Home » Archived » Visual Editor (VE) » Two files the same - 1 UI painter works the other doesn't
Two files the same - 1 UI painter works the other doesn't [message #134040] |
Sat, 09 December 2006 09:07  |
Originally posted by: tim.nesham.geemail.com
I wrote some code in the same class that VE generated and the UI painter
does not recognize the class as a bean. I backed out my code and left what
VE generated and it still does not recognize my class as a bean, but it does
run fine. I then created a new VE class and the UI painter works. I now have
two files exactly the same, 1 the UI painter works the other doesn't. How
do I tell the UI painter, in this situation, that my class is a VE class?
See code and environment info below. I am curious as to what is the
difference?
I have started eclipse with -clean and run the clean menu option.
//Code
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Shell;
public class Test {
private Shell sShell = null ;
* This method initializes sShell
private void createSShell() {
sShell = new Shell();
sShell.setText("Shell");
sShell.setSize(new Point(300, 200));
sShell.setLayout(new GridLayout());
Environment information
*** Date: Sat Dec 09 07:42:13 CST 2006
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20060629-1905
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
804_74
-vm
C:\Program Files\Java\j2re1.4.2_12\bin\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1165668858328
eclipse.vm=C:\Program Files\Java\j2re1.4.2_12\bin\javaw.exe
eclipse.vmargs=-Duser.language=en
-Xms128M
-Xmx512M
-XX:PermSize=64M
-XX:MaxPermSize=128M
-Dosgi.splashLocation=C:\Program Files\MyEclipse\eclipse\MyEclipseSplash.bmp
-jar
C:\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse\startup.jar
java.class.version=48.0
java.endorsed.dirs=C:\Program Files\Java\j2re1.4.2_12\lib\endorsed
java.ext.dirs=C:\Program Files\Java\j2re1.4.2_12\lib\ext
java.home=C:\Program Files\Java\j2re1.4.2_12
java.io.tmpdir=C:\DOCUME~1\tnesham\LOCALS~1\Temp\
java.library.path=C:\Program
Files\Java\j2re1.4.2_12\bin;.;C:\WINDOWS\system32;C:\WINDOWS ;C:\Dev_Build\10g;C:\Ora92\bin;C:\Program
Files\IBM\WebSphere
MQ\Java\lib;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System 32\Wbem;C:\Program
Files\NetManage\Windows;C:\Program Files\IBM\WebSphere MQ\bin;C:\Program
Files\IBM\WebSphere MQ\WEMPS\bin;C:\Program
Files\Oracle\jre\1.3.1\bin;C:\Program Files\Oracle\jre\1.1.8\bin;C:\Program
Files\SlickEdit\win;C:\Program Files\QuickTime\QTSystem\;C:\Program
Files\SlickEdit\win
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_12-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_12
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_12-b03
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imag eio,javax.imageio.event,
javax.imageio.metadata,javax.imageio.plugins.jpeg,javax.imag eio.spi,javax.imageio.stream,javax.naming,javax.naming.direc tory,javax.naming.event,javax.naming.ldap,javax.naming.spi,j avax.net,javax.net.ssl
,javax.print,javax.print.attribute,javax.print.attribute.sta ndard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.secu rity.auth,javax.security.auth.callback,javax.security.auth.k erberos,javax.security.auth.login,javax.security.auth.spi
,javax.security.auth.x500,javax.security.cert,javax.sound.mi di,javax.sound.midi.spi,javax.sound.sampled,javax.sound.samp led.spi,javax.sql,javax.swing,javax.swing.border,javax.swing .colorchooser,javax.swing.event,javax.swing.filechooser
,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.me tal,javax.swing.plaf.multi,javax.swing.table,javax.swing.tex t,javax.swing.text.html,javax.swing.text.html.parser,javax.s wing.text.rtf,javax.swing.tree,javax.swing.undo
,javax.transaction,javax.transaction.xa,javax.xml.parsers,ja vax.xml.transform,javax.xml.transform.dom,javax.xml.transfor m.sax,javax.xml.transform.stream,org.ietf.jgss,org.omg.CORBA ,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable
,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.om g.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNa ming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNa ming.NamingContextPackage,org.omg.Dynamic
,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage, org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.Cod ecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging, org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBI nitInfoPackage
,org.omg.PortableServer,org.omg.PortableServer.CurrentPackag e,org.omg.PortableServer.POAManagerPackage,org.omg.PortableS erver.POAPackage,org.omg.PortableServer.portable,org.omg.Por tableServer.ServantLocatorPackage,org.omg.SendingContext
,org.omg.stub.java.rmi,org.w3c.dom,org.xml.sax,org.xml.sax.e xt,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\eclipse\configuration\org.eclipse.osgi\b undles
osgi.configuration.area=file:/C:/eclipse/configuration/
osgi.framework=file:/c:/eclipse/plugins/org.eclipse.osgi_3.2 .1.R32x_v20060919.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.1.R32x_v20060919
osgi.install.area=file:/C:/eclipse/
osgi.instance.area=file:/C:/eclipse/workspace/
osgi.instance.area.default=file:/C:/Documents and
Settings/tnesham/workspace/
osgi.logfile=C:\eclipse\workspace\.metadata\.log
osgi.manifest.cache=C:\eclipse\configuration\org.eclipse.osg i\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\j2re1.4.2_12\lib\rt.jar;C:\Program
