Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare]MatchEngine NPE bug
[EMF Compare]MatchEngine NPE bug [message #121761] Fri, 02 May 2008 11:41 Go to next message
It seems there is a bug in the GenericMatchEngine.hasSameUri() code:
if one of the EObject returns an empty eResource() (which happens for some
objects in my model), it throws a NPE. I suggest the following fix below.
David
* Checks wether the two given {@link EObject} have the same URI.
* @param obj1
* First of the two {@link EObject} we're comparing.
* @param obj2
* Second {@link EObject} we're comparing.
* @return <code>True</code> if the {@link EObject}s have the same URI,
<code>False</code> otherwise.
private boolean hasSameUri(EObject obj1, EObject obj2) {
if ( obj1.eResource() == obj2.eResource() ) // null==null returns true
return true;
if ( obj1.eResource() == null || obj2.eResource() == null ) // if one of
them is null and not the other return false
return false;
return
obj1.eResource().getURIFragment(obj1).equals(obj2.eResource( ).getURIFragment(obj2));
Re: [EMF Compare]MatchEngine NPE bug [message #121789 is a reply to message #121761] Fri, 02 May 2008 11:57 Go to previous messageGo to next message
Guys,
Just a suggestion. Calling eResource can potentially be quite
expensive, since you have to traverse all the way to the root, so I'd
suggest calling it once and using the returned value multiple times.
David Michonneau wrote:
> David
> * @param obj1
> * @param obj2
> return true;
> return false;
> return
Re: [EMF Compare]MatchEngine NPE bug [message #122141 is a reply to message #121761] Wed, 07 May 2008 04:57 Go to previous message
Hi David,
Thanks (again ;) ) for your feedback, we'll apply the fix ASAP.
Cédric
> David
> * @param obj1
> * @param obj2
> return true;
> return false;
> return
Re: [EMF Compare]MatchEngine NPE bug [message #617987 is a reply to message #121761] Fri, 02 May 2008 11:57 Go to previous message
Guys,
> David
> * @param obj1
> * @param obj2
> return true;
> return false;
> return
Re: [EMF Compare]MatchEngine NPE bug [message #618014 is a reply to message #121761] Wed, 07 May 2008 04:57 Go to previous message
Hi David,
Cédric
> David
> * @param obj1
> * @param obj2
> return true;
> return false;
> return
Previous Topic:Graphical XML Schema Editor for 3.3.2?
Next Topic:[CDO 0.8.0] Transaction/Objects scope
Current Time: Sat Jul 19 14:29:35 EDT 2025
Powered by FUDForum. Page generated in 0.03951 seconds
