Home » Archived » Visual Editor (VE) » How to contribute a IDE project to Eclipse(How to contribute a IDE project to Eclipse)
How to contribute a IDE project to Eclipse [message #505375] Tue, 29 December 2009 18:22 Go to next message
We have a IDE (SwixEditor) for visually laying out swing forms persisted in XML. This project is based on EMF / GEF. This tool is used by several enterprises and individuals.
We want to opensource this project and contribute it as an IDE project similar to VE. Whats the process of doing so. Please advise. You can also send me an email at sanjeevk [AT] invivosoft [DOT] com.
More information on this product can be accessed from http://www.invivosoft.com/swixeditor
Best regards
Sanjeev Kumar
Invivo Software.
Re: How to contribute a IDE project to Eclipse [message #505460 is a reply to message #505375] Wed, 30 December 2009 19:24 Go to previous messageGo to next message
Hi Sanjeev,
Thanks for this offer. Please allow me to ask you some questions:
1. What's the syntax or grammar of XML?
2. What are the benifices for Eclipse community?
3. Is the XML langauge is Open source, if so could you indicate its
license
The declarative UI is definitively our new direction to go. I just need to
know if it makes sense and how integrate them together.
Best regards
Yves YANG
"Sanjeev" <sanjeevk@invivosoft.com> wrote in message
news:hhekfk$qbg$1@build.eclipse.org...
> Best regards
> Sanjeev Kumar
> Invivo Software.
Re: How to contribute a IDE project to Eclipse [message #505797 is a reply to message #505460] Tue, 05 January 2010 00:05 Go to previous messageGo to next message
Hi Yves,
Thanks for the reply.
You asked
The XML is based on swixml, an open source engine for representing Swing UI in xml (www.swixml.org).
However, the SwixEditor is independent of the underlying XML schema. It can support any XML schema. Supporting a custom schema is as simple as adding required annotations to the schema and generating the EMF model code.
>>2. Benefits to Eclipse community
a. Declarative UI persistance for any XML schema definition.
b. Robust implementation of Jigloo FormLayout layout manager (in addition to other layout managers)
c. A complex reference implementation of WYSIWYG editor using GEF/EMF platforms.
d. Advance concepts such as visual inheritance using EObject model.
e. Our customers found this equivalant and better than Microsoft XAML editor.
>>Is XML open source...license details
Out of box, SwixEditor supports swixml (http://www.swixml.org) an open source engine for representing swing UI. SwiXml is available under an Apache-style open source license.
However, as I mentioned earlier, swixeditor is designed to support any xml schema representation.
Please let me know if you need any further information.
Sanjeev Kumar
Re: How to contribute a IDE project to Eclipse [message #506075 is a reply to message #505797] Tue, 05 January 2010 20:34 Go to previous messageGo to next message
Could you look at the XWT Designer, which is incubated in e4? It seems your
editor is much close to this one.
> editor.
I suppose you mean XAML pad, which is in fact a XML text editor, or
Expression Blend, which is much rich and powerful commercial tools?
Best regards
Yves YANG
news:hhuhb4$1m2$1@build.eclipse.org...
> Hi Yves,
> Thanks for the reply. You asked
> code.
> platforms.
> editor.
> Thanks
> Sanjeev Kumar
Re: How to contribute a IDE project to Eclipse [message #506090 is a reply to message #506075] Tue, 05 January 2010 23:35 Go to previous messageGo to next message
Hi Yves,
Yes SwixEditor has same features as XWT Designer.
SwixEditor is however independent of the underlying XML schema. It can be extended to support XWT and other XML schemas as well as Swing and SWT engines.
Sanjeev
Re: How to contribute a IDE project to Eclipse [message #506555 is a reply to message #506090] Thu, 07 January 2010 18:32 Go to previous message
FYI, XWT Designer is already extended to support e4 workbench.
Yves YANG
news:hi13v8$7e0$1@build.eclipse.org...
> Hi Yves,
> engines.
> Thanks
> Sanjeev
Re: How to contribute a IDE project to Eclipse [message #617603 is a reply to message #505460] Tue, 05 January 2010 00:05 Go to previous message
Hi Yves,
You asked
Sanjeev Kumar
Re: How to contribute a IDE project to Eclipse [message #618348 is a reply to message #617603] Tue, 05 January 2010 20:34 Go to previous message
> editor.
Best regards
Yves YANG
> Hi Yves,
> code.
> platforms.
> editor.
> Thanks
> Sanjeev Kumar
Re: How to contribute a IDE project to Eclipse [message #618349 is a reply to message #506075] Tue, 05 January 2010 23:35 Go to previous message
Hi Yves,
Sanjeev
Re: How to contribute a IDE project to Eclipse [message #618351 is a reply to message #618349] Thu, 07 January 2010 18:32 Go to previous message
Yves YANG
> Hi Yves,
> engines.
> Thanks
> Sanjeev
Previous Topic:Visual editor a CDT
Next Topic:Remote VM JRE window
Current Time: Sun Jul 20 12:39:44 EDT 2025
Powered by FUDForum. Page generated in 0.06119 seconds
