Clearing out the bean info caches [message #612754] |
Wed, 26 April 2006 09:34 |
After making changes in the bean info of a project, the changes do not take
effect, even if I shutdown and restart eclipse.
After reading around a bit I found the following:
'Bring up a ve at least once and close it. (The following won't work
until there has been at least one VE opened in a session). Then close
all open editors, select Project->Clean...->Clean All. This will clear
out all Beaninfo caches.
For now it is important that all VE's are closed when you do this
because there is a bug that if a VE is open you would get some errors'
This does work, but I have a lot of large projects in my workspace, and
rebuilding is a time consuming process.
Often I have only made a small change to one bean info class, but still have
to go through
this process in order to test this small change.
My question is
Is there any quicker or more finer grained way of getting the bean info
caches to update?
FUDForum. Page generated in 0.03873 seconds
