Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Compare] Duplicate move detection
[EMF Compare] Duplicate move detection [message #531780] |
Thu, 06 May 2010 03:37  |
In one of my comparisons I moved one element but EMF Compare produced two changes: A MoveModelElement (regular move) and a UpdateContainmentFeature (containment change), and both contain the very same properties!
Example scenario and proposed fix below.
Scenario:
Changing an association between two UML classes from unidirectional to directional.
Technically speaking: The first listing is the model with the unidirectional association, the second listing the model with the directional association.
<Class> A
<Class> B
- (feature ownedAttribute): <Property> dst : A
<Association> A_src_dst
- (feature ownedEnds): <Property> src : B
<Class> A
- (feature ownedAttribute): <Property> src : B
<Class> B
The two changes that EMF Compare detects are:
- <Property> src : X has been moved from <Class> Y to <Association> A_src_dst
- Containment reference has been changed from ownedAttribute to ownedEnd
As I understand it, there is a bug for the detection of containment reference changes: they should only be detected if it is not already a move. In other words, the containment reference changes should only be created if the container differs.
I checked the generic diff engine and saw that this check is done for Match3Elements but not for Match2Elements.
So I guess we just need to adjust the generic diff engine as follows (just one line added; untested):
protected void checkContainmentUpdate(DiffGroup current, Match2Elements matchElement) {
final EObject leftElement = matchElement.getLeftElement();
final EObject rightElement = matchElement.getRightElement();
if (leftElement.eContainmentFeature() != null && rightElement.eContainmentFeature() != null) {
if (!leftElement.eContainmentFeature().getName().equals(
rightElement.eContainmentFeature().getName())
&& getMatchedEObject(leftElement.eContainer()).equals(rightElem ent.eContainer() // this line is new
createUpdateContainmentOperation(current, leftElement, rightElement);
Best regards
Patrick
Re: [EMF Compare] Duplicate move detection [message #531793 is a reply to message #531780] |
Thu, 06 May 2010 04:32   |
Hi Patrick,
Thanks :) please report a bug including, if possible, the incriminated
models and we'll fix this issue for the next release :)
Cédric
> (containment change), and both contain the very same properties! Example
> Scenario:
> directional. Technically speaking: The first listing is the model with the
> <Class> A
> <Class> B
> <Class> A
> <Class> B
> A_src_dst - Containment reference has been changed from ownedAttribute to
> ownedEnd
> Match3Elements but not for Match2Elements. So I guess we just need to
> matchElement) { final EObject leftElement = matchElement.getLeftElement();
> rightElement.eContainmentFeature() != null) { if
> rightElement.eContainmentFeature().getName()) &&
> // this line is new ) { createUpdateContainmentOperation(current,
> leftElement, rightElement); }
> Best regards
> Patrick
Re: [EMF Compare] Duplicate move detection [message #531874 is a reply to message #531793] |
Thu, 06 May 2010 09:09  |
Sure: https://bugs.eclipse.org/bugs/show_bug.cgi?id=311872
On 06-05-2010 10:33, Cédric Brun wrote:
> Hi Patrick,
> Cédric
>> Scenario:
>> <Class> A
>> <Class> B
>> - (feature ownedAttribute):<Property> dst : A
>> - (feature ownedEnds):<Property> src : B
>> <Class> A
>> - (feature ownedAttribute):<Property> src : B
>> <Class> B
>> -<Property> src : X has been moved from<Class> Y to<Association>
>> ownedEnd
>> if (leftElement.eContainmentFeature() != null&&
>> rightElement.eContainmentFeature().getName())&&
>> Best regards
>> Patrick
Re: [EMF Compare] Duplicate move detection [message #622833 is a reply to message #531780] |
Thu, 06 May 2010 04:33  |
Hi Patrick,
Cédric
> Scenario:
> <Class> A
> <Class> B
> <Class> A
> <Class> B
> ownedEnd
> Best regards
> Patrick
Re: [EMF Compare] Duplicate move detection [message #622835 is a reply to message #622833] |
> Hi Patrick,
> Cédric
>> Scenario:
>> <Class> A
>> <Class> B
>> <Class> A
>> <Class> B
>> ownedEnd
>> Best regards
>> Patrick
Current Time: Sat Jul 19 11:40:58 EDT 2025
Powered by FUDForum. Page generated in 0.06696 seconds
