Home » Archived » Visual Editor (VE) » Using GCJ Builder on M$ Windows
Using GCJ Builder on M$ Windows [message #120800] Wed, 22 March 2006 09:01 Go to next message
Originally posted by: newsgroups.eclipse.org
Hello swt folks :
i want to make native application of SWT app. ,so i downloaded GCJ
builder for this matter ,but i faced some problems with this plug-in ,so
plz ... can u help me to solve this matter ?
this is my steps for using GCJ builder :
1- i've downloaded the follwing files from :
http://www.mingw.org/download.shtml
gcc-core-3.4.5-20060117-1.tar.gz
gcc-java-3.4.5-20060117-1.tar.gz
and then extract them to :
c:\MinGW
2- i've downloaded the plug-in from :
http://gcjbuilder.sourceforge.net/download.html
and then install it normaly by follwing :
Add a new entry in:
"Window>Preferences>Java>Build Path>Classpath Variables"
Path:C:/MinGW/share/java/libgcj-3.4.5.jar
3- i've created new project depend on SWT package and then changed its
properties to:
clicked "Project>Properties" and selected "Java Build Path"
clicked "Libraries" tab and removeed "System Library" from list
clicked "Add Variable" button and select "GCJLIB"
selected main class from GCJ project settings
4- i've run my app as SWT app ,it's worked but i couldn't find any exe
file ,but i found 2 files :
makefile
makefile.template
### my questions are :
#1# are that steps is right or there is missed step ?
#2# if my steps are ok ,how i can get the exe file ?
thanks 4 u and i wish to help me .
this is make file content:
# Generated by Eclipse GCJ Builder
# http://gcjbuilder.sf.net
#global targets
ALL: main
all: main
#gcj variable
GCJ=gcj $(OPTLEVEL) $(DEBUGLEVEL) $(COMPILER_OPTIONS)
#binary output folder
BINOUT= debug
#compiler options
COMPILER_OPTIONS=
#linker options
LINKER_OPTIONS=
#object list
OBJ=MainFrame.o
#custom objects
CUSTOM_OBJ=
#jar objects
CPOBJ=
#jar so
CPSO=
#project classpath
CP="--classpath=./;"
#main class (or so output)
MAINCLASS=--main=MainFrame
#binary name (exe or so)
BIN=$(BINOUT)/NativeApp
#library path list
LIBRARYPATH=-L$(BINOUT)
#libraries (so) list
LIBRARIES=
#resource objects list
RESOB=
#compiler optimization level
OPTLEVEL= -O0
#compiler debug level
DEBUGLEVEL= -g
#object targets
%.o: %.java
$(GCJ) $(CP) -c $? -o $@
#dummy targets (depend on config)
#classpath objects target
#classpath so target
#resource objects target
#main target
main: setup $(CPOBJ) $(RESOB) $(OBJ) $(CPSO)
$(GCJ) $(LINKER_OPTIONS) $(MAINCLASS) $(CPOBJ) $(CUSTOM_OBJ) $(RESOB)
$(OBJ) -o$(BIN) $(LIBRARYPATH) $(LIBRARIES) $(CPSO)
#setup output folders
setup:
mkdir -p $(BINOUT)/resource
#clean target
clean:
rm -f `find . -name "*.o"`
rm -r $(BINOUT)
Re: Using GCJ Builder on M$ Windows [message #120802 is a reply to message #120800] Wed, 22 March 2006 11:06 Go to previous messageGo to next message
Eclipse.org wrote:
> Hello swt folks :
> c:\MinGW
> Add a new entry in:
> properties to:
> makefile
> makefile.template
i noticed that when making process starts this error message appear into
console page :
--------Build Started--------
MAKE Version 5.2 Copyright (c) 1987, 1998 Inprise Corp.
mkdir -p debug/resource
The syntax of the command is incorrect.
** error 1 ** deleting setup
Re: Using GCJ Builder on M$ Windows [message #120805 is a reply to message #120802] Wed, 22 March 2006 13:21 Go to previous message
This newsgroup is for the visual editor. Your question is about building
swt. A better place to ask quesions about swt is the
eclipse.platform.swt newsgroup.
Rich Kulp
Re: Using GCJ Builder on M$ Windows [message #612343 is a reply to message #120800] Wed, 22 March 2006 11:06 Go to previous message
Eclipse.org wrote:
> Hello swt folks :
> c:\MinGW
> Add a new entry in:
> properties to:
> makefile
> makefile.template
console page :
Re: Using GCJ Builder on M$ Windows [message #612344 is a reply to message #120802] Wed, 22 March 2006 13:21 Go to previous message
Rich Kulp
Previous Topic:Using GCJ Builder on M$ Windows
Next Topic:JFace Binding for Swing
Current Time: Sun Jul 20 02:07:45 EDT 2025
Powered by FUDForum. Page generated in 0.03649 seconds
