Home » Archived » GMT (Generative Modeling Technologies) » [Epsilon] Problem with ECL
[Epsilon] Problem with ECL [message #383080] Tue, 13 May 2008 14:17 Go to next message
Originally posted by: ste_barr.cs.concordia.ca
I'm trying to use ECL to help with some model merging. Unfortunately I'm
stuck.
My left model consits of a single class A, and the right a single class B.
I'm using the follow code (class.ecl) to compare them and print out the
match trace:
rule ClassA
match l : Left!Class with r : Right!Class {
compare : l.name = 'A' }
rule ClassB
compare : l.name = 'B' }
post {
-- Print name of matching elements and of the rule that matched them.
for (m in matchTrace.matches.select(m|m.isMatching)) {
(m.left.name + ' <' + m.getRule().name + '> ' +
m.right.name).println();
I think that the four element pairings should cause each rule to fire
once, so the output is a surprise to me:
A <ClassA> A
A <ClassA> B
Where are the B to A, B to B pairings? Why did rule ClassA match A with B?
And why does the second rule never fire?
I can't help put think that I'm missing something really basic here, but I
have spent a bit of time trying to unravel this. Thanks for taking a look.
--Steve
P.S. I couldn't get "m.rules.first().name" as given in the Complete OO to
DB comparison to work, which is why I'm using "m.getRule().name" Could
this be a source of trouble?
Re: [Epsilon] Problem with ECL [message #383081 is a reply to message #383080] Tue, 13 May 2008 14:39 Go to previous messageGo to next message
Hi Steve,
I can't reproduce this. For a Left model that contains only one Class A
and a Right model that contains only one Class B I get the following result:
A <ClassA> B
which is correct. There is only one pair to be compared (why did you
expect 4?), and when the ClassA rule is executed it returns true and so
A and B are recorded as matching.
I suspect that both of your two models have 2 classes (A and B) each.
That would explain the result: the 4 pairs first pass from rule ClassA
which characterizes the A<->A and A<->B pairs as matching, and the B<->A
and B<->B pairs as non-matching (your clause is l.name = 'A') and as a
result, since at that point the engine has decided about all pairs, rule
ClassB is not needed and thus is not executed.
Dimitrios
Steve Barrett wrote:
> Hello,
> stuck.
> B. I'm using the follow code (class.ecl) to compare them and print out
> the match trace:
> rule ClassA
> rule ClassB
> post {
> (m.left.name + ' <' + m.getRule().name + '> ' + m.right.name).println();
> A <ClassA> A
> A <ClassA> B
> B? And why does the second rule never fire?
> I have spent a bit of time trying to unravel this. Thanks for taking a
> look.
> --Steve
> to DB comparison to work, which is why I'm using "m.getRule().name"
> Could this be a source of trouble?
Re: [Epsilon] Problem with ECL [message #383082 is a reply to message #383081] Tue, 13 May 2008 15:23 Go to previous messageGo to next message
I knew it was simple!
You are right I do have an A and a B in both models (I've been staring at
it too long...). Your explanation of the second rule not needing to be
invoked makes total sense. Thank you.
--Steve
Re: [Epsilon] Problem with ECL [message #383083 is a reply to message #383082] Tue, 13 May 2008 15:36 Go to previous messageGo to next message
Glad it helped :)
Since you are going to use EML for merging next, you may be interested
to know that from version 1.3.3 you can right-click your ECore metamodel
and generate the default EML and ETL source code (that merge models of
that metamodel) automatically.
Dimitrios
> at it too long...). Your explanation of the second rule not needing to
> be invoked makes total sense. Thank you.
> --Steve
Re: [Epsilon] Problem with ECL [message #383084 is a reply to message #383083] Tue, 13 May 2008 21:58 Go to previous messageGo to next message
I'm playing with EML now Dimitrios. Something doesn't seem right however.
When I try to merge the MergeOO example only the <Models> rule matches,
and the resulting Merged.model is simply a union of *all* the elements in
both models. I end up with duplicate School and Teacher classes, and
String Datatypes.
