I have problem starting the BPMN modeler [message #613899] |
Mon, 31 March 2008 07:08  |
Hi ,
I want to create a BPMN modeler with GMF .
I downloaded the "org.stp.bpmn" open source solution from the "Koders web
site", to try it(only the part of org.eclipse.stp.bpmn.*) .But when I
run it as an eclipse plugin and I open the wizard of creating a new bpmn
diagram I'm blocked in the first window and the wizard didn't display the
list of folders in which I chose to create my new bpmn diagram so I can't
either create a project.
Re: I have problem starting the BPMN modeler [message #614195 is a reply to message #614190] |
Mon, 07 April 2008 04:54   |
Originally posted by: atoulme.intalio.com
Firas,
you can look for these in the Advanced Tab.
Antoine
firas wrote:
> Hello Mr Antoine ,
> Thank you very much for disponobility and for time to help me .
> Finally I could run the project.In fact the source of the bug I had
> wasn't your code, it's a problem in GMF version I used. When I changed
> it, I will be able to run the program.
> But I still have some details that are not yet clear to me.
> In fact, when I want to visualise the details of an item in the diagram
> by doing ( Show Properties View ) , I dont have the EMF details
> (documentation ,name ,...).Only the View property appears to me.
> Could you please indicate to me what doing, to display it .
> Best regards.
> Firas
Re: I have problem starting the BPMN modeler [message #614240 is a reply to message #614209] |
Tue, 08 April 2008 05:17  |
Hello Mr Antoine ,
I would like to extend your code and have my personalised application.
In fact,I would like to add an option to any shape in diagram which
consist on
having a new tab in the Properties view in which the user can put new
properties(that he define it self) to that shape, in form of mapping
between a pair of strings.( like your "Annotation" tab).
I try to reuse the code of the annotation tab but I realise that your code
doesn't allow me to add new properties in the annotation tab (in key and
value
columns).
Could you please indicate to me what doing to let the user add all what he
wants in the columns key and values?
Thanks.
Firas.
FUDForum. Page generated in 0.07172 seconds
