Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo + GMF] Diagram and model element handling
[Teneo + GMF] Diagram and model element handling [message #126055] |
Thu, 19 June 2008 05:20  |
Hello Martin and Teneo users!
For my application I want to give the user the possibilty to create and
also undo/redo/copy/paste (summed up mostly all capabilities which
emf.edit provides out of the box) diagram instances.
My current solution works but I am not really satisfied (and you probably
too when you read this post :) ).
Every Diagram "container" model instance (in your tutorial the "Map")
relates to the GMF "Diagram" model instance. With this rule in mind I do
the following:
I tell you which step I perform when creating my "Map" + "Diagram"
instance:
I create and initialize the "Map" on the command stack. Then I save the
resource so that the ID attribute gets filled and has an unique value.
Then I create the "Diagram" instance on the command stack and set the name
to the id of the "Map". So now I have a very simple reference between the
"Map" and the "Diagram" that I need when opening the diagram editor. Then
I save the resource again.
When opening the diagram I use the following query: "query1=from
Map&query2=from Diagram where name='[Map Id that should be opened]'".
As you can see undo and redo is not really possible, also the same for
deleting, copy and paste, because the Map is not really referenced to the
Diagram.
The rest of my code is nearly exactly the same as used in the Tutorial.
So how would you do it when you want to open serveral different diagram
instances?!?
Thank you for your answers!
Matthias
Re: [Teneo + GMF] Diagram and model element handling [message #126068 is a reply to message #126055] |
Thu, 19 June 2008 09:24   |
Hi Matthias,
Hmmm, I don't yet understand, why don't you create and save the diagram and map in one step (so
create both and then save the resource)?
To guess what you want to achieve in the end: do you want to create the map/diagram and then open
the editor without first saving them in the db? So then the save happens when someone selects save
in the diagram.
gr. Martin
> probably too when you read this post :) ).
> the following:
> instance:
> name to the id of the "Map". So now I have a very simple reference
> between the "Map" and the "Diagram" that I need when opening the diagram
> editor. Then I save the resource again.
> the Diagram.
> instances?!?
> Matthias
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo + GMF] Diagram and model element handling [message #126094 is a reply to message #126081] |
Thu, 19 June 2008 12:16   |
Hi Matthias,
Okay, how will the user of your software open the editor? Will he/she for example start from a list
of map/diagram combinations and then open the editor? In that case you can take the map and diagram
id from the list and use both id's for the query for the resource which will then result in one
map/diagram combination in the query. Btw, the query you showed below will load more diagram/map
instances in the resource but probably gmf will only use the first one.
Another thing you can try is only query for the diagram object, afaiu the diagram references the
map. Then depending on the load strategy of the resource the map is loaded automatically in the
resource, see here:
http://www.elver.org/hibernate/hibernateresources.html#Load+ of+referenced+Objects
I hope this helps a bit (I don't know that much about GMF...).
gr. Martin
Matthias wrote:
> Hello Martin!
> Thanks for your answer. Sorry ok I understand that my post is/was a bit
> confusing... I am sorry for that.
> You are absoluetely right, why not create the "Map" and the "Diagram"
> within one command or step. Ok this works perfectly, till to the part
> that opens the diagram editor. In your tutorial you do the following:
> "page.openEditor(new URIEditorInput(StoreController.DATABASE_URI),
> MindmapDiagramEditor.ID);" where DATABASE_URI is
> "hbxml://?dsname=mindmap&query1=from Map&query2=from Diagram". But this
> works only when you have one Diagram-Map (for me). If you have more map
> instances than the query selects (for me) the first Diagram-Map and the
> editor shows always the same diagram map regardless which . So I
> thought, putting a where clause to the query would help, but it does not.
> Or do you have each diagram-map in its own resource?!? For me, I have
> one resource in my application and I add each diagram-map to this
> (global) resource.
> Matthias
The Netherlands
Re: [Teneo + GMF] Diagram and model element handling [message #126107 is a reply to message #126094] |
Fri, 20 June 2008 02:25   |
Hi Martin!
Thanks for your answer!
Requirement: The user selecets the Map instance from a list and on
double-click he opens the diagram editor.
Some try-and-error showed me, that it only works when putting a "where"
the Diagram related query part of the query ("&query3=from Diagram where
name = "). But what can/should I query?! The Diagram has no id attribut,
it only has a name attribute. So the only way (AFAIK) to open specific map
diagrams is to build up a reference between the Map and the Diagram that
can be accessed by the where clause in the query: So as described in my
first post I create the Map, save the Map in the resource to get an unique
id of the instance, then create the Diagram and set the name to that
unique Map id. With this approach I can query specific Map and Diagram
combinations ("&query3=from Diagram where name = '[Map-id]'").
