Home » Archived » Visual Editor (VE) » Running same project on different PCs
Running same project on different PCs [message #109875] Mon, 24 October 2005 13:45 Go to next message
Originally posted by: charles.abela.gmail.com
I have installed and am using VE on one PC. Now I want to be able to
open/update/run a project on another PC with same version of eclipse (3.1).
On both PCs I have the required plug-ins to use the VE.
Should I just import the project from one PC to another?
Cause when I did this, the VE on the second PC was not launched and neither
the palette nor the other VE related icons could be seen.
Charlie
Re: Running same project on different PCs [message #109882 is a reply to message #109875] Mon, 24 October 2005 13:52 Go to previous message
Charlie,
Select the file, then use Open With->Visual Editor from the context menu.
- Jeff
Charlie Abela wrote:
> Regards
> Charlie
Re: Running same project on different PCs [message #611233 is a reply to message #109875] Mon, 24 October 2005 13:52 Go to previous message
Charlie,
- Jeff
> Regards
> Charlie
Previous Topic:Running same project on different PCs
Next Topic:LwVCL
Current Time: Sat Jul 19 14:33:27 EDT 2025
Powered by FUDForum. Page generated in 0.03694 seconds
