Home » Archived » GMT (Generative Modeling Technologies) » [MOFScript]execute transformation
[MOFScript]execute transformation [message #619930] Thu, 21 August 2008 06:53
I designed an graphical editor using EMF and GMF,and when I create an
instance of this editor in Eclipse,there are two files generated, one is
xx(domain file extension) which is writen in XML Schema and another
xx_diagram.Now I wanna transfer model to text which is another kind of
code.
I have copied my .ecore file to the metamodel file of MOFScript and I
try to execute the transformation code.But when I select the source
model,should I select the .xx file,but no file of this extension is shown
in the dialogue.if I choose the xx.ecore file ,then nothing happend.I set
the file() with reasonable path in the main rule.Where had gone wrong?
Thanks a lot!
Ye
Previous Topic:[Epsilon] - Eugenia - Generate GMF tool, graph and map model
Next Topic:[AM3] Wrinting UML models with ANT plugin
Current Time: Sun Jul 20 12:25:49 EDT 2025
Powered by FUDForum. Page generated in 0.23708 seconds
