No SWT items in VE [message #133104] |
Mon, 13 November 2006 19:32  |
Originally posted by: forrestline.gmail.com
I'm missing SWT items in the palette. Trying to create a new project and a
new visual class. Seems to be ok, it runs. However no SWT entries in
palette in Visual Editor.
The suggestion I found in previous threads, to create such file after
installing the plugin does not work for me, since I got the eclipse with
the plugin installed.
Sincerely,
Evgeny
Re: No SWT items in VE [message #133241 is a reply to message #133202] |
Thu, 16 November 2006 22:11  |
I tried to do as suggested with no success. Same thing.
Anything esle i could try ?
Thank you. I appreciate your help.
Re: No SWT items in VE [message #614781 is a reply to message #133104] |
Tue, 14 November 2006 10:07  |
Use the New Visual Class wizard and make sure you select an SWT style
from the Style tree. That should set up your classpath in your project
so that SWT works.
Evgeny wrote:
> a new visual class. Seems to be ok, it runs. However no SWT entries in
> Sincerely,
> Evgeny
Rich Kulp
Re: No SWT items in VE [message #614785 is a reply to message #133179] |
Tue, 14 November 2006 13:50  |
It may be confused because of the SWT that was added as a jar, try
clearing the cache first.
1) Open one VE, then close it and all other VE's.
2) Then do Project->Clear...->Clear all projects, and then wait for
build to complete.
3) Try the VE now.
Evgeny wrote:
> Thanks.
> It worked. I had to add SWT support as Library, not as external Jar.
> However I see another problem here.
> If I crate a Swing window, I get nice visual representation. But not
> with SWT.
> See the link with screenshots:
> http://www.box.net/public/b30hzdzqj6#main
> Any ideas?
> Thanks.
Rich Kulp
FUDForum. Page generated in 0.05572 seconds
