teneo, databinding, model and a treeview [message #506467] |
Thu, 07 January 2010 11:07  |
I have made a small RCP-Application. I work with databinding and a Treeview. My datamodel represents a tree of folders like the Windows Explorer. I can add Folders and Subfolders and it works fine.
Now I would store the "folders" in a database with teneo. If I load my application I can add folders and subfolders to existing folders and subfolders. The TreeViewer shows the new folders and subfolders. These folders are also stored.
But if I add subfolders to the new folders or subfolders, the TreeViewer shows these folder but they where not stored.
Maybe, someone have a good tutorial ore an idea.
The property "children" of a loaded item contains a HibernatePersistableEList<E>.
But the "children"-property of an added item contains an EObjectWithInverseResolvingEList<E>.
I think, this is the problem.
Re: teneo, databinding, model and a treeview [message #506496 is a reply to message #506467] |
Thu, 07 January 2010 12:36   |
Hi Nebulus,
Indeed objects loaded from the database have the hibernatepersistableelist and new objects have an EMF elist. However,
this normally works fine. So afaics this is not the problem. I guess you don't see exceptions etc.?
Apart from this the only thing you can do is debug some more into the HibernateResource (in the method taking care of
saving to the database)?
Then when you have more info just post it on the EMF newsgroup and I can take a further look.
Teneo is supported on the EMF newsgroup which I added as cc.
gr. Martin
Nebulus wrote:
> Hello,
> folders are also stored. But if I add subfolders to the new folders or
> HibernatePersistableEList<E>. But the "children"-property of an added
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo, databinding, model and a treeview [message #506497 is a reply to message #506496] |
Thu, 07 January 2010 12:41   |
Martin, I remember us fixing this problem in Teneo some time before
EclipseCon 2009 which looks like this.
Nebulus which version of Teneo do you use and how are you
adding/removing subitems?
Tom
Am 07.01.10 18:36, schrieb Martin Taal:
> Hi Nebulus,
> HibernateResource (in the method taking care of saving to the database)?
> gr. Martin
> Nebulus wrote:
>> Hello,
Re: teneo, databinding, model and a treeview [message #621971 is a reply to message #506496] |
Tom
> Hi Nebulus,
> gr. Martin
> Nebulus wrote:
>> Hello,
FUDForum. Page generated in 0.06318 seconds
