Home » Archived » Visual Editor (VE) » Part of composite doesn't show when run as Java bean
Part of composite doesn't show when run as Java bean [message #100734] Fri, 29 July 2005 14:16 Go to next message
Experimenting with a composite using VE, I was changing layout managers on
some sub-containers. Now, while the VE editor window shows everything, if I
run the class as a Java Bean, part of the Composite isn't visible. Any idea
why? When run as a bean, the group labeled plugin dependencies appears
empty:
Joel
  • Attachment: VE_window.gif
    (Size: 14.49KB, Downloaded 156 times)
  • Attachment: as_bean.PNG
    (Size: 11.35KB, Downloaded 162 times)
  • Attachment: MyContent.java
    (Size: 8.59KB, Downloaded 623 times)
Re: Part of composite doesn't show when run as Java bean [message #100845 is a reply to message #100734] Fri, 29 July 2005 15:46 Go to previous message
I don't know why it shows for you because when I bring it up in the VE
it looks the same as your runtime picture.
The reason it looks that way is because "group" has no layout manager
defined on it, so all of the children controls have no position and size.
Rich Kulp
Re: Part of composite doesn't show when run as Java bean [message #610079 is a reply to message #100734] Fri, 29 July 2005 15:46 Go to previous message
Rich Kulp
Previous Topic:Part of composite doesn't show when run as Java bean
Next Topic:Another NPE and VE won't display my composite after some simple source editing.
Current Time: Sat Jul 19 05:27:54 EDT 2025
Powered by FUDForum. Page generated in 0.03559 seconds
