Child comparison problem [message #622914] |
Wed, 19 May 2010 10:31  |
I will be glad for any advice on how to overcome the problem I've encountered when using EMF compare on my model. The essence of the problem is the following:
Let's say I have a model with two objects at root: A and B. Both have a child named C (same name, but different content). When I compare the two copies of the model there are obviously no differences. But as soon as I make a change to one model, say add a new object D to a root, I get not just one difference (D has been added), but three (B.C removed, B.C added, D added).
What I have at the moment is a custom MatchEngine with overridden methods isSimilar(...), findMostSimilar(...) etc. I'd like to know what must be implemented to fix this issue?
Vitaly
Re: Child comparison problem [message #622915 is a reply to message #622914] |
Thu, 20 May 2010 03:24  |
--------------010702090606010302060400
Hi Vitaly,
The "isSimilar()" method you overrode in your custom match engine is
what's causing problems here. Namely, if "isSimilar()" returns false for
your objects "B.C" for any reason, you will get two diffs : "B.C has
been removed" and "B.C has been added".
You'll have to double check your implementation of isSimilar to find why
you're returning false when the two parameters are your "C" objects.
Laurent Goubet
Obeo
Vitaly Savickas wrote:
> Hello,
> added, D added).
> Regards,
> Vitaly
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010702090606010302060400--
FUDForum. Page generated in 0.03596 seconds
