Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Collide ID validation error
Collide ID validation error [message #619270] Fri, 20 June 2008 15:06
I’m getting the following diagnostic error while saving the resource via
TENEO:
Diagnosis of
com.accenture.tools.sd.model.domain.impl.WindowImpl@14ad296{ hibernate://?dsname=yigal_db&query1=
from Window where entityname='WINTST2'#Window|id=95}
The ID '35' of
'com.accenture.tools.sd.model.domain.impl.EntityDescriptionI mpl @e6529c{hibernate://?dsname=yigal_db&query1=
from Window where entityname='WINTST2'#EntityDescription|id=35}'
collides with that of
' com.accenture.tools.sd.model.domain.impl.ToolResourceRegistr yImpl@d9783e{hibernate://?dsname=yigal_db&query1=
from Window where entityname='WINTST2'#ToolResourceRegistry|id=35}'
It seems that there is a conflict between IDs on different classes that
are different tables.
I do not understand why all of a sudden I have ID conflict? (we did
convert a different data set to see this issue, it does not happen with
the dataset from Assembly test).
If I have Window class that has an attribute called “WinIdKey” and it is
marked in the eCore as ID=true.
The Window class references two other classes:
1. ToolResourceRegistry (trrIdKey attribute with ID=true) and
2. EntityDescription (descIdKey attribute with ID=true)
all the ID attributes have a different name.
Why is there a conflict?
Yigal
Previous Topic:[Teneo + GMF] Diagram and model element handling
Next Topic:Collide ID validation error
Current Time: Sat Jul 19 08:48:27 EDT 2025
Powered by FUDForum. Page generated in 0.03119 seconds
