Home » Modeling » UML2 » Help, please look at this issue
Help, please look at this issue [message #475921] |
Tue, 18 September 2007 12:52  |
This question might be too easy or even stupid, but I could not find the
solution. Please give me some hints. Thanks a lot!
To get Stereotype Property values, I know I can use
namedElement1.getValue(stereotype1, property1.getName()); if the type of
property1 is primitive types, e.g., String, Boolean..or Enumeration, there
is no problem. BUT when it is another Stereotype (let's say stereotype2)
and the value of property1 is <<stereotype2>><Class>NamedElement2, the
above method returns only the stereotype2! e.g., it looks like this:
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@30d83d (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@1406eb6 (name: stereotype2)
(instanceClassName: null) (abstract: false, interface: false)).
So how could I get the NamedElement2?
Thank you very much for help!
Re: Help, please look at this issue [message #475922 is a reply to message #475921] |
Tue, 18 September 2007 13:37   |
Hi Jerry,
Sorry about the delayed response...
You might want to use UML2Util.getBaseElement() to get the element that the
stereotype is applied to ( I believe that's what you are looking for )
I hope that helps.
- James.
"Jerry" <jianlin@md.kth.se> wrote in message
news:fda13189341cc86449b1579f93ba73a8$1@www.eclipse.org...
Re: Help, please look at this issue [message #475923 is a reply to message #475922] |
Tue, 18 September 2007 13:39   |
.... that's UMLUtil::getBaseElement() ...
...there are other helpful functions like UMLUtil.getStereotype() that will
return a UML stereotype if you pass in the stereotype application
(DynamicEObject).
- James.
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fcp2cn$7fa$2@build.eclipse.org...
> Hi Jerry,
the
> I hope that helps.
> - James.
there
Re: Help, please look at this issue [message #476012 is a reply to message #475923] |
Thu, 20 September 2007 08:21   |
Thank you, and I got further questions :(
Object obj1 = namedElement1.getValue(stereotype1, property1.getName());
sometime it returns an EcoreEList$Dynamic<E>
[org.eclipse.emf.ecore.impl.DynamicEObjectImpl@caf6e7 (eClass:
org.eclipse.emf.ecore.impl.EClassImpl@6014f7 (name: ErrorModel)
(instanceClassName: null) (abstract: false, interface: false))]
if check the obj1.getClass().getCanonicalName() -->
returns{org.eclipse.emf.ecore.util.EcoreEList.Dynamic}
now the baseElement = UMLUtil.getBaseElement((EObject) obj1); get
Exception in thread "main" java.lang.ClassCastException:
org.eclipse.emf.ecore.util.EcoreEList$Dynamic
sometimes it works and gives following expected results:
DynamicEObjectImpl [org.eclipse.emf.ecore.impl.DynamicEObjectImpl@30d83d
(eClass:org.eclipse.emf.ecore.impl.EClassImpl@1406eb6 (name: stereotype2)
(instanceClassName: null) (abstract: false, interface: false))].
and
org.eclipse.uml2.uml.internal.impl.ClassImpl@10e7c9e (name: Element2,
visibility: <unset>) (isLeaf: false, visibility: public, isAbstract:
false) (isActive: false, isAbstract: false)
Could you please explain what's the reason? Thank you!
Re: Help, please look at this issue [message #476013 is a reply to message #476012] |
Thu, 20 September 2007 08:36   |
Jerry,
Comments below.
I would expect this for a property that is multi-valued.
A list can't be an EObject. I think you need to cast to List and
iterate over the contents.
> DynamicEObjectImpl
> (instanceClassName: null) (abstract: false, interface: false))]. and
In this case I assume you've access a property that is single valued is
that yields some type of EObject.
I would assume the difference depends on the multiplicity of the property.
Re: Help, please look at this issue [message #476015 is a reply to message #476012] |
Thu, 20 September 2007 09:13   |
Jerry,
The result would depend on the multiplicity of your stereotype property -
the value of a multivalued reference property will be a list (of dynamic
objects) whereas a the value of a scalar reference property (i.e. with an
upper bound of 1) will be a dynamic object. It only makes sense to pass the
value of a stereotype property to the UMLUtil#getBaseElement(EObject) method
if the value represents the application of another stereotype (i.e. if the
type of the property is another stereotype)...
Kenn
news:04914e650e6d102bbe1bbe1499958a41$1@www.eclipse.org...
Re: Help, please look at this issue [message #476862 is a reply to message #475923] |
Fri, 18 January 2008 09:34  |
Originally posted by: heiyuchuanxia.163.com
Thanks a lot, I think it solved my problem.
Stefanie
James Bruck 写道:
> (DynamicEObject).
> Cheers,
> - James.
>> Hi Jerry,
> the
>> I hope that helps.
>> - James.
> there
Re: Help, please look at this issue [message #624815 is a reply to message #475921] |
Hi Jerry,
I hope that helps.
- James.
Re: Help, please look at this issue [message #624816 is a reply to message #475922] |
(DynamicEObject).
- James.
> Hi Jerry,
the
> I hope that helps.
> - James.
there
Re: Help, please look at this issue [message #624912 is a reply to message #475923] |
and
Re: Help, please look at this issue [message #624914 is a reply to message #476012] |
Jerry,
Comments below.
> DynamicEObjectImpl
Re: Help, please look at this issue [message #624921 is a reply to message #476012] |
Jerry,
Kenn
Re: Help, please look at this issue [message #625910 is a reply to message #475923] |
Stefanie
James Bruck 写道:
> (DynamicEObject).
> Cheers,
> - James.
>> Hi Jerry,
> the
>> I hope that helps.
>> - James.
> there
Current Time: Sun Jul 20 08:58:10 EDT 2025
Powered by FUDForum. Page generated in 0.25951 seconds
