Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Enhancing the ECore classes
[Teneo] Enhancing the ECore classes [message #108237] Fri, 25 January 2008 10:26 Go to next message
Not sure if I missed something in the steps to create my own JPOX
persistence using Teneo, but I get this
javax.jdo.JDOUserException: Field
"org.mddl.mddl._3.impl.CallableTypeImpl.mixed" is declared as a
reference type (interface/Object) but no implementation classes of
"org.eclipse.emf.ecore.util.FeatureMap" have been found!
at
org.jpox.metadata.MetaDataUtils.getImplementationNamesForRef erenceField(MetaDataUtils.java:441)
at
org.jpox.store.rdbms.table.ColumnCreator.createColumnsForRef erenceField(ColumnCreator.java:250)
at
org.jpox.store.rdbms.table.ColumnCreator.createColumnsForFie ldUsingReference(ColumnCreator.java:224)
at
org.jpox.store.mapping.ReferenceMapping.createColumns(Refere nceMapping.java:77)
at
org.jpox.store.mapping.ReferenceMapping.initialize(Reference Mapping.java:63)
So clearly the ECore classes are not enhanced. What did I miss?
Thx.
David
Re: [Teneo] Enhancing the ECore classes [message #108251 is a reply to message #108237] Fri, 25 January 2008 10:33 Go to previous messageGo to next message
Hi David,
I am not sure if this is related to the enhancement. How does the jdo mapping look like for this field?
To give you an idea, this is a mapping for mixed which I have in one of the testcases:
<field name="mixed" persistence-modifier="persistent">
<collection element-type="org.eclipse.emf.teneo.jpox.elist.AnyFeatureMapEntry "/>
<join name="letterbodytype_mixed"/>
<element>
<embedded>
<field name="featurePath">
<column name="FEATUREPATH"/>
</field>
<field name="anyValue">
<column name="ANYVALUE"/>
</field>
</embedded>
</element>
<order column="LETTERBODYTYPE_MIXED_IDX"/>
</field>
gr. Martin
david wrote:
> at
> at
> at
> at
> at
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Enhancing the ECore classes [message #108744 is a reply to message #108251] Mon, 28 January 2008 13:43 Go to previous messageGo to next message
Not sure where you get this jdo mapping? The package.jdo produced by
Teneo does not include the ECore classes, only the classes from my own
XSD. Did I miss something? How do I include the ECore classes in the
package.jdo produced?
Thx.
David
Martin Taal wrote:
> Hi David,
> the testcases:
> <collection
> <element>
> <embedded>
> </field>
> </field>
> </embedded>
> </element>
> </field>
> gr. Martin
> david wrote:
>> Hi,
>> at
>> at
>> at
>> at
>> at
>> Thx.
>> David
Re: [Teneo] Enhancing the ECore classes [message #108758 is a reply to message #108744] Mon, 28 January 2008 14:26 Go to previous messageGo to next message
Hi David,
The testcases use programmatic creation of the jdo file. Can you try the same using:
JpoxHelper.INSTANCE.generateMapping(...).
gr. Martin
david wrote:
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> of the testcases:
>> <collection
>> <element>
>> <embedded>
>> </field>
>> </field>
>> </embedded>
>> </element>
>> </field>
>> gr. Martin
>> david wrote:
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thx.
>>> David
The Netherlands
Re: [Teneo] Enhancing the ECore classes [message #108783 is a reply to message #108758] Mon, 28 January 2008 17:23 Go to previous messageGo to next message
So does this mean that no Teneo generated JPOX can be used unless you
programatically include the ECore package.jdo generation? I did not do
the library example, but had read the documentation but did not see this
requirement, which seems a fundamental one. Surely any pacakge.jdo
produced by Teneo will require use of the ECore classes and therefore
each time the ECore classes will be require enhancing too?
Thx.
David
Martin Taal wrote:
> Hi David,
> same using: JpoxHelper.INSTANCE.generateMapping(...).
> gr. Martin
> david wrote:
>> Hi,
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> of the testcases:
>>> <collection
>>> <element>
>>> <embedded>
>>> </field>
>>> </field>
>>> </embedded>
>>> </element>
>>> </field>
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Thx.
>>>> David
Re: [Teneo] Enhancing the ECore classes [message #108808 is a reply to message #108783] Mon, 28 January 2008 17:35 Go to previous messageGo to next message
Hi David,
No it is different. For featuremap (and anytype) Teneo has its own classes (for example
org.eclipse.emf.teneo.jpox.elist.AnyFeatureMapEntry). These are located in a separate jar file
(org.eclipse.emf.teneo.jpox.enhanced.jar) which is in the org.eclipse.emf.teneo.jpox plugin.
The classes in this jar file are already enhanced and the classes are exported by the
So in a plugin environment using the org.eclipse.emf.teneo.jpox will also make these enhanced
classes available to you. Enhancing the ecore classes is therefore not required.
It seems that during package.jdo generation the featuremap/mixed is not recognized as such.
Can you post the jdo you get? If you also post your model then I can reproduce it myself. You can
also send me the model directly (mtaal@elver.org).
gr. Martin
david wrote:
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> the same using: JpoxHelper.INSTANCE.generateMapping(...).
>> gr. Martin
>> david wrote:
>>> Hi,
>>> own XSD. Did I miss something? How do I include the ECore classes in
>>> the package.jdo produced?
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> of the testcases:
>>>> <collection
>>>> <element>
>>>> <embedded>
>>>> </field>
>>>> </field>
>>>> </embedded>
>>>> </element>
>>>> </field>
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Thx.