Files\Java\j2re1.4.2_12\lib\i18n.jar;C:\Program
Files\Java\j2re1.4.2_12\lib\sunrsasign.jar;C:\Program
Files\Java\j2re1.4.2_12\lib\jsse.jar;C:\Program
Files\Java\j2re1.4.2_12\lib\jce.jar;C:\Program
Files\Java\j2re1.4.2_12\lib\charsets.jar;C:\Program
Files\Java\j2re1.4.2_12\classes
sun.boot.library.path=C:\Program Files\Java\j2re1.4.2_12\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium i486 i386
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\eclipse
user.home=C:\Documents and Settings\tnesham
user.language=en
user.name=TNesham
user.timezone=America/Chicago
user.variant=
vendor=Apache Software Foundation
vendor-url=http://xml.apache.org/xalan-j
version=2.4.1
*** Features:
org.eclipse.emf (2.2.1.v200609210005) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.2.0.v200609210005) "EMF Service Data Objects
(SDO)"
org.eclipse.gef (3.2.1.v20060921 ) "Graphical Editing Framework"
org.eclipse.jdt (3.2.1.r321_v20060905-R4CM1Znkvre9wC-) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.1.r321_v20060905-R4CM1Znkvre9wC-) "Eclipse Java
Development Tools SDK"
org.eclipse.jem (1.2.2.v20061027_M----6zXJJzM1TEVU) "Java EMF Model"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG ) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.1.r321_v20060921-b_XVA-INSQSyMtx) "Eclipse
Platform"
org.eclipse.platform.source (3.2.1.r321_v20060921-b_XVA-INSQSyMtx ) "Eclipse
Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse RCP"
org.eclipse.rcp.source (3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse RCP
org.eclipse.sdk (3.2.1.r321_v20060801-tQ1w49KnTArT0FZ) "Eclipse Project SDK"
org.eclipse.ve (1.2.1.v20060817_M-zXJUB0fxM0dxQdc) "Visual Editor"
org.maven.ide.eclipse.feature (0.0.9) "Maven 2.0 integration"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Resolved]
com.ibm.icu (3.4.5) "International Components for Unicode for Java (ICU4J)"
[Active]
com.ibm.icu.source (3.4.5) "International Components for Unicode for Java
(ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.1.r321_v20060828) "Ant UI" [Resolved]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism"
[Active]
org.eclipse.core.expressions (3.2.1.r321_v20060721) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File System
for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.1.R32x_v20060914) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource Management
Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601 )
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Active]
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.1.v20060823) "Debug UI" [Active]
org.eclipse.draw2d (3.2.1.v20060921) "Draw2d" [Active]
org.eclipse.emf (2.2.0.v200609210005) "Eclipse Modeling Framework (EMF)"
[Resolved]
org.eclipse.emf.ant (2.2.0.v200609210005) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.2.1.v200609210005) "EMF Template Code Generator"
[Resolved]
org.eclipse.emf.codegen.ecore (2.2.1.v200609210005) "EMF Ecore Code
Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200609210005) "EMF Ecore Code
Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200609210005) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.2.1.v200609210005 ) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.1.v200609210005) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0.v200609210005) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.1.v200609210005) "EMF Model Convert Support"
[Resolved]
org.eclipse.emf.ecore (2.2.1.v200609210005) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.0.v200609210005) "EMF Ecore Change Model"
[Active]
org.eclipse.emf.ecore.change.edit (2.2.0.v200609210005) "EMF Ecore Change
Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200609210005) "EMF Ecore Edit Support"
[Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200609210005) "Sample Ecore Editor"
[Resolved]
(SDO)" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200609210005 ) "EMF Service Data
Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200609210005) "EMF Service Data
Objects (SDO) Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.1.v200609210005 ) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.1.v200609210005) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.0.v200609210005) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter ( 2.2.0.v200609210005) "EMF Model Export Support"
[Resolved]
org.eclipse.emf.importer (2.2.1.v200609210005) "EMF Model Import Support"
[Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200609210005 ) "EMF Ecore Importer"
[Resolved]
org.eclipse.emf.importer.java (2.2.1.v200609210005) "EMF Annotated Java
Importer" [Resolved]
org.eclipse.emf.importer.rose (2.2.0.v200609210005) "EMF Rose Importer"
[Resolved]
org.eclipse.emf.mapping (2.2.0.v200609210005) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200609210005) "Ecore to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200609210005) "Ecore to
Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200609210005) "Ecore to XML
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200609210005 ) "Ecore to XML
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200609210005) "EMF Mapping UI" [Resolved]
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension Registry
Support" [Active]
org.eclipse.gef (3.2.1.v20060921) "Graphical Editing Framework" [Active]