I was expecting something more like I see explained in the example at
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.gmt /epsilon/org.epsilon.eclipse.help/index.html
For reference I've pasted in the text view of the output model:
<?xml version="1.0" encoding="ASCII"?>
<OO:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:OO="OO"
xmi:id="_O6fjQCFYEd2zH6RpYvdvlA" name="educational">
<contents xsi:type="OO:Class" xmi:id="_O6gKUCFYEd2zH6RpYvdvlA"
name="Student" isAbstract="false">
<features xsi:type="OO:Reference" xmi:id="_O6gxYCFYEd2zH6RpYvdvlA"
name="supervisor" type="_O6hYcCFYEd2zH6RpYvdvlA" isMany="false"/>
</contents>
<contents xsi:type="OO:Class" xmi:id="_O6m4ACFYEd2zH6RpYvdvlA"
name="School" isAbstract="false">
<features xsi:type="OO:Attribute" xmi:id="_O6m4ASFYEd2zH6RpYvdvlA"
name="address" type="_O6nfECFYEd2zH6RpYvdvlA" isMany="false"/>
<features xsi:type="OO:Attribute" xmi:id="_O6xQECFYEd2zH6RpYvdvlA"
name="acceptsPostcodes" type="_O6nfECFYEd2zH6RpYvdvlA" isMany="true"/>
<features xsi:type="OO:Reference" xmi:id="_O6x3ICFYEd2zH6RpYvdvlA"
name="employees" type="_O6yeMCFYEd2zH6RpYvdvlA" isMany="true"/>
</contents>
<contents xsi:type="OO:Class" xmi:id="_O6lC0CFYEd2zH6RpYvdvlA"
name="Module" isAbstract="false">
<features xsi:type="OO:Attribute" xmi:id="_O6lC0SFYEd2zH6RpYvdvlA"
name="subject" type="_O6lp4CFYEd2zH6RpYvdvlA" isMany="false"/>
</contents>
<contents xsi:type="OO:Class" xmi:id="_O606cCFYEd2zH6RpYvdvlA"
name="Support" extends="_O6yeMCFYEd2zH6RpYvdvlA" isAbstract="false">
<features xsi:type="OO:Attribute" xmi:id="_O606cSFYEd2zH6RpYvdvlA"
name="role" type="_O6nfECFYEd2zH6RpYvdvlA" isMany="false"/>
</contents>
<contents xsi:type="OO:Datatype" xmi:id="_O62IkSFYEd2zH6RpYvdvlA"
name="Real"/>
<contents xsi:type="OO:Datatype" xmi:id="_O6nfECFYEd2zH6RpYvdvlA"
name="String"/>
<contents xsi:type="OO:Class" xmi:id="_O6zFQCFYEd2zH6RpYvdvlA"
name="Person" extendedBy="_O6yeMCFYEd2zH6RpYvdvlA" isAbstract="true">
<features xsi:type="OO:Attribute" xmi:id="_O6zsUCFYEd2zH6RpYvdvlA"
name="details" type="_O6nfECFYEd2zH6RpYvdvlA" isMany="false"/>
</contents>
<contents xsi:type="OO:Datatype" xmi:id="_O64k0CFYEd2zH6RpYvdvlA"
name="Boolean"/>
<contents xsi:type="OO:Class" xmi:id="_O6imkCFYEd2zH6RpYvdvlA"
name="Class" isAbstract="false">
<features xsi:type="OO:Attribute" xmi:id="_O6imkSFYEd2zH6RpYvdvlA"
name="grade" type="_O6jNoCFYEd2zH6RpYvdvlA" isMany="false"/>
<features xsi:type="OO:Reference" xmi:id="_O6j0sCFYEd2zH6RpYvdvlA"
name="students" type="_O6gKUCFYEd2zH6RpYvdvlA" isMany="true"/>
<features xsi:type="OO:Reference" xmi:id="_O6kbwCFYEd2zH6RpYvdvlA"
name="modules" type="_O6lC0CFYEd2zH6RpYvdvlA" isMany="true"/>
</contents>
<contents xsi:type="OO:Class" xmi:id="_O6yeMCFYEd2zH6RpYvdvlA"
name="Employee" extends="_O6zFQCFYEd2zH6RpYvdvlA"
extendedBy="_O60TYCFYEd2zH6RpYvdvlA _O606cCFYEd2zH6RpYvdvlA"
isAbstract="true">
<features xsi:type="OO:Attribute" xmi:id="_O62IkCFYEd2zH6RpYvdvlA"
name="salary" type="_O62IkSFYEd2zH6RpYvdvlA" isMany="false"/>
<features xsi:type="OO:Reference" xmi:id="_O62voCFYEd2zH6RpYvdvlA"
name="manager" type="_O6yeMCFYEd2zH6RpYvdvlA" isMany="false"/>
</contents>
<contents xsi:type="OO:Class" xmi:id="_O60TYCFYEd2zH6RpYvdvlA"
name="Teacher" extends="_O6yeMCFYEd2zH6RpYvdvlA" isAbstract="false"/>
<contents xsi:type="OO:Datatype" xmi:id="_O6lp4CFYEd2zH6RpYvdvlA"
name="String"/>
<contents xsi:type="OO:Class" xmi:id="_O6hYcCFYEd2zH6RpYvdvlA"
name="Teacher" isAbstract="false">
