Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EEF] Compilation with XMLTypePackage.eINSTANCE.getName() - Converter Utils don't expect a String O
[EEF] Compilation with XMLTypePackage.eINSTANCE.getName() - Converter Utils don't expect a String O [message #548614] |
Thu, 22 July 2010 09:27  |
Hi there,
I am trying EEF on my model, I can generate the EEF genmodel.
I made a new plugin project, and added the dependencies.
I get interresting compilation error on a model Type which has the name
"Name".
As an example. (There are many!)
On the following code in i.e. xxxPropertiesEdititionComponent.java
if (NetworksPackage.eINSTANCE.getCountry_Name().equals(msg.getF eature())
&& basePart != null){
if (msg.getNewValue() != null) {
basePart.setName(EcoreUtil.convertToString(XMLTypePackage.eI NSTANCE.getName(),
msg.getNewValue()));
} else {
basePart.setName("");
Compilation Error:
"The method ECoreUtil.converToString in the type ECoreUtil is not
applicable for the arguments (String, String)."
I Suspect, the code generation should handle features with a name "Name"
differently. The XMLTypePackage actually defines the feature with an
additional underscore "_", so getName_()
* Returns the meta object for data type '{@link java.lang.String
<em>Name</em>}'.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @return the meta object for data type '<em>Name</em>'.
* @see java.lang.String
* @model instanceClass="java.lang.String"
* extendedMetaData="name='Name' baseType='token'
pattern='\\i\\c*'"
* @generated
EDataType getName_();
Cheers Christophe
Re: [EEF] Compilation with XMLTypePackage.eINSTANCE.getName() - Converter Utils don't expect a Stri [message #548630 is a reply to message #548614] |
Thu, 22 July 2010 10:06   |
Hi Christophe,
Sound like a generation bug.
You should open a bug on bugzilla, and attach there a reproductible set
of models ( ecore + eef models ) if possible.
Dou you create your own EDatatype ?
Le 22/07/2010 15:27, Christophe Bouhier a écrit :
> Hi there,
> "Name".
> } else {
> Compilation Error:
> <em>Name</em>}'.
> * extendedMetaData="name='Name' baseType='token' pattern='\\i\\c*'"
> * @generated
> Cheers Christophe
Stéphane Bouchet, OBEO
Re: [EEF] Compilation with XMLTypePackage.eINSTANCE.getName() - Converter Utils don't expect a Stri [message #548662 is a reply to message #548614] |
Thu, 22 July 2010 11:03   |
Guys,
Comments below.
Christophe Bouhier wrote:
> Hi there,
> name "Name".
> if
Note that when a Literals interface is generated,
NetworksPackage.Literals.COUNTRY__NAME == msg.getFeature() would be more
efficient.
Similarly NetworksPackage.Literals.NAME could be generated. In any
case, genFeature.getFeatureAccessorName() should be used in the template
so that getName_ will be call. Note that getName will return the name
of the package.
> } else {
> Compilation Error:
> "Name" differently. The XMLTypePackage actually defines the feature
> with an additional underscore "_", so getName_()
> <em>Name</em>}'.
> pattern='\\i\\c*'"
> * @generated
> Cheers Christophe
Re: [EEF] Compilation with XMLTypePackage.eINSTANCE.getName() - Converter Utils don't expect a Stri [message #548747 is a reply to message #548630] |
Thu, 22 July 2010 15:47   |
See inline;
Stéphane Bouchet wrote:
> Hi Christophe,
Yes I will.
No, I don't think I do. I define simple and complex types in .xsd and
read those in. Simple types might become new EDatatypes, not sure actually.
>> Hi there,
>> "Name".
>> } else {
>> Compilation Error:
>> <em>Name</em>}'.
>> * @generated
>> Cheers Christophe
Re: [EEF] Compilation with XMLTypePackage.eINSTANCE.getName() - Converter Utils don't expect a Stri [message #548823 is a reply to message #548662] |
Fri, 23 July 2010 04:12  |
Thanks Ed for your hints, indeed that is the correct way to generates code.
we will integrate hopefully this pathc to next release.
Le 22/07/2010 17:03, Ed Merks a écrit :
> Guys,
> Comments below.
>> Hi there,
>> name "Name".
>> if
> efficient.
> Similarly NetworksPackage.Literals.NAME could be generated. In any case,
> genFeature.getFeatureAccessorName() should be used in the template so
> that getName_ will be call. Note that getName will return the name of
> the package.
>> } else {
>> Compilation Error:
>> <em>Name</em>}'.
>> * @generated
>> Cheers Christophe
Re: [EEF] Compilation with XMLTypePackage.eINSTANCE.getName() - Converter Utils don't expect a Stri [message #623067 is a reply to message #548614] |
Hi Christophe,
> Hi there,
> "Name".
> } else {
> Compilation Error:
> <em>Name</em>}'.
> * @generated
> Cheers Christophe
Re: [EEF] Compilation with XMLTypePackage.eINSTANCE.getName() - Converter Utils don't expect a Stri [message #623068 is a reply to message #548614] |
Guys,
Comments below.
> Hi there,
> name "Name".
> if
efficient.
of the package.
> } else {
> Compilation Error:
> <em>Name</em>}'.
> pattern='\\i\\c*'"
> * @generated
> Cheers Christophe
Re: [EEF] Compilation with XMLTypePackage.eINSTANCE.getName() - Converter Utils don't expect a Stri [message #623069 is a reply to message #548630] |
See inline;
> Hi Christophe,
Yes I will.
>> Hi there,
>> "Name".
>> } else {
>> Compilation Error:
>> <em>Name</em>}'.
>> * @generated
>> Cheers Christophe
Re: [EEF] Compilation with XMLTypePackage.eINSTANCE.getName() - Converter Utils don't expect a Stri [message #623070 is a reply to message #548662] |
> Guys,
> Comments below.
>> Hi there,
>> name "Name".
>> if
> efficient.
> the package.
>> } else {
>> Compilation Error:
>> <em>Name</em>}'.
>> * @generated
>> Cheers Christophe
Current Time: Sat Jul 19 16:28:11 EDT 2025
Powered by FUDForum. Page generated in 0.06267 seconds
