Home » Archived » Service Oriented Architecture Tools Platform (STP) » AnnValidator missing from Ganymede Update
AnnValidator missing from Ganymede Update [message #620101] Wed, 08 October 2008 17:59 Go to next message
I just upgraded to Ganymede and installed the STP (and many other) updates
using the software updater. When trying to create a wsdl on a Java-first
JAX-WS project though I get a pop-up claiming a class cannot be found.
When checking the log I see many (nested?) exceptions about Annvalidator
like:
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2008-10-08 14:37:57.244
!MESSAGE Plug-in org.eclipse.stp.sc.annvalidator was unable to load class
org.eclipse.stp.sc.annvalidator.builder.AnnValidator.
!STACK 0
java.lang.ClassNotFoundException:
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:481)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:313)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.core.internal.events.BuildManager.instantiateBui lder(BuildManager.java:788)
at
org.eclipse.core.internal.events.BuildManager.initializeBuil der(BuildManager.java:741)
at
org.eclipse.core.internal.events.BuildManager.getBuilder(Bui ldManager.java:480)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:199)
at
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:309)
at
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:341)
at
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:140)
at
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:238)
When I look in my plugins directory and open the
org.eclipse.stp.sc.annvalidator_0.9.0.200806121858.jar I find the plugin
xml file refers to several class but the jar is empty of any classes. I
have found only on other reference to this problem on the web so far, but
that author also concluded that this jar ought to have some classes in it
(he also references the
org.eclipse.stp.sc.xmlvalidator_0.9.0.200806121858.jar which is also empty
of classes).
Am I incorrect in assuming that the class should be in that jar? Is there
a work-around in order for me to get the JAX-WS web-service built? Thanks!
Re: AnnValidator missing from Ganymede Update [message #620106 is a reply to message #620101] Wed, 08 October 2008 18:08 Go to previous messageGo to next message
I should be more specific. The error in my fist post occurred after I
removed the annValidator.jar from the plugins directory and restarted
eclipse. With the jar in the plugins directory, the log shows the
following at startup:
eclipse.buildId=M20080911-1700
java.version=1.6.0_06
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui.workbench 2 0 2008-10-08 15:01:48.806
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-10-08 15:01:48.806
!MESSAGE Conflict for 'org.eclipse.gmf.ValidateAction':
HandlerActivation(commandId=org.eclipse.gmf.ValidateAction,
handler=ActionDelegateHandlerProxy(null,org.eclipse.stp.eid. datamodel.diagram.part.CimeroEditorValidateAction),
expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@107c615),sourcePriority=16384)
handler=ActionDelegateHandlerProxy(null,org.eclipse.stp.sca. diagram.part.SCADiagramValidateAction),
And then when I go to my JAX-WS project, right click on the annotated
class I wish to make a webservice from and then choose "JAX-WS
Tools">"Create Web Service" I see:
!ENTRY org.eclipse.osgi 2 0 2008-10-08 15:05:05.150
!MESSAGE The activator org.eclipse.stp.sc.sca.java.ScaJavaPlugin for
bundle org.eclipse.stp.sc.sca.java is invalid
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.stp.sc.sca.java.ScaJavaPlugin for bundle
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:234)
at
at
at
at
at
at
org.eclipse.stp.sc.common.annotations.ext.AnnotationSupportP roxy.loadAnnotationResolver(AnnotationSupportProxy.java:91)
at
org.eclipse.stp.sc.common.annotations.ext.AnnotationSupportP roxy. <clinit>(AnnotationSupportProxy.java:58)
at
org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getAnnotationClassesForJavaElement(ScAnnotationSupportUti ls.java:188)
at
org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getAvailableAnnotationsForClass(ScAnnotationSupportUtils. java:54)
at
org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getAvailableAnnotationsForType(ScAnnotationSupportUtils.j ava:87)
at
org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.isAnnotationValidForMember(ScAnnotationSupportUtils.java: 175)
at
org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getDefaultedAnnotationNode(ScAnnotationSupportUtils.java: 146)
at