Summed up for me it only worked opening specific map diagrams when putting
the where clause to the diagram query part, otherwise he only opens the
first map-diagram. When looking into the opening code of the GMF editor,
than he is only interested in the Diagram object and the search for the
reference "element" object.
So do we have any chance in the current implementation to overcome this
restrictions?!?
Matthias
Martin Taal wrote:
> Hi Matthias,
then result in one
> resource, see here:
> gr. Martin
Re: [Teneo + GMF] Diagram and model element handling [message #126120 is a reply to message #126107] |
Fri, 20 June 2008 06:57   |
Hi Matthias,
Just to be sure, what you would like to achieve is to be able to not-save the diagram before opening
the editor, is that correct?
gr. Martin
Matthias wrote:
> Hi Martin!
> map diagrams is to build up a reference between the Map and the Diagram
> that can be accessed by the where clause in the query: So as described
> in my first post I create the Map, save the Map in the resource to get
> an unique id of the instance, then create the Diagram and set the name
> to that unique Map id. With this approach I can query specific Map and
> Diagram combinations ("&query3=from Diagram where name = '[Map-id]'").
> putting the where clause to the diagram query part, otherwise he only
> opens the first map-diagram. When looking into the opening code of the
> GMF editor, than he is only interested in the Diagram object and the
> search for the reference "element" object.
> restrictions?!?
> Matthias
> Martin Taal wrote:
>> Hi Matthias,
>> can
>> which will
> then result in one
>> will
>> loaded
>> resource, see here:
>> gr. Martin
The Netherlands
Re: [Teneo + GMF] Diagram and model element handling [message #126141 is a reply to message #126130] |
Fri, 20 June 2008 09:18   |
Hi Matthias,
No direct answer but just an idea. You can try to find how the editor finds the resource. Probably
the editor uses a resource set from somewhere (the editingdomain). I am not sure if this possible
but if this resource set exists then before opening the editor you can add the resource to the
resourceset without saving the resource first. Or maybe implement your own editorinput type.
I am guessing here, but if you debug through the code then maybe you can find the correct hooks to
do this.
By setting breakpoints in the load resource and resource.getContents methods you can probably find
the location where the resource is actually loaded.
gr. Martin
Matthias wrote:
> Hi Martin!
> Yes correct. Is this possible?!
> Best regards,
> Matthias
> Martin Taal wrote:
>> Hi Matthias,
>> gr. Martin
The Netherlands
Re: [Teneo + GMF] Diagram and model element handling [message #126298 is a reply to message #126141] |
Wed, 25 June 2008 03:56   |
Hi Martin!
I tried to implement the ideas you suggested but with no luck. The main
problem is that the resource, used in the XXXDiagramEditor code (load()
method), does not find the Map object in the resource, it only finds the
diagram object. But this diagram returns always null when invoking
getElement(). This is not the case if I persist the Map and Diagram into
the resource, before the GMF diagram is opened. I also tried using both
load strategies...
I also tried to use a custom EditorInput that passes the Map and its
resource: I added the map's resource to the resourceSet in the code, then
it finds the Map object but later I get a nasty NullPointerException
(something about Commands problems) which seems to me, that the
TransactionalEditingDomain cannot handle this resource. But my Map object
must be contained in a resource that can be handeled by the
AdapterFactoryEditingDomain, otherwise my other domain model instances do
not "see" the Map.
I spent very much hours solving this problem, but with no success. Maybe
this question is also very GMF related. For me this problem is not only
related to opening diagrams without saving them before, but also to open a
map when you have more than one map instances in you application (as
already discussed in the previous posts).
If someone has code snippets/tutorials or whatever I would be very happy
to solve this issues and to get away from my current implementation!
Matthias
Re: [Teneo + GMF] Diagram and model element handling [message #126359 is a reply to message #126298] |
Wed, 25 June 2008 13:57   |
Hi Matthias,
See comments inline.
gr. Martin
Matthias wrote:
> Hi Martin!
> load strategies...
MT>> I think I lost track... some questions:
- which url did you use to open this resource? Or how did it get into the editor?
- How did you put the map in the diagram (what happens when you do diagram.setElement(..))?
> then it finds the Map object but later I get a nasty
> NullPointerException (something about Commands problems) which seems to
> me, that the TransactionalEditingDomain cannot handle this resource. But
> my Map object must be contained in a resource that can be handeled by
> the AdapterFactoryEditingDomain, otherwise my other domain model
> instances do not "see" the Map.
