Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Use several ecore file for the same model
[Teneo] Use several ecore file for the same model [message #128858] Wed, 20 August 2008 08:53 Go to next message
Hello !
I want to persit a model with links to another ecore file.
In EMF we have the possibility to load another ecore within an existing
ecore, and to make references to this model.
Example : The ResourceExtendedTest extends a Resource defined in another
ecore file :
<eClassifiers xsi:type="ecore:EClass" name="ResourceExtendedTest"
eSuperTypes="../../../model/DreamsBasicModel.ecore#//Resource ">
</eClassifiers>
But when initializing (HbSessionDataStore.initialize ), It throws an
exception because it can't find the the Resource defined in the other ecore
file:
java.lang.IllegalArgumentException: No annotated model element present for:
Resource for type EClass has its epackage been registered with Teneo?
at
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.checkAnnotatedPresent(PAnnotatedModelImpl.java:346)
at
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.getPAnnotated(PAnnotatedModelImpl.java:288)
at
org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator.ann otate(EClassAnnotator.java:91)
at
org.eclipse.emf.teneo.hibernate.annotations.HbEClassAnnotato r.annotate(HbEClassAnnotator.java:55)
at
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator .processPackage(AnnotationGenerator.java:167)
at
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator .map(AnnotationGenerator.java:135)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:142)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:66)
at
org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbD ataStore.java:609)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataStore.java:155)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:73)
at
org.eclipse.emf.teneo.hibernate.HbBaseSessionDataStore.getSe ssionFactory(HbBaseSessionDataStore.java:57)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.close(HbS essionDataStore.java:172)
at
com.oslo.dreams.model.util.ExtendedModelLoaderTest.testLoadM odel(ExtendedModelLoaderTest.java:38)
All the packages has been registered (even the packages defined in the other
ecore file).
Thanks in advance for your help,
Samuel Michelot
Re: [Teneo] Use several ecore file for the same model [message #128885 is a reply to message #128858] Fri, 22 August 2008 12:26 Go to previous message
Hi Samuel,
Sorry for the late reply, I was travelling and I had missed your post before that. Also support for
Teneo is given on the EMF newsgroup which I cc-ed.
Teneo does not resolve the references by itself. You need to tell the datastore which EPackages you
want to persist. All your epackages should be passed in the call to dataStore.setEPackages.
gr. Martin
Samuel Michelot wrote:
> Hello !
> ecore file :
> </eClassifiers>
> file:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ecore file).
> Regards,
> Samuel Michelot
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Use several ecore file for the same model [message #620248 is a reply to message #128858] Fri, 22 August 2008 12:26 Go to previous message
Hi Samuel,
gr. Martin
> Hello !
> ecore file :
> </eClassifiers>
> file:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ecore file).
> Regards,
> Samuel Michelot
The Netherlands
Previous Topic:EMF search returns duplicate results
Next Topic:[Teneo] Error running Teneo (1.x) Dynamic.java example
Current Time: Sun Jul 20 16:09:27 EDT 2025
Powered by FUDForum. Page generated in 0.03834 seconds
