NullPointerException when showing JPanel [message #133339] |
Tue, 21 November 2006 13:43  |
excuse my bad English. I'm from Germany and I have no possibility to talk
English with somebody.
I have a big problem with the Eclipse VE. I have two visual classes.
The first class is a javax.swing.JPanel that shows a picture. The VE shows
me this JPanel with the picture in the VE show window (I hope you can
understand what I mean). I doesnt get any Exception there.
The second class is a javax.swing.JPanel, too. This class shows some
JLabels, one JButton and an object of the first class.
It all works fine, if I start the Application. Then I get no errors.
But in the VE show window I cant see the object of first class. If I
click on Java Beans and select the bean of the first class, then I can
see a red circle with and white x in it and the text
java.lang.NullPointerException(null). This Message is shown in the
lowest line of Eclipse.
Because of this error and so much errors in the Error Log that I
couldnt understand I reinstalled Eclipse three times
. But everything is
the same.
The versions of my plug-ins and my error log file is below.
Best regards and thanks for your help!
Andreas Eberle
Versions of my plug-ins (not all plug-ins)
Eclipse Java Development Tools SDK
Version: 3.2.1.r321_v20060905-R4CM1Znkvre9wC-
Build id: M20060921-0945
Eclipse Modeling Framework (EMF)
Version: 2.2.1.v200609210005
Build id: 200609210005
Eclipse Platform
Version: 3.2.1.r321_v20060921-b_XVA-INSQSyMtx
Eclipse Project SDK
Version: 3.2.1.r321_v20060801-tQ1w49KnTArT0FZ
Eclipse Graphical Editing Framework
Version: 3.2.1.v20060921
Build id: 20060921-1617
Java EMF Model
Version: 1.2.1.v20060815_M----6zXJJzKIRGVU
Build id: 200609261748
Visual Editor
Version: 1.2.1.v20060817_M-zXJUB0fxM-0vSdc
Build id: 200606280938
My error log file
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-19 18:38:52.593
!MESSAGE Exception thrown.
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: -1
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 14)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObjectF orURIFragmentRootSegment(ResourceImpl.java:642)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:692)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:671)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XML Handler.java:2522)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:2450)
at
org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAtt ribs(SAXXMIHandler.java:74)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:1940)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:1844)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:1779)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1587)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:881)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:82)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:860)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:627)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:179)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1094)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:900)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.demandLoad(ProjectResourceSetImpl.java:83)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:390)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:262)
at
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doLoadFromCache(VEModelCacheUtility.java:103)
at
org.eclipse.ve.internal.java.codegen.core.VEModelInstance.cr eateComposition(VEModelInstance.java:100)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reConnect(JavaSourceTranslator.java:1134)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:910)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:597)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1978)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!ENTRY org.eclipse.ve.java.core 2 0 2006-11-19 18:38:53.093
!MESSAGE
+++ Warning +++: Sun Nov 19 18:38:53 CET 2006 Skipping expression:
this.setSize(new Dimension(310,370))
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-19 18:38:53.125
!MESSAGE Invalid PropertyDecorator
!ENTRY org.eclipse.jem.proxy 4 0 2006-11-19 18:38:53.890
!MESSAGE
!STACK 0
java.lang.RuntimeException: IWAV0066E No Standard Bean Proxy Factory has
been set.
at
org.eclipse.jem.internal.proxy.core.ProxyFactoryRegistry.get BeanProxyFactory(ProxyFactoryRegistry.java:159)
at
org.eclipse.jem.internal.proxy.remote.REMCallbackThread.<init >(REMCallbackThread.java:78)
at
org.eclipse.jem.internal.proxy.remote.REMCallbackRegistry.cr eateCallback(REMCallbackRegistry.java:61)
at
org.eclipse.jem.internal.proxy.remote.REMMasterServerThread. processRequest(REMMasterServerThread.java:143)
at
org.eclipse.jem.internal.proxy.remote.REMMasterServerThread. run(REMMasterServerThread.java:80)
!ENTRY org.eclipse.jem.proxy 2 0 2006-11-19 18:38:54.000
!MESSAGE
+++ Warning +++: Sun Nov 19 18:38:54 CET 2006 Project (TSP)-VM for
TSP:err>
java.io.EOFException
at java.io.DataInputStream.readBoolean(Unknown Source)
at
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.requestCallbackSocket(RemoteVMServerThread.java:625)
at
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.createCallbackHandler(RemoteVMServerThread.java:504)
at
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.getFreeCallbackHandler(RemoteVMServerThread.java:496)
at
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.doCallback(RemoteVMServerThread.java:537)
at
org.eclipse.ve.internal.jfc.vm.ComponentManager$ComponentMan agerFeedbackController.run(ComponentManager.java:546)
at
org.eclipse.jem.internal.proxy.common.GenericEventQueue$Even tThread.run(GenericEventQueue.java:81)
org.eclipse.jem.internal.proxy.common.CommandException: No callback
handler retrieved.
at
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d.doCallback(RemoteVMServerThread.java:565)
at
at
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-19 18:39:55.062
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1$Diagno sticWrappedException:
org.xml.sax.SAXParseException: Content is not allowed in trailing section.