org.eclipse.stp.sc.jaxws.wizards.annotations.AnnotationAttri butePage.initializeFromDefault(AnnotationAttributePage.java: 211)
at
org.eclipse.stp.sc.jaxws.wizards.annotations.AnnotationAttri butePage.createAttributeGroup(AnnotationAttributePage.java:1 82)
at
org.eclipse.stp.sc.jaxws.wizards.annotations.AnnotationAttri butePage.createControl(AnnotationAttributePage.java:126)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:170)
at
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:669)
at
org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:543)
at
org.eclipse.stp.sc.jaxws.wizards.ScWizardDialog.createConten ts(ScWizardDialog.java:43)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at
org.eclipse.stp.sc.jaxws.actions.CreateWebServiceAction.run( CreateWebServiceAction.java:63)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
Caused by: java.lang.ClassNotFoundException:
at
at
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:139)
... 56 more
Root exception:
java.lang.ClassNotFoundException: org.eclipse.stp.sc.sca.java.ScaJavaPlugin
at
And when I right click on the root of my JAX-WS project and go to "JAX-WS
Tools">"Generate WSDL" I see:
!ENTRY org.eclipse.osgi 2 0 2008-10-08 15:07:39.556
!MESSAGE The activator org.eclipse.stp.sc.annvalidator.AnnValidatorPlugin
for bundle org.eclipse.stp.sc.annvalidator is invalid
!STACK 0
org.eclipse.stp.sc.annvalidator.AnnValidatorPlugin for bundle
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:218)
at
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:360)
at
org.eclipse.core.internal.resources.Project.internalBuild(Pr oject.java:516)
at org.eclipse.core.internal.resources.Project.build(Project.ja va:94)
at
org.eclipse.stp.sc.jaxws.actions.AssignedJava2WsdlAction.run (AssignedJava2WsdlAction.java:41)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 50 more
Root exception:
So what I am doing so wrong that I am missing all these classes?
Thanks!
Re: AnnValidator missing from Ganymede Update [message #620108 is a reply to message #620106] Thu, 09 October 2008 08:10 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Brian, please open a bug with those stacktraces, a reference to this
newsgroup thread, and the version numbers of the STP plugins in your
workspace.
Crossposting to SCA Tools newgroup as one of the exceptions is about the
SCA plugins.
Antoine
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> ... 56 more
> Root exception:
> at
> "JAX-WS Tools">"Generate WSDL" I see:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 50 more
> Root exception:
> Thanks!
Re: AnnValidator missing from Ganymede Update [message #620109 is a reply to message #620108] Thu, 09 October 2008 08:47 Go to previous messageGo to next message
Hi Antoine, Brian,
Sorry, I don't think that SCA Tools is involved in your problem.
> org.osgi.framework.BundleException: The activator org.eclipse.stp.sc.sca.java.ScaJavaPlugin for bundle org.eclipse.stp.sc.sca.java is invalid
This error is coming from the Service Creation component (stp.sc).
This component contains (old) tools for SCA developpers but it doesn't
form part of the SCA Tools project.
However, you discovered a conflict between the Cimero Editor and the SCA
Composite Designer. This message is just a warning and is not related
with the before-mentioned exception.
Thanks ;)
Stéphane Drapeau
Obeo
Re: AnnValidator missing from Ganymede Update [message #620110 is a reply to message #620109] Thu, 09 October 2008 10:51 Go to previous messageGo to next message
Stephane Drapeau wrote:
> Hi Antoine, Brian,
OK.
> Thanks ;)
Aha! I did something useful today. What a nice feeling!
> Regards,
> Stéphane Drapeau
> Obeo
Re: AnnValidator missing from Ganymede Update [message #620111 is a reply to message #620110] Thu, 09 October 2008 11:00 Go to previous messageGo to next message
>> Hi Antoine, Brian,
> OK.
Brian, you should file a bug against stp.sc. If you want it fixed
quickly, please consider providing a patch.
Antoine
Re: AnnValidator missing from Ganymede Update [message #620487 is a reply to message #620111] Fri, 10 October 2008 09:14 Go to previous message
I think there's commentary on the general state of affairs
here in the next posting entitled "Retirement of inactive
components in STP".
Oisin Hurley at Progress
http://oisinh.wordpress.com
Previous Topic:Retirement of inactive components in STP
Next Topic:MDA-BPM position at Lille
Current Time: Sat Jul 19 15:59:43 EDT 2025
Powered by FUDForum. Page generated in 0.05309 seconds
