Home » Archived » Visual Editor (VE) » how to install ve 1.1?
how to install ve 1.1? [message #99659] Sat, 23 July 2005 18:10 Go to next message
Originally posted by: numerodix.gmail.com
I'm running eclipse on gentoo and I've installed eclipse3.1. I'd like to use
the visual editor but I can't for the life of me figure out how to install
it. I could not find any documentation on that on the project site. I have
tried just unzipping the zip files into /opt/eclipse-extensions-3/, which
is where portage installs them by default. When I fire up eclipse and go to
Help>About Eclipse SDK>Plug-in Details, VE1.1 is listed, along with GEF3.1
and EMF2.1.0. But when I try to open the Visual Editor, I get an error
(nullpointer if I remember correctly).
The first thing I did was to install VE (and GEF, EMF) through the built-in
update manager but I ended up with an error precluding VE from starting. I
traced that to an incompatibility between <=VE1.1 and eclipse3.1, but the
update site does not list VE1.1, so I tried taking the manual route which
failed as mentioned already.
So.. how do I install the beast?
Martin
Re: how to install ve 1.1? [message #99666 is a reply to message #99659] Sat, 23 July 2005 21:39 Go to previous messageGo to next message
Martin,
Try remove all in eclipse_home/configuration except config.ini,
restart eclipse and add extension from Help-software-updates-Manage
instalation
(right click on eclipse sdk,choose add extension and set
/opt/eclipse-extensions-3)
-clean all existing projects
I have a problems with plugin cache in eclipse 3.1, too
regards
> use the visual editor but I can't for the life of me figure out how to
> install it. I could not find any documentation on that on the project
> site. I have tried just unzipping the zip files into
> /opt/eclipse-extensions-3/, which is where portage installs them by
> default. When I fire up eclipse and go to Help>About Eclipse SDK>Plug-in
> Details, VE1.1 is listed, along with GEF3.1 and EMF2.1.0. But when I try
> to open the Visual Editor, I get an error (nullpointer if I remember
> correctly).
> built-in update manager but I ended up with an error precluding VE from
> starting. I traced that to an incompatibility between <=VE1.1 and
> eclipse3.1, but the update site does not list VE1.1, so I tried taking the
> manual route which failed as mentioned already.
> Martin
Re: how to install ve 1.1? [message #99708 is a reply to message #99666] Sat, 23 July 2005 23:00 Go to previous messageGo to next message
snpe wrote:
> Martin,
> instalation
....and make sure you start Eclipse with
$ eclipse -clean &
the first time.
Dave Orme
Visual Editor Project lead
http://www.db4o.com -- The Open-source Java Object Database
http://xswt.sf.net -- XML-based SWT page description language
Re: how to install ve 1.1? [message #99726 is a reply to message #99708] Sun, 24 July 2005 14:59 Go to previous messageGo to next message
David J. Orme wrote:
> snpe wrote:
>> Martin,
>> instalation
> $ eclipse -clean &
> the first time.
yes, I'm sure.Eclipse 3.1 cache plugins in extension location and add/change
this plugins doesn't work - I remove configuration/org.eclipse.* and it
work
eclipse 3.1 have yet another bug - build plugins/features (export) doesn't
work when exists binaries plugins with linked contents
regards
Re: how to install ve 1.1? [message #99939 is a reply to message #99726] Mon, 25 July 2005 10:35 Go to previous messageGo to next message
> work
Excellent!
Time to head to Bugzilla; I'd guess this one belongs to PDE/UI.
Dave Orme
Re: how to install ve 1.1? [message #99998 is a reply to message #99939] Mon, 25 July 2005 15:59 Go to previous message
>> add/change this plugins doesn't work - I remove
>> configuration/org.eclipse.* and it work
> Excellent!
>> doesn't work when exists binaries plugins with linked contents
I add bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=103912 before
regards
Re: how to install ve 1.1? [message #609204 is a reply to message #99659] Sat, 23 July 2005 21:39 Go to previous message
Martin,
instalation
regards
> correctly).
> Martin
Re: how to install ve 1.1? [message #609210 is a reply to message #99666] Sat, 23 July 2005 23:00 Go to previous message
snpe wrote:
> Martin,
> instalation
$ eclipse -clean &
the first time.
Dave Orme
Re: how to install ve 1.1? [message #609213 is a reply to message #99708] Sun, 24 July 2005 14:59 Go to previous message
> snpe wrote:
>> Martin,
>> instalation
> $ eclipse -clean &
> the first time.
work
regards
Re: how to install ve 1.1? [message #609231 is a reply to message #99726] Mon, 25 July 2005 10:35 Go to previous message
> work
Excellent!
Dave Orme
Re: how to install ve 1.1? [message #609235 is a reply to message #99939] Mon, 25 July 2005 15:59 Go to previous message
> Excellent!
regards
Previous Topic:Also Problems to get Ve to work
Next Topic:Problem installing ve
Current Time: Sat Jul 19 14:36:36 EDT 2025
Powered by FUDForum. Page generated in 0.09119 seconds
