Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374796] |
Thu, 21 August 2008 04:08  |
Originally posted by: dali.xxxx.com
Hello Everybody,
i'm trying to integrate the bpmn modeler into my RCP plugin project.
my problem is that when i call the bpmn editor from my main class :
page.openEditor(new myeditinput("name"),BpmnEditor.ID,true);
it through a core exception :
org.eclipse.core.runtime.CoreException: ERROR
at
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createPartControl(DiagramDocumentEditor. java:1458)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at
org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2565)
at
ekipbpmodeler.ApplicationWorkbenchAdvisor.postStartup(Applic ationWorkbenchAdvisor.java:25)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2327)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at ekipbpmodeler.Application.start(Application.java:20)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
i read a recent topic that tells that it's possible to integrate it into
RCP.
Please Help,
Best Regards,
Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #374801 is a reply to message #374800] |
Thu, 21 August 2008 11:22   |
Hi Dali,
Test if your project exists and is open
if(myWebProject.exists() && myWebProject.isOpen())
The only reason I see is, that ... yeah, the file doesn't exist.
The methods like getProject, getFolder etc. doesn't test if the
requested resources are present, they only give you a link. The first
"test" of the resource is made when the editor is opened.
Greets
Till
Dali schrieb:
> Hi everybody ,
> i'm still trying to integrate the bpmn modeler into my RCP Plugin project.
> my question is it necessary that the editor input be based on an IFile.
> please help me fixing this bug when i'm calling the editor :
> IWorkspaceRoot myWorkspaceRoot = ResourcesPlugin.getWorkspace().getRoot();
> IProject myWebProject =
> myWorkspaceRoot.getProject("EkipBPModeler");
> IFolder bpmnFolder = myWebProject.getFolder("BpmnFiles");
> IFile file = bpmnFolder.getFile("test.bpmn_diagram");
> FileEditorInput fileEditorInput = new
> FileEditorInput(file);
> IWorkbenchPage page =
> PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
> page.openEditor(fileEditorInput,BpmnEditor.ID,true);
> I obtain this exception :
> !STACK 1
> org.eclipse.core.runtime.CoreException: Resource
> '/EkipBPModeler/BpmnFiles/test.bpmn_diagram' does not exist.
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil.load(DiagramIOUtil.java:219)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil.load(DiagramIOUtil.java:145)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDiagramDocumentProvider.setDocumentContentFromStora ge(FileDiagramDocumentProvider.java:154)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.StorageDocumentProvider.setDocumentContent(StorageDocum entProvider.java:152)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDiagramDocumentProvider.setDocumentContent(FileDiag ramDocumentProvider.java:273)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.StorageDocumentProvider.createDocument(StorageDocumentP rovider.java:76)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDocumentProvider.createElementInfo(FileDocumentProv ider.java:476)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .AbstractDocumentProvider.connect(AbstractDocumentProvider.j ava:387)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.doSetInput(DiagramDocumentEditor.java:42 6)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.setInput(DiagramDocumentEditor.java:389)
> at
> org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:318)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.init( DiagramEditor.java:638)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.init(DiagramDocumentEditor.java:116)
> at
> org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
> at
> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ekipbpmodeler.ApplicationWorkbenchAdvisor.postStartup(Applic ationWorkbenchAdvisor.java:44)
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.runtime.CoreException[1]:
> org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Resource
> at
> org.eclipse.emf.ecore.resource.impl.URIConverterImpl$Workben chHelper.createPlatformResourceInputStream(URIConverterImpl. java:199)
> at
> org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createP latformResourceInputStream(URIConverterImpl.java:540)
> at
> org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:449)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:897)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil$FileLoader.load(DiagramIOUtil.java:83)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .util.DiagramIOUtil.load(DiagramIOUtil.java:160)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: org.eclipse.core.internal.resources.ResourceException:
> Resource '/EkipBPModeler/BpmnFiles/test.bpmn_diagram' does not exist.