> a map when you have more than one map instances in you application (as
MT>> If you can zip it up then I can a look at it (will be early next week though).
> Matthias
The Netherlands
Re: [Teneo + GMF] Diagram and model element handling - SOLVED [message #127510 is a reply to message #127391] |
Thu, 24 July 2008 06:47  |
Hi Matthias,
I am happy to hear that it works!
It would be really great if you can send me an email with a description of what you did. I don't use
GMF myself so therefore it is always difficult to have enough detailed information for me.
gr. Martin
Matthias wrote:
> Hi!
> Finally I have an acceptable solution (at least for me) that allows me
> to open a Map + Diagram that have not been persisted to database yet and
> a better handling of Maps and their Diagram when opening the Diagram
> Editor.
> If you want code or further explanation how I have implemented that into
> my project feel free to ask per mail (I am on gmail.com) or whatever.
> Ohh and Martin thank you very much for your input and your offering to
> have a look at my code!!!
> Best regards,
> Matthias
The Netherlands
Re: [Teneo + GMF] Diagram and model element handling [message #619261 is a reply to message #126055] |
Hi Matthias,
in the diagram.
gr. Martin
> the following:
> instance:
> the Diagram.
> instances?!?
> Matthias
The Netherlands
Re: [Teneo + GMF] Diagram and model element handling [message #619262 is a reply to message #126068] |
Thu, 19 June 2008 12:02  |
Hello Martin!
within one command or step. Ok this works perfectly, till to the part that
In your tutorial you do the following: "page.openEditor(new
URIEditorInput(StoreController.DATABASE_URI), MindmapDiagramEditor.ID);"
where DATABASE_URI is "hbxml://?dsname=mindmap&query1=from Map&query2=from
Diagram".
But this works only when you have one Diagram-Map (for me). If you have
more map instances than the query selects (for me) the first Diagram-Map
and the editor shows always the same diagram map regardless which . So I
Or do you have each diagram-map in its own resource?!? For me, I have one
resource in my application and I add each diagram-map to this (global)
resource.
Matthias
Re: [Teneo + GMF] Diagram and model element handling [message #619263 is a reply to message #126081] |
Hi Matthias,
resource, see here:
gr. Martin
Matthias wrote:
> Hello Martin!
> (global) resource.
> Matthias
The Netherlands
Re: [Teneo + GMF] Diagram and model element handling [message #619264 is a reply to message #126094] |
Hi Martin!
restrictions?!?
Matthias
Martin Taal wrote:
> Hi Matthias,
then result in one
> resource, see here:
> gr. Martin
Re: [Teneo + GMF] Diagram and model element handling [message #619265 is a reply to message #126107] |
Hi Matthias,
gr. Martin
Matthias wrote:
> Hi Martin!
> restrictions?!?
> Matthias
> Martin Taal wrote:
>> Hi Matthias,
>> can
>> which will
> then result in one
>> will
>> loaded
>> resource, see here:
>> gr. Martin
The Netherlands
Re: [Teneo + GMF] Diagram and model element handling [message #619267 is a reply to message #126130] |
Hi Matthias,
do this.
gr. Martin
Matthias wrote:
> Hi Martin!
> Best regards,
> Matthias
> Martin Taal wrote:
>> Hi Matthias,
>> gr. Martin
The Netherlands
Re: [Teneo + GMF] Diagram and model element handling [message #619311 is a reply to message #126141] |
Hi Martin!
load strategies...
not "see" the Map.
Matthias
Re: [Teneo + GMF] Diagram and model element handling [message #619324 is a reply to message #126298] |
Hi Matthias,
gr. Martin
Matthias wrote:
> Hi Martin!
> load strategies...
> Matthias
The Netherlands
Re: [Teneo + GMF] Diagram and model element handling - SOLVED [message #620139 is a reply to message #126359] |
Thu, 24 July 2008 05:15  |
Hi!
Finally I have an acceptable solution (at least for me) that allows me to
open a Map + Diagram that have not been persisted to database yet and a
better handling of Maps and their Diagram when opening the Diagram Editor.
Matthias
Re: [Teneo + GMF] Diagram and model element handling - SOLVED [message #620145 is a reply to message #127391] |
Hi Matthias,
gr. Martin
Matthias wrote:
> Hi!
> Editor.
> Best regards,
> Matthias
The Netherlands
Current Time: Sat Jul 19 15:30:04 EDT 2025
Powered by FUDForum. Page generated in 0.29894 seconds