org.eclipse.help (3.2.1.R321_v20060920) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server"
[Resolved]
org.eclipse.help.base (3.2.1.R321_v20060822) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.1.R321_v20060803) "Help System Webapp"
[Resolved]
org.eclipse.jdt (3.2.1.r321_v20060823) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing Core" [Installed]
org.eclipse.jdt.apt.ui (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing UI" [Installed]
org.eclipse.jdt.core (3.2.1.v_677_R32x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721 ) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.1.r321_v20060731) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.1.r321_v20060918) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.2.1.r321_v20060907) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java Development
User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools JUnit
support" [Active]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development Tools
JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.1.r321_v20060905) "Java Development
Tools JUnit4 runtime support" [Installed]
org.eclipse.jdt.launching (3.2.1.r321_v20060731) "Java Development Tools
Launching Support" [Active]
Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.1.r321_v20060907) "Java Development Tools UI"
[Active]
org.eclipse.jem (1.2.1.v20060918_M) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.2.2.v20061027_M) "Java EMF Model BeanInfo
(Introspection) Support" [Active]
org.eclipse.jem.proxy (1.2.0.v20060918_M) "Java EMF Model Proxy Support"
[Active]
org.eclipse.jem.ui (1.2.1.v20060918_M) "Java EMF Model UI" [Active]
org.eclipse.jem.util (1.2.1.v20060918_M) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.2.2.v20061027_M) "Java EMF Model Workbench
Support" [Active]
org.eclipse.jface (3.2.1.M20060908-1000) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding"
[Resolved]
org.eclipse.jface.text (3.2.1.r321_v20060810) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring Core"
[Active]
org.eclipse.ltk.ui.refactoring (3.2.1.r321_v20060726) "Refactoring UI"
[Active]
org.eclipse.osgi.services ( 3.1.100.v20060601) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.1.v20060810-0800) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.1.r321_v20060823) "Plug-in Development
Environment Build Support" [Resolved]
org.eclipse.pde.core (3.2.1.v20060915-0800) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) "Eclipse Plug-in Development
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605 ) "Plug-in Development Environment
Runtime" [Resolved]
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.0.v20060601) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.1.r321_v2006030) "Eclipse Platform Plug-in
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse Workbench
org.eclipse.platform.source (3.2.1.r321_v20060921-b_XVA-INSQSyMtx) "Eclipse
Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.2.1.r321_v20060921-b_XVA-INSQSyMtx) "Eclipse Platform Plug-in Developer
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.2.1.r321_v20060801-2ekW2BxmcpPUOoq) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.2.1.r321_v20060705) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Resolved]
org.eclipse.swt (3.2.1.v3235e) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.1.v3235) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.2.1.M20060711) "Team Support Core" [Active]
org.eclipse.team.cvs.core ( 3.2.1.M200608161750) "CVS Team Provider Core"
[Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I200606011710) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200606051140) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.1.M20060831) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.1.M20060913-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Active]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External Tools"
[Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.2.1.M20060915-1030) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.1.R321_v20060810) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal Welcome"
[Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800 ) "Common Navigator View"
[Resolved]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) "Navigator
Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation
Plug-in" [Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400 ) "Eclipse UI Win32 Enhancements"
[Resolved]
org.eclipse.ui.workbench (3.2.1.M20060906-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.2.1.v20092006) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.1.v20092006) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.1.v20092006) "Install/Update Core for
Windows" [Resolved]
org.eclipse.update.scheduler (3.2.1.v20092006) "Automatic Updates Scheduler"
[Active]
org.eclipse.update.ui (3.2.1.v20092006) "Install/Update UI" [Resolved]
org.eclipse.ve (1.2.0.v20060518_RC1) "Visual Editor" [Resolved]
org.eclipse.ve.cde ( 1.2.0.v20060918_M) "Visual Editor Common Data Editor"
[Active]
org.eclipse.ve.doc (1.2.0.v20060824_M) "Visual Editor for Java User Guide"
[Resolved]
org.eclipse.ve.java.core (1.2.1.v20060918_M) "Visual Editor Java Core"
[Active]
org.eclipse.ve.jfc (1.2.1.v20060918_M) "Visual Editor for Java Foundation
