Home » Modeling » Modeling (top-level project) » Help: Advice on GUI Designer to choose?
Help: Advice on GUI Designer to choose? [message #478806] |
Thu, 06 August 2009 22:10  |
I am starting the development of a database program using Java and Eclipse (Galileo). Having just started with Eclipse, I don't know what is available and useful as a GUI design plug in. Any suggestion?
Its probably best that the tool be free, ...and I don't want to develop any tools or plug-ins for Eclipse, I want to use one that has already been developed.
Re: Help: Advice on GUI Designer to choose? [message #478946 is a reply to message #478936] |
Fri, 07 August 2009 11:28   |
--------------080208050205040802080505
Lou,
It really depends on what type of application you're trying to build.
Things like the Visual Editor Project or the Web Tools Project might be
useful. Also, you might well have a model for your data, e.g,. a schema
and could generate a complete application from that:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html
LouArnold wrote:
> Haha, OK. Wrong forum. Thanks for helping, anyway. I guess we'll see
> about the RAP project later.
> I just wanted to ask what to start the prototype with SWT or Swing to
> make migration easier. Perhaps if you can direct me to the proper
> forum, I'll ask there.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Lou,<br>
<br>
schema and could generate a complete application from that:<br>
<blockquote><a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html"> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html</a><br>
</blockquote>
<br>
LouArnold wrote:
<blockquote cite="mid:h5hfnq$5cm$1@build.eclipse.org" type="cite">Haha,
OK. Wrong forum. Thanks for helping, anyway. I guess we'll see about
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------080208050205040802080505--
Re: Help: Advice on GUI Designer to choose? [message #496793 is a reply to message #479159] |
Wed, 11 November 2009 06:38  |
Soyatec has published the first version of XWT Designer for technical
preview, and has decided to contribute it in eclipse. The integration of
this GUI Design in e4 is on going. If everything goes well, it will be in e4
1.0M3.
Definitively, PMF addresses the Modeling UI in large terms (not only UI ,
but also data binding and scenario),
So, keep turn.
Best regards
Yves YANG
"Krzysztof Kowalczyk" <kowalczyk.krzysztof@gmail.com> wrote in message
news:h5nhrf$s68$1@build.eclipse.org...
>> Netbeans means Swing and Matisse which may or may not be better.
> I mentioned Netbeans, as in database application one can use Swing
> Application Framework https://appframework.dev.java.net/ and JPA and
> Netbeans generate and handle such things well out of the box. In Eclipse
> it would take much effort to gather proper knowledge about beans binding,
> SWT, JFace, JPA and find good plugins to support that.
>> SWT is cool (and better IMHO) though it is changing in e4 so who knows.
>> They
>> are going declarative and CSS and Javascript and such things.
> It is not "changing", it is "growing". e4 allows for deklarative SWT (XWT)
> and for styling controls with CSS. But you don't have to use it! The old
> way works like always did.
> I am (not yet ;) ) fun of XWT / XAML, but declarative UI has strong
> advantages in many use cases IMO.
> Regards,
> Krzysztof Kowalczyk
Re: Help: Advice on GUI Designer to choose? [message #617747 is a reply to message #478908] |
Fri, 07 August 2009 10:31  |
I'm a bit confused by your response. I don't want to develop graphical editors. I want to use one that is already developed.
Did I ask in the wrong forum?
Is SWT appropriate if I move the project on to become a web application with jFaces, servlets and Tomcat?
Re: Help: Advice on GUI Designer to choose? [message #617748 is a reply to message #617747] |
Fri, 07 August 2009 10:44  |
Lou,
Comments below.
> editors.
Then you won't be interested in GMF. :-P
Like VE.
Yes, I think so. :-P
Things like the RAP project support web access to an SWT-based
application. The Eclipse 4.0 (e4) work is also targeting the web...
Re: Help: Advice on GUI Designer to choose? [message #617749 is a reply to message #478935] |
Fri, 07 August 2009 11:03  |
Haha, OK. Wrong forum. Thanks for helping, anyway. I guess we'll see about the RAP project later.
I just wanted to ask what to start the prototype with SWT or Swing to make migration easier. Perhaps if you can direct me to the proper forum, I'll ask there.
Re: Help: Advice on GUI Designer to choose? [message #617750 is a reply to message #617749] |
Lou,
<html>
<head>
</head>
Lou,<br>
<br>
<blockquote><a
</blockquote>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
Re: Help: Advice on GUI Designer to choose? [message #617752 is a reply to message #478949] |
Fri, 07 August 2009 11:58  |
Krzysztof Kowalczyk wrote on Fri, 07 August 2009 11:48
> You are not sure what technology you want to use, but want to create a
> prototype? Sound like a case for http://www.eclipse.org/pmf/ But it is
> "not there yet" and I don't think that you want it, but still it is
> "modelling" newsgroup ;)
> You can try to install http://www.eclipse.org/vep/
> (http://wiki.eclipse.org/VE/Update) it support SWT and Swing.
> VE news group: eclipse.tools.ve
> Most likely you will have some problems (installation or usage), so you
> would like to check commercials tools (both support SWT and Swing, there
> are some free non-commercial versions):
> http://www.instantiations.com/windowbuilder/
> or http://www.cloudgarden.com/jigloo/
> Actually if you are not sure what to use, probably
> http://www.netbeans.org/kb/docs/java/gui-db.html fit your needs best.
> Regards,
> Krzysztof Kowalczyk
I think this answered it. I will try VE, but if things get sticky then, perhaps Netbeans is better.
Thanks very much.
Re: Help: Advice on GUI Designer to choose? [message #617754 is a reply to message #617752] |
Sun, 09 August 2009 00:14  |
Netbeans means Swing and Matisse which may or may not be better. SWT is
cool (and better IMHO) though it is changing in e4 so who knows. They
If you stay with SWT, forget VE, buy SWT Designer from instantiations.com.
My opinion.
Re: Help: Advice on GUI Designer to choose? [message #617757 is a reply to message #479094] |
Sun, 09 August 2009 18:16  |
binding, SWT, JFace, JPA and find good plugins to support that.
> SWT is cool (and better IMHO) though it is changing in e4 so who knows. They
(XWT) and for styling controls with CSS. But you don't have to use it!
The old way works like always did.
Krzysztof Kowalczyk
Re: Help: Advice on GUI Designer to choose? [message #618458 is a reply to message #479159] |
1.0M3.
So, keep turn.
Best regards
Yves YANG
>> They
> Regards,
> Krzysztof Kowalczyk
Current Time: Sat Jul 19 06:00:06 EDT 2025
Powered by FUDForum. Page generated in 0.08219 seconds
