Problem running uml2 api program [message #475210] |
Thu, 23 August 2007 12:44  |
Hi to all!
I've the following problems.
The first is this: I've tried to run like Java Application the
gettingStartedWithUML2 program, but I've the following messages like
output:
Could not find the main class. Program will exit.
java.lang.NoClassDefFoundError:
org/eclipse/emf/common/util/WrappedException
Exception in thread "main"
I've followed all the steps indicated in the gettingStartedWithUML2
article. The file that i've run is the .class not the .java .
The second problem is about a simple program that I've written but when I
try to run it I get te follow error message in the console:
Create Model...
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/uml2/common/util/CacheAdapter
at
org.eclipse.uml2.uml.internal.impl.ElementImpl.getCacheAdapt er(ElementImpl.java:714)
at
org.eclipse.uml2.uml.internal.impl.ElementImpl.eNotification Required(ElementImpl.java:852)
at
org.eclipse.uml2.uml.internal.impl.NamedElementImpl.setName( NamedElementImpl.java:232)
at model.ModelUml.createModel(ModelUml.java:28)
at model.ModelUml.main(ModelUml.java:49)
This is the code:
package model;
import org.eclipse.uml2.uml.Model;
import org.eclipse.uml2.uml.UMLFactory;
public class ModelUml {
public static boolean DEBUG = true;
protected static void out(String output)
if(DEBUG)
System.out.println(output);
protected static void err(String error)
System.err.println(error);
protected static Model createModel(String name)
Model model = UMLFactory.eINSTANCE.createModel();
model.setName(name);
out("Model '" + model.getQualifiedName() + "' created.");
return model;
System.out.println("Create Model...");
Model epoModel = createModel("Modello");
System.out.println("Model created");
I'm using the Eclipse 3.3 and the last version of UML2 plug-in.
Anyone can help me, please?
Thank you
Manu
Re: Problem running uml2 api program [message #624518 is a reply to message #475210] |
Thu, 23 August 2007 18:04  |
Hi Manu,
The getting started article is a little out of date but should still work
fine. I just gave it a try and it everything seemed ok.
I find it strange that you are having issues like "Could not find the main
class". There probably is an issue with how you configured your
environment.
I also looked at the code that creates the CacheAdapter and it also seemes
ok.
Can you try to update your environment once more.
Any other details would be helpful.
Perhaps someone else has also experienced this?
- James.
"Manu" <zappasan@gmail.com> wrote in message
news:e6102edd3bba213dd2eaec66060d9570$1@www.eclipse.org...
> Hi to all!
> output:
> Create Model...
> at
ava:714)
> at
Impl.java:852)
> at
..java:232)
> This is the code:
> package model;
> if(DEBUG)
> return model;
> public static void main(String[] args) {
> Thank you
> Manu
Re: Problem running uml2 api program [message #624519 is a reply to message #475212] |
Fri, 24 August 2007 05:38  |
Hi James!
The way that I've used for configure my environement is very simple:
_ I've downloaded eclipse 3.3 and than I've installed it.
_ With the help of the Eclipse's software update I've download and
installed emf, gmf, gef and uml2.
That's all. Are correct the steps that I've followed? If no, is there
another way to configure uml2? If yes where I can find a step by step
guide to configure it?
Thank you
Manu
Re: Problem running uml2 api program [message #624524 is a reply to message #475213] |
Fri, 24 August 2007 10:05  |
1. Download eclipse
2. Go to help > Software updates > Find and install...
3. Use the Europa discovery site to download UML2
4. Select "All required plugins".
5. Get the .zip as mentioned at the end of the article
"uml2.articles.2006XXXX.zip", ( the link in the article is good )
6. Unzip that into a directory called c:\uml2.articles.2006XXX.zip.
7. From your workspace do File > Import > Plug-in Development > Plugins and
Fragments.
8. for the plugin location use c\uml2.articles.2006XXX.zip.
9. Select the "Binary projects with linked content" option.
10. Select Next then select the found plugin. Click "Add->".
11. You should now see a java project called "com.ibm.uml2.articles".
12. Right click and select Debug As > Java Application.
13. ( It should complain that you have to pass an argument ).
14. go to Open Debug Dialog ...
15 Select entry under "Java Application" and in the "Arguments" tab type
file:/c:/blah
16. now select Debug.
.... voila ...
That works fine for me.
You can alternatively unzip all the source and create a project and import
the source code directly, but these are the steps that the
article recommends ( more or less ).
- James.
news:053fcf75e4077ac15b7d03ce3ad58da5$1@www.eclipse.org...
> Hi James!
> Thank you
> Manu
Re: Problem running uml2 api program [message #624528 is a reply to message #475218] |
Fri, 24 August 2007 11:46  |
Hi!
I've followed all the steps that you've indicated but it doesn't work.
This is the output of the debug:
GettingStartedWithUML2 [Java Application]
com.ibm.uml2.articles.GettingStartedWithUML2 at localhost:3537
Thread [main] (Suspended (exception ClassNotFoundException))
URLClassLoader$1.run() line: not available
AccessController.doPrivileged(PrivilegedExceptionAction<T>,
AccessControlContext) line: not available [native method]
Launcher$AppClassLoader(URLClassLoader).findClass(String) line: not
available
Launcher$AppClassLoader(ClassLoader).loadClass(String, boolean) line:
not available
Launcher$AppClassLoader.loadClass(String, boolean) line: not available
Launcher$AppClassLoader(ClassLoader).loadClass(String) line: not
available
Launcher$AppClassLoader(ClassLoader).loadClassInternal(Strin g) line:
not available
G:\Programmi\Java\jre1.6.0_01\bin\javaw.exe (24/ago/07 17:43:52)
I can understand.
Anyway thank You.
Re: Problem running uml2 api program [message #624530 is a reply to message #475222] |
Fri, 24 August 2007 13:42  |
Can you create a simple java project with a main() that executes?
If so, just get the source code for the articles ( from the .zip) and cut /
paste.
- James.
news:684ad5e0389a409f4637d362796e0e49$1@www.eclipse.org...
> Hi!
> available
> not available
> available
> not available
> I can understand.
> Anyway thank You.
FUDForum. Page generated in 0.05557 seconds
