Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO][0.8.0] Exception Handling
[CDO][0.8.0] Exception Handling [message #104869] Mon, 17 December 2007 22:16 Go to next message
I would like that any CDOClientRequest do not freeze if the indication have
an exception.
If an error occured in the back-end.. the application freeze because of
that.
It should react as CommitTransactionRequest and CommitTransactionIndication
Should be bullet proof.
What do you think ?
Re: [CDO][0.8.0] Exception Handling [message #104875 is a reply to message #104869] Tue, 18 December 2007 06:23 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
> an exception.
> that.
> What do you think ?
100% agreed.
Only in the recent days I thought about making requests more reliable in
both cases: success and failure. Currently there are potentially two issues:
- In case of a (server processing) failure it's left to the application
protocol to handle this case (what you complained about). In fact this
case is currently only handled by using a proper timeout value with
Request.send(channel, timeout).
- The aforementioned timeout can lead to TimeoutExceptions being thrown
although there was no failure in server processing, it just takes a bit
longer. CommitTransactionRequest is the best example (and it happened to
me when committing large transactions). More exactly the timeout value
controls, starting from the time the requesting() method has
finished/returned, if the response input stream is idle for timeout millis.
I believe there's an interesting solution for both issues: We could use
the control channel (through new API of Connector) to inform the client
about the state of the server processing, including the indicating()
method progress for the case that the real server processing happens in
the responding() method.
We should start by specifying what exactly we want to protect against!
1) Bugs in an indicating() method. There are two different kinds of bugs:
1a) Protocol bugs. The implementor of the indicating() method
incorrectly calls (or doesn't call) readXYZ() methods.
1b) Server processing failures. The implementor of the indicating()
method calls a server method that throws an uncaught exception.
2) Bugs in a responding() method. These can only be server processing
failures. The implementor of the responding() method calls a server
3) Bugs in a confirming() method. There are two different kinds of bugs:
3a) Protocol bugs. The implementor of the confirming() method
3b) Client processing failures. The implementor of the confirming()
method calls a client method that throws an uncaught exception.
4) Network failures. One of the readXYZ() calls throws a
TimeoutException or EOFException.
5) A bit pathological are client processing failures in the middle of a
requesting() execution. The client can easily be protected since
requesting is always executed in the context of the calling/sending
thread. But the data sent so far can also lead to network failures 4) in
the server!
6) Inappropriate (too early) interpretation of server processing
failures 1b) in cases where the processing simply takes longer than
expected.
Agreed so far? Any additions?
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
Re: [CDO][0.8.0] Exception Handling [message #104947 is a reply to message #104875] Tue, 18 December 2007 16:10 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=213369
"Eike Stepper" <stepper@sympedia.de> wrote in message
news:fk8air$oem$2@build.eclipse.org...
>> have an exception.
>> that.
>> What do you think ?
> 100% agreed.
> issues:
> millis.
> 1a) Protocol bugs. The implementor of the indicating() method incorrectly
> 1b) Server processing failures. The implementor of the indicating() method
> failures. The implementor of the responding() method calls a server method
> 3a) Protocol bugs. The implementor of the confirming() method incorrectly
> 3b) Client processing failures. The implementor of the confirming() method
> 4) Network failures. One of the readXYZ() calls throws a TimeoutException
> or EOFException.
> the server!
> 6) Inappropriate (too early) interpretation of server processing failures
> 1b) in cases where the processing simply takes longer than expected.
> Regards,
> Eike Stepper
Re: [CDO][0.8.0] Exception Handling [message #104967 is a reply to message #104947] Wed, 19 December 2007 00:44 Go to previous message
--------------020705000203060802020509
Simon,
I turned it into an enhancement request and marked it P1.
Are you planning to comment on the points I wrote?
Eike Stepper
>>> have an exception.
>>> that.
>>> What do you think ?
>> 100% agreed.
>> issues:
>> millis.
>> or EOFException.
>> the server!
>> Regards,
>> Eike Stepper
<html>
<head>
http-equiv="Content-Type">
</head>
Simon,<br>
<br>
I turned it into an enhancement request and marked it P1.<br>
Are you planning to comment on the points I wrote?<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/CDO">http://wiki.eclipse.org/CDO</a><br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/Net4j">http://wiki.eclipse.org/Net4j</a><br>
<br>
<br>
<br>
<blockquote cite="mid:fk9d15$70s$1@build.eclipse.org" type="cite">
<pre wrap=""><a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=213369">https://bugs.eclipse.org/bugs/show_bug.cgi?id=213369</a>
"Eike Stepper" <a class="moz-txt-link-rfc2396E" href="mailto:stepper@sympedia.de">&lt;stepper@sympedia.de&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fk8air$oem$2@build.eclipse.org">news:fk8air$oem$2@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Simon McDuff schrieb:
</pre>
<pre wrap="">I would like that any CDOClientRequest do not freeze if the indication
have an exception.
that.
What do you think ?
</pre>
</blockquote>
<pre wrap="">100% agreed.
issues:
millis.
or EOFException.
the server!
Eike Stepper
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------020705000203060802020509--
Re: [CDO][0.8.0] Exception Handling [message #612866 is a reply to message #104869] Tue, 18 December 2007 06:23 Go to previous message
> an exception.
> that.
> What do you think ?
100% agreed.
the server!
expected.
Eike Stepper
Re: [CDO][0.8.0] Exception Handling [message #612894 is a reply to message #104875] Tue, 18 December 2007 16:10 Go to previous message
>> have an exception.
>> that.
>> What do you think ?
> 100% agreed.
> issues:
> millis.
> or EOFException.
> the server!
> Regards,
> Eike Stepper
Re: [CDO][0.8.0] Exception Handling [message #612898 is a reply to message #104947] Wed, 19 December 2007 00:44 Go to previous message
Simon,
Eike Stepper
>>> have an exception.
>>> that.
>>> What do you think ?
>> 100% agreed.
>> issues:
>> millis.
>> or EOFException.
>> the server!
>> Regards,
>> Eike Stepper
<html>
<head>
</head>
Simon,<br>
<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<br>
<br>
<br>
</pre>
</pre>
have an exception.
that.
What do you think ?
</pre>
</blockquote>
issues:
millis.
or EOFException.
the server!
Eike Stepper
</pre>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Previous Topic:[cdo][0.8.0]
Next Topic:[CDO] Performance problem
Current Time: Sat Jul 19 05:02:32 EDT 2025
Powered by FUDForum. Page generated in 0.04325 seconds