>>>>> David
The Netherlands
Re: [Teneo] Enhancing the ECore classes [message #108822 is a reply to message #108783] Mon, 28 January 2008 17:44 Go to previous messageGo to next message
Another thing that confused me is the last item on the Troubleshooting
page. It says "Teneo uses the runtime version of the ecore model. The
runtime version is present as java code in the generated EPackage
implementation class." which made me think that that was how the ECore
classes got enhanced. But there is no sign of this EPackage generated file?
Thx.
David
david wrote:
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> of the testcases:
>>>> <collection
>>>> <element>
>>>> <embedded>
>>>> </field>
>>>> </field>
>>>> </embedded>
>>>> </element>
>>>> </field>
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Thx.
>>>>> David
Re: [Teneo] Enhancing the ECore classes [message #108835 is a reply to message #108822] Mon, 28 January 2008 18:14 Go to previous message
Hi David,
Maybe the documentation is confusing in this regard.
To give some more background info. References to the Ecore model itself are not persisted as they
are statically present in the generated code. The only exceptions are featuremap (which supports the
mixed type) and anytype. Both of these require additional fields to store a reference to the ecore
model (to an efeature). However the ecore model is not persisted because the reference to the ecore
model is persisted as a string in the db. When the object (featuremap) is read back from the db then
the string is translated to the in-memory efeature. But this is only required for featuremap.
gr. Martin
david wrote:
> Thx.
> David
> david wrote:
>> Hi,
>> this requirement, which seems a fundamental one. Surely any
>> pacakge.jdo produced by Teneo will require use of the ECore classes
>> and therefore each time the ECore classes will be require enhancing too?
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> Thx.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> <collection
>>>>> <element>
>>>>> <embedded>
>>>>> </field>
>>>>> </field>
>>>>> </embedded>
>>>>> </element>
>>>>> </field>
>>>>> gr. Martin
>>>>> david wrote:
>>>>>> Hi,
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Thx.
>>>>>> David
The Netherlands
Re: [Teneo] Enhancing the ECore classes [message #614087 is a reply to message #108237] Fri, 25 January 2008 10:33 Go to previous message
Hi David,
<element>
<embedded>
</field>
</field>
</embedded>
</element>
</field>
gr. Martin
david wrote:
> at
> at
> at
> at
> at
> Thx.
> David
The Netherlands
Re: [Teneo] Enhancing the ECore classes [message #614121 is a reply to message #108251] Mon, 28 January 2008 13:43 Go to previous message
Thx.
David
Martin Taal wrote:
> Hi David,
> the testcases:
> <collection
> <element>
> <embedded>
> </field>
> </field>
> </embedded>
> </element>
> </field>
> gr. Martin
> david wrote:
>> Hi,
>> at
>> at
>> at
>> at
>> at
>> Thx.
>> David
Re: [Teneo] Enhancing the ECore classes [message #614122 is a reply to message #108744] Mon, 28 January 2008 14:26 Go to previous message
Hi David,
gr. Martin
david wrote:
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> of the testcases:
>> <collection
>> <element>
>> <embedded>
>> </field>
>> </field>
>> </embedded>
>> </element>
>> </field>
>> gr. Martin
>> david wrote:
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thx.
>>> David
The Netherlands
Re: [Teneo] Enhancing the ECore classes [message #614124 is a reply to message #108758] Mon, 28 January 2008 17:23 Go to previous message
Thx.
David
Martin Taal wrote:
> Hi David,
> gr. Martin
> david wrote:
>> Hi,
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> of the testcases:
>>> <collection
>>> <element>
>>> <embedded>
>>> </field>
>>> </field>
>>> </embedded>
>>> </element>
>>> </field>
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Thx.
>>>> David
Re: [Teneo] Enhancing the ECore classes [message #614126 is a reply to message #108783] Mon, 28 January 2008 17:35 Go to previous message
Hi David,
gr. Martin
david wrote:
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> of the testcases:
>>>> <collection
>>>> <element>
>>>> <embedded>
>>>> </field>
>>>> </field>
>>>> </embedded>
>>>> </element>
>>>> </field>
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Thx.
>>>>> David
The Netherlands
Re: [Teneo] Enhancing the ECore classes [message #614127 is a reply to message #108783] Mon, 28 January 2008 17:44 Go to previous message
Thx.
David
david wrote:
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Thx.
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> of the testcases:
>>>> <collection
>>>> <element>
>>>> <embedded>
>>>> </field>
>>>> </field>
>>>> </embedded>
>>>> </element>
>>>> </field>
>>>> gr. Martin
>>>> david wrote:
>>>>> Hi,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Thx.
>>>>> David
Re: [Teneo] Enhancing the ECore classes [message #614128 is a reply to message #108822] Mon, 28 January 2008 18:14 Go to previous message
Hi David,
gr. Martin
david wrote:
> Thx.
> David
> david wrote:
>> Hi,
>> Thx.
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>> david wrote:
>>>> Hi,
>>>> Thx.
>>>> David
>>>> Martin Taal wrote:
>>>>> Hi David,
>>>>> <collection
>>>>> <element>
>>>>> <embedded>
>>>>> </field>
>>>>> </field>
>>>>> </embedded>
>>>>> </element>
>>>>> </field>
>>>>> gr. Martin
>>>>> david wrote:
>>>>>> Hi,
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Thx.
>>>>>> David
The Netherlands
Previous Topic:[Teneo] Bug 216658
Next Topic:[Teneo/CDO] Managing huge models / unloading parts of models
Current Time: Sat Jul 19 23:32:59 EDT 2025
Powered by FUDForum. Page generated in 0.05747 seconds
