Home » Eclipse Projects » Platform - User Assistance (UA) » Eclipse 3.4 - .war deployment of a standalone help system
Eclipse 3.4 - .war deployment of a standalone help system [message #473910] |
Wed, 11 June 2008 17:39  |
Am hoping for advice on how to package and deploy the base eclipse help
system as a .war file and package and deploy the contents for the help
system as separate components.
We are currently working on a 3.4 infocenter implementation -- the
infocenter help system is launched from a java-based web application (not
eclipse) as a help.war file. Our preferred strategy is to package the help
contents as eclipse features/plugins in one or more separate war (or jar)
files. The infocenter is launched from the web application by sending an
http request to a Web server (Jetty) which hosts the application and help
as a part of it. (https://somehost:8283/help/index.jsp). The Jetty process
unpacks the contents of each war to a separate work location, however,
when infocenter is launched, the contents pane in empty indicating that
the content plugins are not being recognized. Following are
observations/questions:
1) If all of the features/plugins for our content are packaged in the
single help.war, the help system and contents display as expected. Our
issue is occuring when we try to separate the content features/plugins
from the base help.war. Our product is a framework into which a variety of
components can be installed -- we need the flexibility to install docs to
match the installed components.
2) It appears that the "unpack" process creates a work\<jetty work
directory>\eclipse directory (a subset of the directory structure from the
help.war)--- that contains configuration, features, plugins, and
sub-folders. A platform.xml is also created in work\<jetty work
directory>\eclipse\configuration\org.eclise.update. All of this is created
before the application itself is even started, so it appears that some
sort of loading is taking place. Is this configurable?
3) The use of a links directory was attempted -- while the help.war
contained the links directory with a link file to the location of the doc
plugin, this file was not unpacked to the subset work\<jetty work
directory>\eclipse location (a full copy of the entire help.war is also
unpacked to work\<jetty work directory>\webapps\WEB-INF). Is the links
directory the right approach here? Should it be unpacked to the subset
work directory? Because some loading takes place, is it necessary to
launch with an argument (similar to -clean) that would clear that cached
information?
4) I reviewed the suggestions in bugzilla 201666 -- question about having
all of the files at the root level of the jar -- our output produces a
feature (directory) and plugin (jar -- which puts the topic files at the
root), but then I have been jar'ing the eclipse\feature and eclipse\plugin
directories to a single jar for deployment. Is this approach correct?
One final -- and basic question -- what are the benefits of .war
deployment of the help system in general?
Thanks in advance!
Kitty
Re: Eclipse 3.4 - .war deployment of a standalone help system [message #473912 is a reply to message #473911] |
Thu, 12 June 2008 15:53   |
Originally posted by: nospam_kowalskilee.gmail.com
Just to add to what Chris said, the fact that you can deploy the war
file on any web server means that if you've already got a server machine
and running a web app server on it to run your browser-based
application, then you don't have to run an additional second web app
server to run an Eclipse-based infocenter to supply the help system for
that browser-based application.
In the past, before this war version of the Eclipse help system, some
teams would be in this scenario:
- They had some Eclipse doc plug-in for their RCP (desktop) application
- They were creating a browser-based web application
- They needed a help system for the Help buttons in that web application
- They wanted to reuse the doc plug-ins from their RCP application and
not have to recreate the TOC, index, help topics, etc.
Therefore, they wanted to be able to use an Eclipse infocenter system as
the help system hooked to the Help buttons/menu in their web
application. But to do that in the past meant that you'd have to have
two web app servers running:
- one for running their browser-based web app
- second one was the Tomcat running inside the Eclipse infocenter
Having to have two web apps running on the same machine and getting them
to talk to one another caused headaches. So being able to deploy the
Eclipse infocenter into the same web app server on which the web
application is running that needs to talk to the infocenter--that is a
glorious thing. :-)
Lee Anne
Chris Goldthorpe wrote:
> Let me answer the final question first. The benefit of the war file is
> that you can deploy it on any Web Server and you can have more control
> of how you use the security features of your favorite web server.
> The help system as a war file uses the Equinox runtime to load the
> plugins and it is possible to tell Equinox to load plugins from more
> than one directory - unfortunately I have not had much luck finding the
> documentation on how that works, maybe someone else on this news group
> has more information.
Re: Eclipse 3.4 - .war deployment of a standalone help system [message #474059 is a reply to message #473910] |
Fri, 13 June 2008 07:35  |
Originally posted by: eclipse.maxant.co.uk
ive written a tutorial:
http://blog.maxant.co.uk/pebble/2008/06/09/1213043100000.htm l
cheers,
ant
"Kitty Ohman" <kohman@sybase.com> schrieb im Newsbeitrag
news:cf46c1d3fc46a9191477a5265645b84a$1@www.eclipse.org...
> Hello,
> information?
> Thanks in advance!
> Kitty
Re: Eclipse 3.4 - .war deployment of a standalone help system [message #614435 is a reply to message #473910] |
Thu, 12 June 2008 12:32  |
Re: Eclipse 3.4 - .war deployment of a standalone help system [message #614438 is a reply to message #473911] |
glorious thing. :-)
Lee Anne
Re: Eclipse 3.4 - .war deployment of a standalone help system [message #615234 is a reply to message #473910] |
cheers,
ant
> Hello,
> information?
> Thanks in advance!
> Kitty
Current Time: Sat Jul 19 07:41:44 EDT 2025
Powered by FUDForum. Page generated in 0.07758 seconds
