Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Net4j]
[Net4j] [message #616250] Sun, 13 April 2008 10:34
Hi Eike,
after trying around with the echo example (which helps me a lot) many new
questions comming up to me.
I found some documentation on http://net4j.berlios.de/ Is this
documentation still valid? Especially that Net4J runs in a Merlin
Container? I could not found a referenced third party jar.
The EchoServer is based on the TCP Plugin. Which services does the TCP
Plugin provides here.
My planned server should work with a protocoll designed like echo Protocoll.
So I could do it like in the example. On the other side I have two older
legacy protocolls I would like to serve. These clients are implemented in
Perl and in C.
So I think I have to implement these protocolls on a lower level in Net4J
than the echo protocoll. Is it possible to mix these different behavior at
the same time in one server?
Thank you in advance
Torsten Link
Previous Topic:The Hibernate resource query does not work in the latest TENEO build
Next Topic:Re: Eclipse 3.4/emf 2.4
Current Time: Sat Jul 19 15:10:17 EDT 2025
Powered by FUDForum. Page generated in 0.04304 seconds
