Home » Eclipse Projects » Platform - User Assistance (UA) » Re: InfoCenter Exception
Re: InfoCenter Exception [message #474302] Thu, 28 August 2008 08:45 Go to next message
Originally posted by: nospam_kowalskilee.gmail.com
Markus Wolf wrote:
> we are using the eclipse infocenter deployed on tomcat to serve our
> online help. Now we created an index from our docbook base and added it
> to the plugin.xml as described in the eclipse help. So far so good, but
> when we try to open the index we get this exception:
> SCHWERWIEGEND: Servlet.service() for servlet equinoxbridgeservlet threw
> exception
> java.lang.ClassCastException: org.eclipse.help.internal.toc.Toc$1 cannot
> be cast to org.eclipse.help.internal.Topic
> at org.eclipse.help.internal.toc.TocManager.getTopic
> (TocManager.java:120)
> at org.eclipse.help.internal.index.IndexAssembler
> $IndexComparator.getLabel(IndexAssembler.java:247)
> $IndexComparator.compare(IndexAssembler.java:199)
> at java.util.Arrays.mergeSort(Arrays.java:1270)
> at java.util.Arrays.mergeSort(Arrays.java:1281)
> at java.util.Arrays.sort(Arrays.java:1210)
> at org.eclipse.help.internal.index.IndexAssembler.sort
> (IndexAssembler.java:155)
> (IndexAssembler.java:141)
> at org.eclipse.help.internal.index.IndexAssembler.assemble
> (IndexAssembler.java:52)
> at org.eclipse.help.internal.index.IndexManager.getIndex
> (IndexManager.java:59)
> at org.eclipse.help.internal.webapp.servlet.IndexFragmentServle t
> $Serializer.<init>(IndexFragmentServlet.java:125)
> at
> org.eclipse.help.internal.webapp.servlet.IndexFragmentServle t.doGet
> (IndexFragmentServlet.java:103)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
> at org.eclipse.equinox.http.registry.internal.ServletManager
> $ServletWrapper.service(ServletManager.java:180)
> at
> org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest
> (ServletRegistration.java:90)
> at
> org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias
> (ProxyServlet.java:111)
> at org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce
> (ProxyServlet.java:59)
> at org.eclipse.equinox.servletbridge.BridgeServlet.service
> (BridgeServlet.java:121)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter
> (ApplicationFilterChain.java:290)
> at org.apache.catalina.core.ApplicationFilterChain.doFilter
> (ApplicationFilterChain.java:206)
> at org.apache.catalina.core.StandardWrapperValve.invoke
> (StandardWrapperValve.java:233)
> at org.apache.catalina.core.StandardContextValve.invoke
> (StandardContextValve.java:175)
> at org.apache.catalina.core.StandardHostValve.invoke
> (StandardHostValve.java:128)
> at org.apache.catalina.valves.ErrorReportValve.invoke
> (ErrorReportValve.java:102)
> at org.apache.catalina.core.StandardEngineValve.invoke
> (StandardEngineValve.java:109)
> at org.apache.catalina.connector.CoyoteAdapter.service
> (CoyoteAdapter.java:286)
> at org.apache.coyote.http11.Http11Processor.process
> (Http11Processor.java:844)
> at org.apache.coyote.http11.Http11Protocol
> $Http11ConnectionHandler.process(Http11Protocol.java:583)
> at org.apache.tomcat.util.net.JIoEndpoint$Worker.run
> (JIoEndpoint.java:447)
> at java.lang.Thread.run(Thread.java:619)
> Can anyone help us on how to resolve the issue?
> We looked the the source of the TocManager which does the invalid cast.
> And in fact the returned object, from the method call before the
> exception is thrown, implements the interface ITopic but is not a Topic
> object.
> Thanks for any input
> Markus Wolf
Re: InfoCenter Exception [message #474303 is a reply to message #474302] Thu, 28 August 2008 12:46 Go to previous message
This sounds like a bug, can you file a bug report. What is happening is
that an index entry in a remote toc does not have a label attribute and
it is trying to look up the href in the TOC, we have tested the remote
index but may not have hit on that particular situation in our testing.
Lee Anne wrote:
> Markus Wolf wrote:
>> Hi,
>> it to the plugin.xml as described in the eclipse help. So far so good,
>> but when we try to open the index we get this exception:
>> threw exception
>> cannot be cast to org.eclipse.help.internal.Topic
>> at
>> at
>> at
>> at
>> cast. And in fact the returned object, from the method call before the
>> Topic object.
>> Markus Wolf
Re: InfoCenter Exception [message #619455 is a reply to message #474302] Thu, 28 August 2008 12:46 Go to previous message
Lee Anne wrote:
> Markus Wolf wrote:
>> Hi,
>> threw exception
>> at
>> at
>> at
>> at
>> Topic object.
>> Markus Wolf
Previous Topic:How to add anchor to href in a call to displayHelpResource
Next Topic:Not recognising helpdata.xml
Current Time: Sat Jul 19 09:13:56 EDT 2025
Powered by FUDForum. Page generated in 0.03617 seconds
