Home » Archived » Visual Editor (VE) » VE Installation Problem
VE Installation Problem [message #124553] Wed, 10 May 2006 07:48 Go to next message
Originally posted by: robert.moestl.joanneum.at
Hello!
I installed VE today. The good thing is, that I am able to run the wizard to create a visual class, but then I got a failure message like "creation of element failed ... (Unsupported major.minor version 49.0)"
What's the problem. I'm very frustrated...
Thanks in advance
Robert
Re: VE Installation Problem [message #124567 is a reply to message #124553] Wed, 10 May 2006 10:15 Go to previous messageGo to next message
This means your code was compiled using Java 1.5 byte code but it is
trying to be executed on a Java 1.4 VM.
Robert Möstl wrote:
> Hello!
> Thanks in advance
> Robert
Rich Kulp
Re: VE Installation Problem [message #124648 is a reply to message #124567] Fri, 12 May 2006 04:10 Go to previous message
Thanks for the tip.
My problem was that an Oracle client runs on my computer, which uses a version of JRE 1.4. So this version was used by the whole system allthough I have installed JRE 1.5.
For those who face a simlilar problem. I copied the path to the bin directory of my JRE 1.5 installation at the beginning of the path variable. Furthermore I created the environment variable called JAVA_HOME and set the value to the path of the base directory of my JRE 1.5 installation (not the the child bin directory!).
Kind regards
Robert
Re: VE Installation Problem [message #612862 is a reply to message #124553] Wed, 10 May 2006 10:15 Go to previous message
Robert Möstl wrote:
> Hello!
> Thanks in advance
> Robert
Rich Kulp
Re: VE Installation Problem [message #612875 is a reply to message #124567] Fri, 12 May 2006 04:10 Go to previous message
Thanks for the tip.
Kind regards
Robert
Previous Topic:How to debug a Visual Editor Parse Error
Next Topic:VE properties window stopped working
Current Time: Sun Jul 20 03:52:23 EDT 2025
Powered by FUDForum. Page generated in 0.03533 seconds
