[TENEO] Multiple instances using concurrently the same database? [message #609470] |
Wed, 15 August 2007 12:32 |
Originally posted by: ovcharov.us.ibm.com
This is a multipart message in MIME format.
--=_alternative 005AFF7DC2257338_=
Content-Type: text/plain; charset="US-ASCII"
I am planning to use Teneo/jpox in an environment where multiple Teneo
instances use the same database instance (DB2) at the same time. Is this
supported?
If yes, are there any restrictions or characteristics of Teneo in this
regard that I must consider? For example, are there any potential problems
with concurrent read and update operations from different Teneo instances?
Do I need to setup/configure Teneo specially for this and do I need to use
it in a special fashion? Also, a single Teneo instance - is it thread safe
or do I need to take care about synchronization?
Thank you in advance!
Stanislav Ovcharov.
Content-Type: text/html; charset="US-ASCII"
<br><font size=1 face="sans-serif">Hello,</font>
<br><font size=1 face="sans-serif"> </font>
<br><font size=1 face="sans-serif">I am planning to use Teneo/jpox in an
environment where multiple Teneo instances use the same database instance
(DB2) at the same time. Is this supported? </font>
<br>
<br><font size=1 face="sans-serif">If yes, are there any restrictions or
characteristics of Teneo in this regard that I must consider? For example,
are there any potential problems with concurrent read and update operations
from different Teneo instances? Do I need to setup/configure Teneo specially
for this and do I need to use it in a special fashion? Also, a single Teneo
instance - is it thread safe or do I need to take care about synchronization?</font>
<br>
<br><font size=1 face="sans-serif">Thank you in advance!</font>
<br><font size=1 face="sans-serif">Regards,</font>
<br><font size=1 face="sans-serif">Stanislav Ovcharov.</font>
<br>
--=_alternative 005AFF7DC2257338_=--
FUDForum. Page generated in 0.03367 seconds
