Home » Eclipse Projects » Dali » Eclipse RCP et JPA
Eclipse RCP et JPA [message #619274] Fri, 04 June 2010 11:12 Go to next message
Hello
I am developing a java application with Eclipse RCP.
For the persistence of data I used JPA. The problem is that I can not integrate the two into a single project.
When I run my classes as JPA java bean everything works perfectly but when I try to integrate with RCP, it leaves me this error:
avax.persistence.PersistenceException: No Persistence provider for EntityManager named maquette
at javax.persistence.Persistence.createEntityManagerFactory(Per sistence.java:89)
at javax.persistence.Persistence.createEntityManagerFactory(Per sistence.java:60)
at sofrecom.service.FichierNMFService.<init>(FichierNMFService.java:16)
at maquette.NavigationView.createDummyModel(NavigationView.java :140)
at maquette.NavigationView.createPartControl(NavigationView.jav a:180)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:367)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:226)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 3)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:52 9)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 08)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:649)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:576)
at org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:568)
at org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:272)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:982)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:2626)
at org.eclipse.ui.internal.WorkbenchWindow$27.run(WorkbenchWind ow.java:2965)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2946)
at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:761)
at org.eclipse.ui.internal.Workbench$21.runWithException(Workbe nch.java:1045)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3885)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3506)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at maquette.Application.start(Application.java:20)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Someone can tell me where is the problem? or have an idea to integrate jpa with eclipse rcp application.
Thank you in advance for your help.
Re: Eclipse RCP et JPA [message #619277 is a reply to message #619274] Mon, 07 June 2010 13:26 Go to previous message
Take a look at the simple EclipseLink JPA/RCP example here: http://wiki.eclipse.org/EclipseLink/Examples/OSGi/LazyLoadin gRCP
--Shaun
Previous Topic:Re: Creating New JPA Project - Configuration Options
Next Topic:Dali 2.3 released with Helios!
Current Time: Sat Jul 19 16:39:29 EDT 2025
Powered by FUDForum. Page generated in 0.26074 seconds