> at
> org.eclipse.core.internal.resources.Resource.checkExists(Res ource.java:310)
> at
> org.eclipse.core.internal.resources.Resource.checkAccessible (Resource.java:193)
> at org.eclipse.core.internal.resources.File.getContents(File.ja va:285)
> at org.eclipse.core.internal.resources.File.getContents(File.ja va:276)
> at
> org.eclipse.emf.ecore.resource.impl.URIConverterImpl$Workben chHelper.createPlatformResourceInputStream(URIConverterImpl. java:195)
> ... 68 more
> !SUBENTRY 1 org.eclipse.gmf.runtime.diagram.ui.resources.editor 4 1
> 2008-08-21 16:52:49.642
> !MESSAGE Resource '/EkipBPModeler/BpmnFiles/test.bpmn_diagram' does not
> exist.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> !ENTRY org.eclipse.ui 4 0 2008-08-21 16:52:49.658
> !MESSAGE org.eclipse.gef.DefaultEditDomain
> !STACK 0
> java.lang.ClassCastException: org.eclipse.gef.DefaultEditDomain
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.getDi agramEditDomain(DiagramEditor.java:576)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.getAc tionManager(DiagramEditor.java:1027)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.getOp erationHistory(DiagramEditor.java:1050)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.stopL istening(DiagramEditor.java:997)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFl yOutPalette.stopListening(DiagramEditorWithFlyOutPalette.jav a:585)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.setIn put(DiagramEditor.java:914)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.dispose(DiagramDocumentEditor.java:179)
> at
> org.eclipse.stp.bpmn.diagram.part.BpmnDiagramEditor.dispose( BpmnDiagramEditor.java:149)
> at
> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:689)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Unable to create editor ID ekipbpmodeler.BpmnEditor: An
> exception was thrown during initialization
> !STACK 0
> at
> org.eclipse.emf.transaction.util.TransactionUtil.getEditingD omain(TransactionUtil.java:50)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .DiagramModificationListener. <init>(DiagramModificationListener.java:55)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDiagramModificationListener. <init>(FileDiagramModificationListener.java:54)
> at
> org.eclipse.stp.bpmn.diagram.part.BpmnDocumentProvider$Custo mModificationListener. <init>(BpmnDocumentProvider.java:164)
> at
> org.eclipse.stp.bpmn.diagram.part.BpmnDocumentProvider.creat eFileInfo(BpmnDocumentProvider.java:114)
> at
> org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide.docu ment.FileDocumentProvider.createElementInfo(FileDocumentProv ider.java:486)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanx for help,
> Best regards ,
> Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618482 is a reply to message #374796] |
Thu, 21 August 2008 05:34  |
Hi Dali,
It is possible to integrate it into a RCP application. I'm doing it
right now right here ;)
Would be nice to know what kind of Input you pass to the openEditor
method. I had a bug with the editor not opening when I try to open a
diagram which wasn't in a project in the workspace.
Greets
Dali schrieb:
> Hello Everybody,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> RCP.
> Please Help,
> Best Regards,
> Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618493 is a reply to message #374799] |
Thu, 21 August 2008 10:53  |
Hi everybody ,
FileEditorInput fileEditorInput = new FileEditorInput(file);
!STACK 1
at
at
at
at
at
at
at
at
at
at
at org.eclipse.gef.ui.parts.GraphicalEditor.init(GraphicalEdito r.java:318)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: org.eclipse.core.internal.resources.ResourceException: Resource
at
at
at
... 68 more
exist.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!MESSAGE Unable to create editor ID ekipbpmodeler.BpmnEditor: An exception
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Thanx for help,
Best regards ,
Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618496 is a reply to message #374800] |
Hi Dali,
Greets
Till
Dali schrieb:
> Hi everybody ,
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> exist.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanx for help,
> Best regards ,
> Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618507 is a reply to message #374804] |
Fri, 22 August 2008 05:09  |
Hi Dali,
I don't know how you created your project inside the workbench, but try
to create a new from sourcecode:
myWebProject.create(null);
myWebProject.open(null);
Greets,
Till
Dali schrieb:
> Hi till,
> yeah the myWebProject.exists() return false .
