Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMFdiff file display
EMFdiff file display [message #504370] Fri, 18 December 2009 09:49 Go to next message
I want to make an application that can view an emfdiff file in a treestructure. Is there an xsd file from this emfdiff file or what is the best way to to this?Or can someone give some more information how this file is constructed?
Randi
Re: [EMF Compare] EMFdiff file display [message #504718 is a reply to message #504370] Tue, 22 December 2009 05:31 Go to previous messageGo to next message
--------------020108080603020208030004
Hi Randi,
Please set "[EMF Compare]" in the subject line for ease of reading ^^.
As for your question ... I do not really understand. Displaying the
emfdiff file in the compare editor is a matter of double clicking it
with EMF Compare installed, what is blocking you?
The metamodels used to construct these files are both the match.ecore
and diff.ecore models of EMF Compare.
Laurent Goubet
Obeo
Randi wrote:
> Hello,
> Randi
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020108080603020208030004--
Re: [EMF Compare] EMFdiff file display [message #504726 is a reply to message #504718] Tue, 22 December 2009 06:05 Go to previous messageGo to next message
Hello Laurent,
Well I made a standalone version for the EMFCompare where I safe a resultdiff file as result.xmi (I compare 2 umlmodels in xmi format) . Now I want to parse this diff file so I can put in a GUI as a treeview so all deleted nodes for eg as children from the node Deleted. Almost the same like in Eclipse , but as a standalone version. So I want to show the difference between the 2 models in a GUI I want to have standalone. Is there some DTD available or so from the difffile or wat is the best way to show a treeview of the diff file.
Many thanks
Randi
Re: [EMF Compare] EMFdiff file display [message #504744 is a reply to message #504726] Tue, 22 December 2009 02:04 Go to previous messageGo to next message
--------------070900090207050604070201
Randi,
Both EMF Compare and EMF are developped to be usable in a standalone
application. You can simply load the emfdiff file via the EMF facilities
once both the match and diff packages are registered in the package
registry.
Something along the lines of
ResourceSet rs = new ResourceSetImpl();
rs.getPackageRegistry().put(DiffPackage.eNS_URI, DiffPackage.eINSTANCE);
rs.getPackageRegistry().put(MatchPackage.eNS_URI, MatchPackage.eINSTANCE);
rs.getResource(<modelURI>, true);
should do the trick.
If you want to code your own parser, I can't really help on how to do
it. All I know is : if you need a DTD, as I understand it the DTD is
simply xmi, with the namespaces being the ecore, diff and match metamodels :
org.eclipse.emf.ecore/model/Ecore.ecore
org.eclipse.emf.compare.diff/model/diff.ecore
org.eclipse.emf.compare.match/model/match.ecore
Laurent Goubet
Obeo
Randi wrote:
> Hello Laurent,
> Many thanks
> Randi
--------------070900090207050604070201--
Re: [EMF Compare] EMFdiff file display [message #621950 is a reply to message #504718] Tue, 22 December 2009 06:05 Go to previous messageGo to next message
Hello Laurent,
Many thanks
Randi
Re: [EMF Compare] EMFdiff file display [message #621951 is a reply to message #504726] Tue, 22 December 2009 07:02 Go to previous message
Randi,
registry.
Laurent Goubet
Obeo
Randi wrote:
> Hello Laurent,
> Many thanks
> Randi
Previous Topic:EMFdiff file display
Next Topic:EEF Can´t display the property view
Current Time: Sat Jul 19 17:43:39 EDT 2025
Powered by FUDForum. Page generated in 0.04497 seconds