Classes" [Active]
org.eclipse.ve.propertysheet (1.2.0.v20060824_M) "Visual Editor
PropertySheet" [Active]
org.eclipse.ve.swt (1.2.1.v20060918_M) "Visual Editor for Standard Widget
Toolkit" [Active]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.junit4 (4.1.0.1) "JUnit Testing Framework Version 4" [Installed]
org.maven.ide.eclipse (0.0.9) "Maven 2.0 integration" [Active]
system.bundle (3.2.1.R32x_v20060919) "OSGi System Bundle" [Active]
*** User Preferences:
#Sat Dec 09 07:42:15 CST 2006
@org.eclipse.debug.ui=3.2.1.v20060823
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<templates/>
@org.eclipse.ui.ide=3.2.1.M20060915-1030
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.userLibr ary.SWTPLUGINS= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<userlibrary systemlibrary\="false"
version\="1">\r\n\t<archive
path\=" C\:/eclipse/plugins/com.ibm.etools.emf.event_3.0.0.v20060518 _RC1.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.maven.ide.eclipse_0.0.9.jar"/ >\r\n\t<archive
path\="C\:/eclipse/plugins/com.ibm.icu_3.4.4.1.jar"/>\r\n\t <archive
path\="C\:/eclipse/plugins/com.jcraft.jsch_0.1.28.jar"/>\r\n\t <archive
path\=" C\:/eclipse/plugins/org.eclipse.ant.core_3.1.100.v20060531.j ar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ant.ui_3.2.0.v20060531.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.compare_3.2.0.v20060605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.boot_3.1.100.v20060603. jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.commands_3.2.0.I2006060 5-
1400.jar"/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.contenttype_3.2.0.v2006 0603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.expressions_3.2.0.v2006 0605-
path\=" C\:/eclipse/plugins/org.eclipse.core.filebuffers_3.2.0.v2006 0605-1400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.filesystem.win32.x86_1. 0.0.v20060603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.filesystem_1.0.0.v20060 603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.jobs_3.2.0.v20060603.ja r "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.resources.compatibility _3.2.0.v20060603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.resources.win32_3.2.0.v 20060603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.resources_3.2.0.v200606 03.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.runtime.compatibility.a uth_3.2.0.v20060601.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.runtime.compatibility_3 .1.100.v20060603.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.runtime_3.2.0.v20060603 .jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.core.variables_3.1.100.v2006 0605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.debug.core_3.2.0.v20060605.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.debug.ui_3.2.0.v20060605.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.draw2d_3.2.0.v20060626.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ant_2.2.0.v200606271057. jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.codegen.ecore.ui_2.2.0.v 200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.codegen.ecore_2.2.0.v200 606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.codegen.ui_2.1.0.v200606 271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.codegen_2.2.0.v200606271 057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.common.ui_2.2.0.v2006062 71057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.common_2.2.0.v2006062710 57.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.commonj.sdo_2.1.0.v20060 6271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.converter_2.2.0.v2006062 71057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.change.edit_2.1.0. v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.change_2.2.0.v2006 06271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.edit_2.2.0.v200606 271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.editor_2.2.0.v2006 06271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.sdo.edit_2.1.0.v20 0606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.sdo.editor_2.1.0.v 200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.sdo_2.2.0.v2006062 71057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore.xmi_2.2.0.v2006062 71057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.ecore_2.2.0.v20060627105 7.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.edit.ui_2.2.0.v200606271 057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.edit_2.2.0.v200606271057 .jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.exporter_2.2.0.v20060627 1057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.importer.ecore_2.2.0.v20 0606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.importer.java_2.2.0.v200 606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.importer.rose_2.2.0.v200 606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.importer_2.2.0.v20060627 1057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping.ecore2ecore.edit or_2.2.0.v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping.ecore2ecore_2.2. 0.v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping.ecore2xml.ui_2.2 .0.v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping.ecore2xml_2.2.0. v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping.ui_2.2.0.v200606 271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.emf.mapping_2.2.0.v200606271 057.