Installed VE doesn't do SWT/JFace [message #131988] |
Fri, 06 October 2006 13:04  |
"Jeff Myers" <jefmyers@us.ibm.com> wrote in message
news:e92u9j$spp$1@utils.eclipse.org...
> VE 1.2 requires Eclipse 3.2. The easiest way to install VE is to
> download Eclipse 3.2, then use the Update Manager to install VE from the
> Callisto Discovery site. Doing this will also download the required GEF
> and EMF plug-ins needed to run VE.
> Hope this helps,
> - Jeff
I have VE 1.2 and what I believe to be all of the latest versions of GEF,
EMF, Eclipse Build SDK etc. but I don't see SWT components, containers,
menus, or controls when attempting to use the VE...
Any ideas?
Re: Installed VE doesn't do SWT/JFace [message #132019 is a reply to message #131988] |
Fri, 06 October 2006 14:24   |
"Martin Thompson" <thompsma@aecl.ca> wrote in message
news:eg62bd$h9$1@utils.eclipse.org...
>> Hope this helps,
>> - Jeff
> Any ideas?
The error log indicates this might be a problem with emf core...but all
updates to installed features are up to date...
(see attached image)
!SESSION 2006-10-06
13:49:37.304 -----------------------------------------------
eclipse.buildId=M20060629-1905
java.version=1.5.0_06
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ve.java.core 4 0 2006-10-06 13:53:47.564
!MESSAGE Exception thrown.
!STACK 0
java.lang.ArrayIndexOutOfBoundsException: -1
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 14)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObjectF orURIFragmentRootSegment(ResourceImpl.java:642)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:692)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:671)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XML Handler.java:2522)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:2450)
at
org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAtt ribs(SAXXMIHandler.java:74)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:1940)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:1844)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHa ndler.java:1779)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1587)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:881)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:82)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:860)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:627)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:179)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1094)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:900)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.demandLoad(ProjectResourceSetImpl.java:83)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:390)
at
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResource(ProjectResourceSetImpl.java:262)
at
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doLoadFromCache(VEModelCacheUtility.java:103)
at
org.eclipse.ve.internal.java.codegen.core.VEModelInstance.cr eateComposition(VEModelInstance.java:100)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reConnect(JavaSourceTranslator.java:1134)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:910)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:597)
at
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1978)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Re: Installed VE doesn't do SWT/JFace [message #614697 is a reply to message #131988] |
>> Hope this helps,
>> - Jeff
> Any ideas?
!SESSION 2006-10-06
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Installed VE doesn't do SWT/JFace [message #614699 is a reply to message #132019] |
Fri, 06 October 2006 17:53  |
Try clearing the cache. You may have a bad cachce.
1) Open a VE, then close it and all VE's.
2) Run Project->Clean->Clean all and wait for build to complete
3) Try opening the VE again.
Rich Kulp
Re: Installed VE doesn't do SWT/JFace [message #614707 is a reply to message #132055] |
Wed, 11 October 2006 11:08  |
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:eg6j89$4lm$2@utils.eclipse.org...
> Rich Kulp
Thanks for the suggestion Rich... but I still get no SWT/JFace options in
the VE...
I checked the error log on bringing up Eclipse and found this... I presume
that this means that there is an EMF related problem...
I have no idea where to begin correcting the problem since I am new to
Eclipse...
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
at
Source)
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
FUDForum. Page generated in 0.05150 seconds
