Home » Archived » Visual Editor (VE) » Refreshing after correcting errors
Refreshing after correcting errors [message #130366] Fri, 25 August 2006 12:26 Go to next message
After downloading and installing calisto bundle, I noticed when I
corrected errors and saved the code in the ve, it does not refresh
anything especially the problems tab. I have to close the java file and
re-open it to refresh every thing. Has anyone experienced or reported this
problem?
Re: Refreshing after correcting errors [message #130392 is a reply to message #130366] Fri, 25 August 2006 13:20 Go to previous messageGo to next message
Originally posted by: jefmyers.us.ibm.com
Richard,
Have you turned off Build Automatically?
- Jeff
Re: Refreshing after correcting errors [message #130403 is a reply to message #130392] Fri, 25 August 2006 13:25 Go to previous messageGo to next message
Honestly, I don't know. How do I check that?
Re: Refreshing after correcting errors [message #130415 is a reply to message #130403] Fri, 25 August 2006 13:29 Go to previous messageGo to next message
nevermind, i found out. it was not checked.
Re: Refreshing after correcting errors [message #130427 is a reply to message #130415] Fri, 25 August 2006 13:35 Go to previous message
sorry, i was dense in mind. i am on vacation mode. i checked it and it
worked now. thanks.
Re: Refreshing after correcting errors [message #614576 is a reply to message #130366] Fri, 25 August 2006 13:20 Go to previous message
Richard,
- Jeff
Re: Refreshing after correcting errors [message #614577 is a reply to message #130392] Fri, 25 August 2006 13:25 Go to previous message
Re: Refreshing after correcting errors [message #614578 is a reply to message #130403] Fri, 25 August 2006 13:29 Go to previous message
Re: Refreshing after correcting errors [message #614579 is a reply to message #130415] Fri, 25 August 2006 13:35 Go to previous message
worked now. thanks.
Previous Topic:Placing logger call
Next Topic:Placing logger call
Current Time: Sat Jul 19 16:14:21 EDT 2025
Powered by FUDForum. Page generated in 0.04302 seconds