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.emf_2.2.0.v200606271057.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.equinox.common_3.2.0.v200606 03.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.equinox.preferences_3.2.0.v2 0060601.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.equinox.registry_3.2.0.v2006 0601.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.gef_3.2.0.v20060626.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.help.appserver_3.1.100.v2006 0602.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.help.base_3.2.0.v20060601.ja r "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.help.ui_3.2.0.v20060602.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.help_3.2.0.v20060602.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.apt.core_3.2.0.v20060602 -
1740.jar"/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.apt.ui_3.2.0.v20060602-1 740.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.core.manipulation_1.0.0. v20060605-
path\="C\:/eclipse/plugins/org.eclipse.jdt.core_3.2.0.v_671.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.debug.ui_3.2.0.v20060605 .jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.doc.isv_3.2.0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.jdt.doc.user_3.2.0.v20060605 -1400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.junit4.runtime_1.0.0.v20 060605-
path\=" C\:/eclipse/plugins/org.eclipse.jdt.launching_3.2.0.v2006060 5.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jdt.ui_3.2.0.v20060605-1400. jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.jdt_3.2.0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.jem.beaninfo_1.2.0.v20060530 _RC2.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jem.proxy_1.2.0.v20060530_RC 2.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jem.ui_1.2.0.v20060518_RC1.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jem.util_1.2.0.v20060530_RC2 .jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jem.workbench_1.2.0.v2006053 0_RC2.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.jem_1.2.0.v20060530_RC2.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jface.databinding_1.0.0.I200 60605-
path\=" C\:/eclipse/plugins/org.eclipse.jface.text_3.2.0.v20060605-1 400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.jface_3.2.0.I20060605-1400.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.2.0.v 20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.2.0.v20 060605-1400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.osgi.services_3.1.100.v20060 601.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.osgi.util_3.1.100.v20060601. jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.osgi_3.2.0.v20060601.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.pde.core_3.2.0.v20060605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.pde.doc.user_3.2.0.v20060605 .jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.pde.junit.runtime_3.2.0.v200 60605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.pde.runtime_3.2.0.v20060605. jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.pde.ui_3.2.0.v20060605.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.pde_3.2.0.v20060605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.platform.doc.isv_3.2.0.v2006 0612-
0900.jar"/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.platform.doc.user_3.2.0.v200 60605.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.rcp_3.2.0.v20060605.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.search_3.2.0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.swt.win32.win32.x86_3.2.0.v3 232m.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.swt_3.2.0.v3232o.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.core_3.2.0.I20060605114 0.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.cvs.core_3.2.0.M2006062 8.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.2.0.I2006060 51140.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.cvs.ssh_3.2.0.I20060601 1710.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.cvs.ui_3.2.0.I200606051 140.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.team.ui_3.2.0.I200606051140. jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.text_3.2.0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.browser_3.2.0.v20060602.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.cheatsheets_3.2.0.v200606 02.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.console_3.1.100.v20060605 .jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ui.editors_3.2.0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.externaltools_3.1.100.v20 060605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.forms_3.2.0.v20060602.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ui.ide_3.2.0.I20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.intro_3.2.0.v20060601.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.navigator.resources_3.2.0 .I20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.navigator_3.2.0.I20060605 -1400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.presentations.r21_3.2.0.I 20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.views.properties.tabbed_3 .2.0.I20060605-1400.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ui.views_3.2.0.I20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.win32_3.2.0.I20060605-140 0.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.2. 0.v20060605-
