Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Compare] Problem with getting RemoteRemoveModelElement vs. RemoteAddModelElement with 3 way compare
[Compare] Problem with getting RemoteRemoveModelElement vs. RemoteAddModelElement with 3 way compare [message #616163] Wed, 09 April 2008 16:40
I'm doing a 3 way headless comparison (match+diff). In my test, the
ancestor has no children, the "left" model has a new child and the
"right" model has a new (also different) child. These two new children
show up through the match as "UnMatchedElements" which I believe is
correct.
However, when I run the Diff, the unmatched element on the "left" shows
up as a "RemoteRemoveModelElement" instead of a "RemoteAddModelElement"
whereas the "right" element shows up correctly as a "AddModelElement".
This seems like a bug, though I may be missing something.
I've put the serialization of the match and the diff below. Please let
me know if there's more information that would help or if there's
something like a 'snippet' I can modify to show the problem. I am
running against HEAD from CVS for emf compare and Eclipse 3.4 M6.
Matt
Match Model:
<?xml version="1.0" encoding="Cp1252"?>
<match:MatchModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:match="http://www.eclipse.org/emf/compare/match/1.1"
leftModel="/objects/org.example.model.impl.AllObjectsContainedImpl@1487217"
rightModel="/objects/org.example.model.impl.AllObjectsContainedImpl@13a46b6"
originModel="/objects/org.example.model.impl.AllObjectsContainedImpl@65dbe8">
<matchedElements xsi:type="match:Match3Element"
similarity="0.8777120315581853">
<leftElement
href="/objects/org.example.model.impl.AllObjectsContainedImpl@1487217#/"/>
<rightElement
href="/objects/org.example.model.impl.AllObjectsContainedImpl@13a46b6#/"/>
<originElement
href="/objects/org.example.model.impl.AllObjectsContainedImpl@65dbe8#/"/>
</matchedElements>
<unMatchedElements xsi:type="match:RemoteUnMatchElement">
<element
href="/objects/org.example.model.impl.AllObjectsContainedImpl@1487217#RemoteAdd"/>
</unMatchedElements>
<unMatchedElements>
<element
href="/objects/org.example.model.impl.AllObjectsContainedImpl@13a46b6#LocalAdd"/>
</match:MatchModel>
Diff Model:
<diff:DiffModel xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:diff="http://www.eclipse.org/emf/compare/diff/1.1"
left="/objects/org.example.model.impl.AllObjectsContainedImpl@1487217"
origin="/objects/org.example.model.impl.AllObjectsContainedImpl@65dbe8"
right="/objects/org.example.model.impl.AllObjectsContainedImpl@13a46b6">
<ownedElements xsi:type="diff:DiffGroup">
<subDiffElements xsi:type="diff:DiffGroup">
<subDiffElements xsi:type="diff:AddModelElement">
<leftParent
<rightElement
</subDiffElements>
<subDiffElements xsi:type="diff:RemoteRemoveModelElement">
<leftParent
<rightElement
</subDiffElements>
<leftParent
</subDiffElements>
</ownedElements>
</diff:DiffModel>
Code snippet that runs the match/diff:
HashMap<String, Object> options = new HashMap<String, Object>();
GenericMatchEngine genericMatch = new GenericMatchEngine();
MatchModel match = genericMatch.resourceMatch(modelLeft.eResource(),
modelRight.eResource(), modelAncestor.eResource(),
options);
GenericDiffEngine diffEngine = new GenericDiffEngine();
final DiffModel diff = diffEngine.doDiff(match, true);
Previous Topic:[Teneo] org.jpox.sco.exceptions.NullsNotAllowedException on resource.save()
Next Topic:Hibernate map does not have the required flag set
Current Time: Sat Jul 19 23:08:26 EDT 2025
Powered by FUDForum. Page generated in 0.04101 seconds
