[Teneo] Problem with the length of element names [message #609471] |
Thu, 16 August 2007 12:21 |
I have a problem with the length of the element names in the EMF model -
Teneo complains that it cannot add class tables. I am using DB2 - is it
a specific DB2 problem or it can be fixed in Teneo?
DB2 SQLSTATE 42622 means that the name is too long.
Thanks in advance for your help.
Here is the stack trace:
[java] Exception in thread "main" javax.jdo.JDODataStoreException:
Error(s) were found while auto-creating/validating the
datastore for classes. The errors are printed in the log, and are
attached to this exception.
[java] at
org.jpox.store.rdbms.RDBMSManager$ClassAdder.verifyErrors(RD BMSManager.java:3272)
[java] at
org.jpox.store.rdbms.RDBMSManager$ClassAdder.addClassTablesA ndValidate(RDBMSManager.java:3322)
[java] at
org.jpox.store.rdbms.RDBMSManager$ClassAdder.run(RDBMSManage r.java:2554)
[java] at
org.jpox.store.rdbms.RDBMSManager$MgmtTransaction.execute(RD BMSManager.java:2406)
[java] at
org.jpox.store.rdbms.RDBMSManager.addClasses(RDBMSManager.ja va:821)
[java] at
org.eclipse.emf.teneo.jpox.JpoxDataStore.createSchema(JpoxDa taStore.java:518)
[java] at
org.eclipse.emf.teneo.jpox.JpoxDataStore.initialize(JpoxData Store.java:213)
[java] at
DatastoreInstall.initJpoxDatastore(DatastoreInstall.java:120 )
[java] at DatastoreInstall.init(DatastoreInstall.java:61)
[java] at DatastoreInstall.main(DatastoreInstall.java:327)
[java] NestedThrowablesStackTrace:
[java] com.ibm.db2.jcc.c.SqlException: DB2 SQL error: SQLCODE:
-107, SQLSTATE: 42622, SQLERRMC: MYELEMENT_CATEGORYMEMBER
;18
[java] at com.ibm.db2.jcc.c.fg.e(fg.java:1596)
[java] at com.ibm.db2.jcc.c.fg.b(fg.java:1160)
[java] at com.ibm.db2.jcc.b.gb.h(gb.java:217)
[java] at com.ibm.db2.jcc.b.gb.b(gb.java:46)
[java] at com.ibm.db2.jcc.b.w.b(w.java:40)
[java] at com.ibm.db2.jcc.b.vb.f(vb.java:118)
[java] at com.ibm.db2.jcc.c.fg.m(fg.java:1155)
[java] at com.ibm.db2.jcc.c.fg.a(fg.java:1865)
[java] at com.ibm.db2.jcc.c.fg.e(fg.java:737)
[java] at com.ibm.db2.jcc.c.fg.execute(fg.java:721)
FUDForum. Page generated in 0.03192 seconds
