Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » CDO problems
CDO problems [message #622014] Mon, 18 January 2010 05:25 Go to next message
Hi all ,
i use cdo session View to create a cdo resource , but i have this exception :
org.eclipse.net4j.signal.RemoteException: java.lang.NullPointerException
at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteEx ception(RequestWithConfirmation.java:128)
at org.eclipse.net4j.signal.SignalProtocol.handleRemoteExceptio n(SignalProtocol.java:491)
at org.eclipse.net4j.signal.RemoteExceptionIndication.indicatin g(RemoteExceptionIndication.java:53)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indicati on.java:55)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:312)
at org.eclipse.net4j.signal.Indication.execute(Indication.java: 49)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:239)
at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.eclipse.emf.cdo.internal.server.TransactionCommitContext Impl$TransactionPackageRegistry.putPackageUnit(TransactionCo mmitContextImpl.java:687)
at org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicatingCommit(CommitTransactionIndication.ja va:268)
at org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:197 )
at org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:140 )
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating (IndicationWithMonitoring.java:84)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn put(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:63)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In dicationWithMonitoring.java:63)
... 5 more
Thanks in advance,
Zakarov
Zakarov
Re: CDO problems [message #622015 is a reply to message #622014] Mon, 18 January 2010 05:28 Go to previous messageGo to next message
Hi Zakarow,
Please use the EMF newsgroup for CDO support.
Which CDO version are you referring to?
Cheers
/Eike
Zakarov schrieb:
> Hi all ,
> exception : java.lang.NullPointerException
> on.java:55)
> wn Source)
> ... 5 more
> Thanks in advance,
> Zakarov
Re: CDO problems [message #622016 is a reply to message #622014] Mon, 18 January 2010 06:02 Go to previous messageGo to next message
Thank you Eike ,
i'm using the 2.0
can you give me the link for EMF newsgroup , to post my next cdo posts in.
Zakarov .
Zakarov
Re: CDO problems [message #622017 is a reply to message #622016] Mon, 18 January 2010 06:20 Go to previous message
Zakarov schrieb:
> Thank you Eike ,
> i'm using the 2.0
> in.
Google is your friend:
http://www.google.de/#hl=de&source=hp&q=EMF+newsgrou p&btnG=Google-Suche&meta=lr%3D&aq=f&oq=EMF+n ewsgroup&fp=f6ac4f2ff50ba745
Cheers
/Eike
Previous Topic:CDO problems
Next Topic:How to generate code from GMF editor
Current Time: Sat Jul 19 11:49:26 EDT 2025
Powered by FUDForum. Page generated in 0.30662 seconds