path\=" C\:/eclipse/plugins/org.eclipse.ui.workbench_3.2.0.I20060605 -1400.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ui_3.2.0.I20060605-1400.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.update.configurator_3.2.0.v2 0060605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.update.core.win32_3.2.0.v200 60605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.update.core_3.2.0.v20060605. jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.update.scheduler_3.2.0.v2006 0605.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.update.ui_3.2.0.v20060605.ja r "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ve.cde_1.2.0.v20060518_RC1.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ve.doc_1.2.0.v20060518_RC1.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ve.java.core_1.2.0.v20060620 _RC3.jar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ve.jfc_1.2.0.v20060620_RC3.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/plugins/org.eclipse.ve.propertysheet_1.2.0.v2006 0518_RC1.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ve.swt_1.2.0.v20060628.jar "/>\r\n\t<archive
path\="C\:/eclipse/plugins/org.eclipse.ve_1.2.0.v20060518_RC1.jar "/>\r\n</userlibrary>\r\n
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13
,1155849257195" defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1155849257195" name\="j2re1.4.2_12" path\="C\:\\Program
Files\\Java\\j2re1.4.2_12"
javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api/"/>\r\n</vmType>\r\n</vmSettings>\r\n
/instance/org.eclipse.ui.workbench/resourcetypes=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors version\="3.1">\r\n<info name\="*"
extension\="jpage">\r\n<editor id\="
org.eclipse.jdt.debug.ui.SnippetEditor"/>\r\n</info>\r\n <info name\="*"
extension\="genmodel">\r\n<editor
id\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel EditorID
"/>\r\n</info>\r\n<info name\="*" extension\="html">\r\n<editor
id\="org.eclipse.ui.browser.editorSupport"/>\r\n</info>\r\n <info name\="*"
extension\="override">\r\n<editor id\="
org.eclipse.jem.beaninfo.OverrideEditor"/>\r\n</info>\r\n <info name\="*"
extension\="ecore">\r\n<editor
id\="org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n </info>\r\n<info
name\="sample" extension\="properties">\r\n<editor id\="
org.eclipse.pde.ui.sampleEditor"/>\r\n<defaultEditor
id\="org.eclipse.pde.ui.sampleEditor"/>\r\n</info>\r\n<info name\="*"
extension\="ecore2xml">\r\n<editor id\="
org.eclipse.emf.mapping.ecore2xml.presentation.Ecore2XMLEdit orID "/>\r\n</info>\r\n<info
name\="*" extension\="htm">\r\n<editor
extension\="datagraph">\r\n<editor id\="
org.eclipse.emf.ecore.sdo.presentation.SDOEditorID"/>\r\n</info >\r\n<info
name\="*" extension\="xmi">\r\n<editor
id\="org.eclipse.emf.ecore.presentation.ReflectiveEditorID"/ >\r\n</info>\r\n<info
name\="*" extension\="jardesc">\r\n<editor id\="
org.eclipse.jdt.ui.JARDescEditor"/>\r\n<defaultEditor
id\="org.eclipse.jdt.ui.JARDescEditor"/>\r\n</info>\r\n <info name\="*"
extension\="ecore2ecore">\r\n<editor id\="
org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore EditorID "/>\r\n</info>\r\n<info
name\="*" extension\="shtml">\r\n<editor
id\="org.eclipse.ui.browser.editorSupport "/>\r\n</info>\r\n<info name\="*"
extension\="jar">\r\n<editor id\="WinZip File"/>\r\n<defaultEditor
id\="WinZip File"/>\r\n</info>\r\n<info name\="*"
extension\="class">\r\n<editor id\="C\:\\Program Files\\Cavaj Java
Decompiler\\cavaj.exe"/>\r\n<defaultEditor id\="C\:\\Program Files\\Cavaj
Java Decompiler\\cavaj.exe"/>\r\n</info>\r\n<info name\="*"
extension\="emof">\r\n<editor id\="
org.eclipse.emf.ecore.presentation.EcoreEditorID"/>\r\n</info >\r\n</editors>
@org.eclipse.pde.core=3.2.1.v20060915-0800
/instance/org.eclipse.ve.java.core/VISUAL_CLASS_WIZARD_SELEC TED_ELEMENT_KEY=
org.eclipse.ve.swt.cat-Shell-java.lang.Object
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
/instance/org.eclipse.pde.runtime/activate=true
@org.eclipse.ui.browser=3.2.0.v20060602
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
@org.eclipse.jdt.ui=3.2.1.r321_v20060907
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.resources=3.2.1.R32x_v20060914
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.help.ui/browser.y=0
/instance/org.eclipse.help.ui/browser.x=0
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.pde.core/platform_path=C\:\\eclipse
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
@org.eclipse.team.cvs.ui=3.2.1.M20060831
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.WAS_50_PLUGINDIR=C\:/Program
Files/WebSphere/AppServer
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.ui.workbench=3.2.1.M20060906-0800
@org.eclipse.ve.java.core=1.2.1.v20060918_M
file_export_version=3.0
@org.eclipse.jdt.launching=3.2.1.r321_v20060731
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
@org.eclipse.pde.runtime=3.2.0.v20060605
/instance/org.eclipse.help.ui/browser.h=738
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_SRC_HOME=C\:/eclipse/plugins/org.eclipse.jdt .source_3.2.1.r321_v20060905-R4CM1Znkvre9wC-/src/org.junit_3 .8.1
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/instance/org.eclipse.ve.java.core/PALETTE_WIDTH=125
