Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] "Copy current change from right to left" doesn't work?
[EMF Compare] "Copy current change from right to left" doesn't work? [message #621963] Wed, 06 January 2010 04:22 Go to next message
I am a new user for EMF compare. I just do a simple test.
Base model is one class.
Then User1 add one attribute: Property1:EInt.
Then I use EMF compare each other, at this time, base model is on left side, and User1 is on right side.
When I click "Copy current change from right to left" button to merge from right to left, it doesn't add same attribute on left model. On left model, just one attribute named as Property1, but has no EInt type!
Is this normal behavior?
B.T.W, if I want to extend "Copy current change from right to left" button action, how to develop? I means what extension point should i extend?
Thanks!
Re: [EMF Compare] "Copy current change from right to left" doesn't work? [message #621965 is a reply to message #621963] Wed, 06 January 2010 07:16 Go to previous message
--------------010703020606040502070807
Nope, this is no expected behavior; though we've never experienced this
ourselves and I cannot reproduce your behavior with sample models with
the steps outlined here.
This seems to be fixed with the latest vesion of EMF Compare. Which are
you using?
Extending the merge actions is not possiblve apart from providing your
own mergers. This is done through the extension point
org.eclipse.emf.compare.diff.mergerprovider .
Laurent Goubet
Obeo
esong0317@163.com wrote:
> extend?
> Thanks!
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010703020606040502070807--
Previous Topic:[MWE] MWE project evolution?
Next Topic:have no "Eclipse Application" option on the menu
Current Time: Sun Jul 20 03:14:47 EDT 2025
Powered by FUDForum. Page generated in 0.03314 seconds