> why the workbench is can not localise it.
> how can i debug this.
> Best Regards ,
> Dali
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618511 is a reply to message #374805] |
Fri, 22 August 2008 05:24  |
Hi till ,
i create the project from
file->newProject->PluginDevelopment->Pluginproject.
i tryed to create it from code but it still through me this exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
ekipbpmodeler.ApplicationWorkbenchAdvisor.postStartup(Applic ationWorkbenchAdvisor.java:56)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
2008-08-22 11:17:38.074
exist.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 68 more
!ENTRY org.eclipse.ui 4 0 2008-08-22 11:17:38.105
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 2008-08-22 11:17:58.185
!MESSAGE The proxied handler for
'org.eclipse.gmf.runtime.diagram.ui.actions.internal.Duplica teActionDelegate'
could not be loaded
!ENTRY org.eclipse.ui 4 0 2008-08-22 11:17:58.185
could not be loaded
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.gmf.runtime.diagram.ui was unable to load class
org.eclipse.gmf.runtime.diagram.ui.actions.internal.Duplicat eActionDelegate.
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(Ha ndlerProxy.java:293)
at
org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(Hand lerProxy.java:262)
at org.eclipse.core.commands.Command.isEnabled(Command.java:831 )
at org.eclipse.core.commands.Command.setHandler(Command.java:93 8)
at
org.eclipse.ui.internal.handlers.HandlerAuthority.updateComm and(HandlerAuthority.java:535)
at
org.eclipse.ui.internal.handlers.HandlerAuthority.deactivate Handler(HandlerAuthority.java:256)
at
org.eclipse.ui.internal.handlers.HandlerService.deactivateHa ndler(HandlerService.java:144)
at
org.eclipse.ui.internal.handlers.HandlerService.deactivateHa ndlers(HandlerService.java:153)
at
org.eclipse.ui.internal.handlers.HandlerPersistence.clearAct ivations(HandlerPersistence.java:101)
at
org.eclipse.ui.internal.handlers.HandlerPersistence.dispose( HandlerPersistence.java:107)
at
org.eclipse.ui.internal.handlers.HandlerService.dispose(Hand lerService.java:159)
at
org.eclipse.ui.internal.services.ServiceLocator.dispose(Serv iceLocator.java:95)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:27 30)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:9 17)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:8 34)
at org.eclipse.ui.internal.Workbench$22.run(Workbench.java:1078 )
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1076)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1048)
at
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:696)
at
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:675)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:790)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:788)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:736)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:68 2)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:91)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:301)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1621)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3674 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:291)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1554)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:1753)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4351 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2260 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:456)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3760 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at
at
at
at
at
at
at
java.lang.ClassNotFoundException:
at java.lang.ClassLoader.findClass(Unknown Source)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:429)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2008-08-22 11:17:58.185
!MESSAGE Plug-in org.eclipse.gmf.runtime.diagram.ui was unable to load
class
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Best Regards,
Dali.
Re: Problems integrating the bpmn modelerinto my RCP Plugin Project [message #618517 is a reply to message #374806] |
Fri, 22 August 2008 10:59  |
1. Step: Look into your run dialog where your workspace is.
2. Step: Check if your project/folder/file is located in there.
2.1 : If not, create a project from source code (to be sure it IS there)
2.2 : Move the diagram file into the project and try opening it.
What you discover is not a problem with the modeler itself, but your
runtime ;)
Greets
Till
Dali schrieb:
> Hi till ,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> exist.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 68 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> could not be loaded
> could not be loaded
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> class
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.08466 seconds