/instance/org.eclipse.ui.ide/platformState=1165667813163
/instance/org.eclipse.ve.java.core/PALETTE_STATE=2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
@org.eclipse.ui.editors=3.2.1.r321_v20060721
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\ecl ipse\\workspace
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.userLibr ary.MEMBEREAR_LIBRARY=\#\# <cp
entry ignore>\#\#
/instance/org.eclipse.pde.runtime/orderType=2
/instance/org.eclipse.team.cvs.ui/pref_first_startup=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=C\:/eclipse/plugins/org.junit_3.8.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.RUNTIME_LIB=C\:/eclipse/plugins/org.eclipse.swt.wi n32.win32.x86_3.2.1.v3235.jar
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=C\:/Program
Files/Java/j2re1.4.2_12/lib/rt.jar
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=10
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.jdt.ui.override.decorator\:true,org.eclipse.jdt.ui.int erface.decorator\:false
,org.eclipse.pde.ui.binaryProjectDecorator\:false,org.eclips e.team.cvs.ui.decorator\:true,org.eclipse.ui.LinkedResourceD ecorator\:true,
@org.eclipse.jdt.core=3.2.1.v_677_R32x
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
@org.eclipse.search=3.2.1.r321_v20060726
/instance/org.eclipse.pde.runtime/orderValue=-1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<web-browsers current\="0">\r\n<system/>\r\n<external
name\="Internet Explorer" location\="C\:\\Program Files\\Internet
Explorer\\iexplore.exe"/>\r\n</web-browsers>
/instance/org.eclipse.ui.workbench/editors=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<editors>\r\n<descriptor label\="Scrapbook"
image\="$nl$/icons/full/obj16/jsbook_obj.gif" class\="
org.eclipse.jdt.internal.debug.ui.snippeteditor.JavaSnippetE ditor "
id\="org.eclipse.jdt.debug.ui.SnippetEditor"
plugin\="org.eclipse.jdt.debug.ui" openMode\="1" internal\="true"
open_in_place\="false"/>\r\n<descriptor label\="EMF Generator"
image\="icons/full/obj16/GenModelModelFile.gif" class\="
org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel Editor "
id\=" org.eclipse.emf.codegen.ecore.genmodel.presentation.GenModel EditorID "
plugin\="org.eclipse.emf.codegen.ecore.ui" openMode\="1" internal\="true"
open_in_place\="false"/>\r\n<descriptor label\="Web Browser"
image\="$nl$/icons/obj16/internal_browser.gif" launcher\="
org.eclipse.ui.internal.browser.BrowserLauncher"
id\="org.eclipse.ui.browser.editorSupport" plugin\="org.eclipse.ui.browser"
openMode\="4" internal\="false" open_in_place\="false"/>\r\n<descriptor
label\="Override Editor" image\="icons/full/obj16/file_obj.gif" class\="
org.eclipse.ui.editors.text.TextEditor"
id\="org.eclipse.jem.beaninfo.OverrideEditor" plugin\="org.eclipse.jem.ui"
openMode\="1" internal\="true" open_in_place\="false"/>\r\n<descriptor
label\="Sample Ecore Model Editor"
image\="icons/full/obj16/EcoreModelFile.gif" class\="
org.eclipse.emf.ecore.presentation.EcoreEditor"
plugin\="org.eclipse.emf.ecore.editor" openMode\="1" internal\="true"
open_in_place\="false"/>\r\n<descriptor label\="Code Sample Editor"
image\="$nl$/icons/obj16/build_exec.gif" class\="
org.eclipse.pde.internal.ui.samples.SampleEditor"
id\="org.eclipse.pde.ui.sampleEditor" plugin\="org.eclipse.pde.ui"
label\="Ecore to XML Mapping Editor"
image\="icons/full/obj16/Ecore2XMLModelFile.gif" class\="
org.eclipse.emf.mapping.ecore2xml.presentation.Ecore2XMLEdit or "
id\=" org.eclipse.emf.mapping.ecore2xml.presentation.Ecore2XMLEdit orID "
plugin\="org.eclipse.emf.mapping.ecore2xml.ui" openMode\="1"
internal\="true" open_in_place\="false"/>\r\n<descriptor label\="Data Graph
Editor" image\="icons/full/obj16/SDOModelFile.gif" class\="
org.eclipse.emf.ecore.sdo.presentation.SDOEditor"
id\="org.eclipse.emf.ecore.sdo.presentation.SDOEditorID"
plugin\="org.eclipse.emf.ecore.sdo.editor" openMode\="1" internal\="true"
open_in_place\="false"/>\r\n<descriptor label\="Sample Reflective Ecore
Model Editor"
image\=" platform\:/plugin/org.eclipse.emf.edit/icons/full/obj16/Mode lFile.gif "
class\=" org.eclipse.emf.ecore.presentation.EcoreEditor"
open_in_place\="false"/>\r\n<descriptor label\="JAR Description Editor"
image\="$nl$/icons/full/obj16/jar_desc_obj.gif" class\="
id\="org.eclipse.jdt.ui.JARDescEditor" plugin\="org.eclipse.jdt.ui"
label\="Ecore to Ecore Mapping Editor"
image\="icons/full/obj16/Ecore2EcoreModelFile.gif" class\="
org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore Editor "
id\=" org.eclipse.emf.mapping.ecore2ecore.presentation.Ecore2Ecore EditorID "
plugin\="org.eclipse.emf.mapping.ecore2ecore.editor" openMode\="1"
internal\="true" open_in_place\="false"/>\r\n<descriptor label\="WinZip
File" file\="WinZip File" id\="WinZip File" openMode\="4" internal\="false"
open_in_place\="false" program_name\="WinZip File"/>\r\n<descriptor
label\="cavaj" file\="C\:\\Program Files\\Cavaj Java Decompiler\\cavaj.exe"
id\="C\:\\Program Files\\Cavaj Java Decompiler\\cavaj.exe" openMode\="4"
internal\="false" open_in_place\="false"/>\r\n</editors>
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.user_vie w_bindings= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<viewBindings>\r\n<view
id\="org.eclipse.ui.console.ConsoleView ">\r\n<perspective
id\="org.eclipse.team.cvs.ui.cvsPerspective"