<features xsi:type="OO:Reference" xmi:id="_O6h_gCFYEd2zH6RpYvdvlA"
name="teaches" type="_O6imkCFYEd2zH6RpYvdvlA" isMany="true"/>
</contents>
<contents xsi:type="OO:Datatype" xmi:id="_O6jNoCFYEd2zH6RpYvdvlA"
name="Integer"/>
<contents xsi:type="OO:Class" xmi:id="_O65L4CFYEd2zH6RpYvdvlA"
<features xsi:type="OO:Reference" xmi:id="_O65y8CFYEd2zH6RpYvdvlA"
name="classes" type="_O6imkCFYEd2zH6RpYvdvlA" isMany="true"/>
<features xsi:type="OO:Reference" xmi:id="_O66aACFYEd2zH6RpYvdvlA"
name="principal" type="_O6hYcCFYEd2zH6RpYvdvlA" isMany="false"/>
</contents>
</OO:Model>
Re: [Epsilon] Problem with ECL [message #383085 is a reply to message #383084] Wed, 14 May 2008 01:48 Go to previous messageGo to next message
Hi Steve,
Oops... The example on the EML documentation page is based on an old
version of the language. I'll update it asap. Until then, you can check
out the updated/working "Merging two Object Oriented Models" example
from http://www.eclipse.org/gmt/epsilon/doc/examples.php.
Dimitrios
> however. When I try to merge the MergeOO example only the <Models> rule
> matches, and the resulting Merged.model is simply a union of *all* the
> elements in both models. I end up with duplicate School and Teacher
> classes, and String Datatypes.
> </contents>
> </contents>
> </contents>
> </contents>
> name="Real"/>
> name="String"/>
> </contents>
> name="Boolean"/>
> </contents>
> isAbstract="true">
> </contents>
> name="String"/>
> </contents>
> name="Integer"/>
> </contents>
> </OO:Model>
Re: [Epsilon] Problem with ECL [message #383593 is a reply to message #383085] Wed, 14 May 2008 03:55 Go to previous message
Opps. How embarassing :-)
I managed to fix the problem by changing "Classifier" to "Class." Magic.
I'm quite impressed.
--Steve
Re: [Epsilon] Problem with ECL [message #617621 is a reply to message #383080] Tue, 13 May 2008 14:39 Go to previous message
Hi Steve,
A <ClassA> B
Dimitrios
> Hello,
> stuck.
> the match trace:
> rule ClassA
> rule ClassB
> post {
> A <ClassA> A
> A <ClassA> B
> look.
> --Steve
Re: [Epsilon] Problem with ECL [message #617624 is a reply to message #383081] Tue, 13 May 2008 15:23 Go to previous message
--Steve
Re: [Epsilon] Problem with ECL [message #617625 is a reply to message #383082] Tue, 13 May 2008 15:36 Go to previous message
Glad it helped :)
Dimitrios
> --Steve
Re: [Epsilon] Problem with ECL [message #617626 is a reply to message #383083] Tue, 13 May 2008 21:58 Go to previous message
String Datatypes.
</contents>
</contents>
</contents>
</contents>
name="Real"/>
name="String"/>
</contents>
name="Boolean"/>
</contents>
isAbstract="true">
</contents>
name="String"/>
</contents>
name="Integer"/>
</contents>
</OO:Model>
Re: [Epsilon] Problem with ECL [message #617629 is a reply to message #383084] Wed, 14 May 2008 01:48 Go to previous message
Hi Steve,
Dimitrios
> </contents>
> </contents>
> </contents>
> </contents>
> name="Real"/>
> name="String"/>
> </contents>
> name="Boolean"/>
> </contents>
> isAbstract="true">
> </contents>
> name="String"/>
> </contents>
> name="Integer"/>
> </contents>
> </OO:Model>
Re: [Epsilon] Problem with ECL [message #617630 is a reply to message #383085] Wed, 14 May 2008 03:55 Go to previous message
--Steve
Previous Topic:[Epsilon] Problem with ECL
Next Topic:[Epsilon] String wrapping under -> and .
Current Time: Sun Jul 20 10:11:57 EDT 2025
Powered by FUDForum. Page generated in 0.26994 seconds
