[EMF Compare] possible bug comparing resources [message #621349] |
Tue, 01 September 2009 09:12 |
I have encountered a problem in EMF compare whereby an index out of bounds
(-1) exception in thrown in resourceURISimilatity when comparing in memory
(non-persisted) resources. My resources are created in this way:
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.createResource(URI.createURI(""));
EList<EObject> contents = resource.getContents();
contents.add(emfModel);
Does anyone know whether this is a known issue? If so, is there are fix for
it?
java.lang.ArrayIndexOutOfBoundsException: -1
at
org.eclipse.emf.compare.match.internal.statistic.ResourceSim ilarity.resourceURISimilarity(ResourceSimilarity.java:138)
at
org.eclipse.emf.compare.match.internal.statistic.ResourceSim ilarity.computeURISimilarity(ResourceSimilarity.java:94)
at
org.eclipse.emf.compare.diff.engine.check.ReferencesCheck.co mputeDeletedReferences(ReferencesCheck.java:400)
at
org.eclipse.emf.compare.diff.engine.check.ReferencesCheck.cr eateNonConflictingReferencesUpdate(ReferencesCheck.java:520)
at
org.eclipse.emf.compare.diff.engine.check.ReferencesCheck.ch eckReferenceUpdates(ReferencesCheck.java:197)
at
org.eclipse.emf.compare.diff.engine.check.ReferencesCheck.ch eckReferencesUpdates(ReferencesCheck.java:77)
at
org.eclipse.emf.compare.diff.engine.GenericDiffEngine.checkF orDiffs(GenericDiffEngine.java:338)
at
org.eclipse.emf.compare.diff.engine.GenericDiffEngine.doDiff Delegate(GenericDiffEngine.java:930)
at
org.eclipse.emf.compare.diff.engine.GenericDiffEngine.doDiff Delegate(GenericDiffEngine.java:953)
at
at
org.eclipse.emf.compare.diff.engine.GenericDiffEngine.doDiff TwoWay(GenericDiffEngine.java:576)
at
org.eclipse.emf.compare.diff.engine.GenericDiffEngine.doDiff (GenericDiffEngine.java:113)
at
org.eclipse.emf.compare.diff.service.DiffService.doDiff(Diff Service.java:101)
at
org.eclipse.emf.compare.diff.service.DiffService.doDiff(Diff Service.java:82)
Jose
FUDForum. Page generated in 0.03397 seconds