userAction\="opened"/>\r\n<perspective
id\="org.eclipse.jdt.ui.JavaPerspective"
userAction\="closed"/>\r\n</view>\r\n</viewBindings>\r\n
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.pde.runtime/column4=150
/instance/org.eclipse.pde.runtime/column3=150
@org.eclipse.team.ui=3.2.1.M200608151725
/instance/org.eclipse.pde.runtime/column2=300
/instance/org.eclipse.search/org.eclipse.search.defaultPersp ective=org.eclipse.search.defaultPerspective.none
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.jdt.ui/MemberFilterActionGroup.org.ecl ipse.jdt.ui.JavaOutlinePage.4=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.M2_REPO=C\:/Documents
and Settings/tnesham/.m2/repository
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.SERVERJDK_50_PLUGINDIR=C\:/Program
Files/WebSphere/AppServer/java
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.userLibr ary.MemberEar= <?xml
version\=" 1.0" encoding\="UTF-8"?>\r\n<userlibrary systemlibrary\="false"
path\="C\:/eclipse/workspace/MemberEAR/xstream-1.1.2.jar"/ >\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/aopalliance- 1.0.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/AR_IDL.jar"/>\r\n\t <archive
path\="C\:/eclipse/workspace/MemberEAR/bcmail-jdk13-133.jar "/>\r\n\t<archive
jdk14-133.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/bcprov-jdk13-133.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/benefit-adapters-0.7.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cadre_fw.jar"/>\r\n\t <archive
path\="C\:/eclipse/workspace/MemberEAR/carrier-
service-1.1.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cbc-benefit-client-5.0.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cbc-claim-client-12.0.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cbcDrugClient_6.0.1.jar "/>\r\n\t<archive
eligibility-4.0.jar"/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-eligibility-client-4.0.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-mail-order-client-9.0.0. 1.jar
"/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-mail-order-site-locator- client-2.3.jar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-member-locator-client-5. 0.jar
"/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-member-materials-client- 5.0.jar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-message-tracking-client- 1.6.jar "/>\r\n\t<archive
osf-client-2.3.0.2.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cbc-pharmacy-client-3.0.jar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-prescriber-client-4.0.ja r
"/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/cbc-price-check-client-2.0.j ar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cbc-shared-2.3.jar"/ >\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cglib-
full-2.0.2.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/claim-adapters-1.4.jar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/claim-router-adapters-0.6.ja r "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/client-
hierarchy-1.5.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/cmt-client-service-1.1.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/com.ibm.mq-1.0.jar"/ >\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/com.ibm.mqbind.jar"/ >\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/com.ibm.mqjms-
path\="C\:/eclipse/workspace/MemberEAR/common-deprecated-1.1.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/common-legacy-1.1.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/commonLogonSupport-
0.6.1.jar"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/common-model-1.0.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/common-persistence-1.5.jar "/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/commons-
beanutils-1.6.jar"/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/commons-beanutils-core-1.7.j ar "/>\r\n\t<archive
path\=" C\:/eclipse/workspace/MemberEAR/commons-collections-2.1.1.ja r
"/>\r\n\t<archive
path\="C\:/eclipse/workspace/MemberEAR/commons-digester.jar "/>\r\n\t<archive
Re: Two files the same - 1 UI painter works the other doesn't [message #134062 is a reply to message #134050] |
Sun, 10 December 2006 16:47  |
That was it, thanks.
Tim
"David Wegener" <wegener@cboenospam.com> wrote in message
news:elf8vh$1vh$1@utils.eclipse.org...
> When you say that the UI painter doesn't work do you mean that when you
> open up the file you only see the Java editor and no gui display? If so,
> you have probably opened the .java file with the Java editor and not the
> Visual editor.
> Close the file .java file for the class that isn't working. Right click
> on the file in the Navigator/Type explorer. Select Open With... and
> select Visual Editor from the menu.
> Eclipse remembers the last editor that was used to open a specific file.
Re: Two files the same - 1 UI painter works the other doesn't [message #614850 is a reply to message #134040] |
Sat, 09 December 2006 16:14  |
> difference?
> //Code
> public class Test {
snip...
so, you have probably opened the .java file with the Java editor and not
the Visual editor.
Re: Two files the same - 1 UI painter works the other doesn't [message #614852 is a reply to message #134050] |
Tim
> Visual editor.
Current Time: Sun Jul 20 09:43:11 EDT 2025
Powered by FUDForum. Page generated in 0.04146 seconds