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:307)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:268)
at
at
at
at
at
at
at
at
Caused by: org.xml.sax.SAXParseException: Content is not allowed in
trailing section.
at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. createSAXParseException(Unknown
Source)
at
com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper. fatalError(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.rep ortError(Unknown
Source)
at
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFat alError(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$TrailingMiscDispatcher.dispatch(Unknown
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
at
at
at
at
at
... 9 more
!ENTRY org.eclipse.ui 4 4 2006-11-19 18:40:06.609
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-11-19 18:40:06.609
!MESSAGE Failed to execute runnable (java.lang.NullPointerException)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
at org.eclipse.swt.SWT.error(SWT.java:3374)
at org.eclipse.swt.SWT.error(SWT.java:3297)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
at
org.eclipse.ve.internal.java.core.BeanPropertyDescriptorAdap ter.isReadOnly(BeanPropertyDescriptorAdapter.java:463)
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:803 )
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1029)
at
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:943)
at
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:473)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 20 more
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-19 18:40:12.406
!STACK 0
at
org.eclipse.ve.internal.java.core.EventMethodTreeEditPart.ge tText(EventMethodTreeEditPart.java:70)
at
org.eclipse.gef.editparts.AbstractTreeEditPart.refreshVisual s(AbstractTreeEditPart.java:138)
at
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:676)
at
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:235)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:198)
at
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:727)
at
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:677)
at
at
at
at
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:504)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:1121)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$13.run(JavaVisualEditorPart.java:2098)
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 4 2006-11-19 18:40:12.406
!ENTRY org.eclipse.ui 4 0 2006-11-19 18:40:12.437
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 20 more
!ENTRY org.eclipse.ve.java.core 2 0 2006-11-19 18:40:12.640
!MESSAGE
+++ Warning +++: Sun Nov 19 18:40:12 CET 2006 TypeVisitor.visit() could
not visit jbInit : null
!SESSION 2006-11-20 20:10:38.202
eclipse.buildId=M20060921-0945
java.version=1.5.0_09
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-20 20:26:26.967
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-20 20:51:49.780
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-20 21:05:38.530
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SESSION 2006-11-20 21:08:11.702
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-20 21:08:48.577
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!SESSION 2006-11-20 21:09:45.498
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-20 21:10:03.795
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-20 21:10:10.155
!STACK 0
at
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.getSF(DefaultVisitorFactoryRule.java:66)
at
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.retrieveFromCache(DefaultVisitorFactoryRule.ja va:82)
at
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.getTypeVisitor(DefaultVisitorFactoryRule.java: 109)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:534)
at
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:443)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:865)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:947)
at
at
!ENTRY org.eclipse.ve.java.core 2 0 2006-11-20 21:10:10.186
!STACK 0
at
org.eclipse.ve.internal.java.codegen.model.BeanDeclModel.get AllMethods(BeanDeclModel.java:617)
at
org.eclipse.ve.internal.java.codegen.util.CodeGenUtil.markSa meLineExpressions(CodeGenUtil.java:1200)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(JavaSourceTranslator.java:866)
at
at
at
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-11-20 21:10:10.827
!MESSAGE IWAV0155E Introspection failed on class "javax.swing.JPanel."
msg="."
!STACK 0
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensionDocument(BeaninfoClassAdapter.java:911)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:649)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:428)
at
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:415)
at
org.eclipse.jem.java.internal.impl.JavaClassImpl.getEAnnotat ions(JavaClassImpl.java:379)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator .findDecorator(ClassDecoratorSourceIterator.java:37)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.initi alize(ClassDecoratorIterator.java:47)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator . <init>(ClassDecoratorSourceIterator.java:33)
at
org.eclipse.ve.internal.cde.emf.ClassDecoratorFeatureAccess. getDecoratorWithFeature(ClassDecoratorFeatureAccess.java:67)
at
at
at
at
at
at
at
at
!SESSION 2006-11-21 17:27:16.718
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-21 17:28:04.125
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ve.java.core 4 2 2006-11-21 17:28:14.046
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ve.java.core".
!STACK 0
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri
'http:///org/eclipse/ve/internal/cde/palette.ecore' not found.
(platform:/plugin/org.eclipse.ve.jfc/palette/javavisualbeans cats.xmi, 5,
132)
at
at
at
at
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$DefaultVEContributor.contributePalleteCats(JavaVisu alEditorPart.java:1234)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$7.run(JavaVisualEditorPart.java:1694)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup$CreateRegistry.run(JavaVisualEditorPart.java: 1685)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
with uri 'http:///org/eclipse/ve/internal/cde/palette.ecore' not found.
132)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2322)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2160)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1137)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1239)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:877)
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
at
at
at
at
at
... 7 more
!ENTRY org.eclipse.ve.java.core 4 0 2006-11-21 17:28:29.000
!STACK 0
org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'allocation'
not found.
(file:/D:/Programme/Java/Java/.metadata/.plugins/org.eclipse .core.resources/.projects/TSP/org.eclipse.ve.java.core/.cach e/emfmodel/src/ui/neu/board/NewBoardPnl.xmi,
2, 5071)
at
at
at
at
at
at
at
at
at
at
Caused by: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature
'allocation' not found.
FUDForum. Page generated in 0.04791 seconds
