Home » Archived » Visual Editor (VE) » VE throws NoClassDefFoundError
VE throws NoClassDefFoundError [message #99714] |
Sun, 24 July 2005 04:48  |
VE 1.1 throws this error when I try to open e.g. a Shell (created with
the "New Visual Class" wizard) as a visual class. I have installed
Eclipse 3.1, EMF 2.1 and GEF 3.1. And I tried to start eclipse -with
-clean. There are actually some weird errors in the log, but "Manage
configuration" tells me that everything is EMF and GEF are configured
properly.
I attached the log below. If it's not something obvious, I can file a
bug with my configuration and a simple example project - just let me know.
Later,
Chris
!SESSION 2005-07-24 10:34:26.481
eclipse.buildId=I20050627-1435
java.version=1.5.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.update.configurator 2005-07-24 10:34:35.904
!MESSAGE Could not install bundle plugins/org.eclipse.draw2d_3.1.0.jar
Bundle "org.eclipse.draw2d" version "3.1.0" has already been installed
!ENTRY org.eclipse.update.configurator 2005-07-24 10:34:36.275
plugins/org.eclipse.emf.common_2.1.0.jar Bundle
"org.eclipse.emf.common" version "2.1.0" has already been installed
!ENTRY org.eclipse.update.configurator 2005-07-24 10:34:36.525
!MESSAGE Could not install bundle plugins/org.eclipse.gef_3.1.0.jar
Bundle "org.eclipse.gef" version "3.1.0" has already been installed
!ENTRY org.eclipse.ui 4 4 2005-07-24 10:36:46.01
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-07-24 10:36:46.81
!MESSAGE org/eclipse/ve/internal/cde/core/EditDomain$ToolChangedListe ner
!STACK 0
java.lang.NoClassDefFoundError:
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:162)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:232)
at
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:252)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:837)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:543)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:365)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:126)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:391)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1102)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1051)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:12 56)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:442)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:109 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:60)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:212)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:202)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:753)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:665)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:628)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2323)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2258)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2250)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2236)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2231)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:279)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:271)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:178)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: VE throws NoClassDefFoundError [message #99779 is a reply to message #99714] |
Mon, 25 July 2005 08:35   |
Hi Chris,
Can you check the plugin list in Help>About..>Plugin details for the
plugin 'org.eclipse.ve.cde' version 1.1.0 along with other
org.eclipse.ve.* plugins version 1.1.0. Just want to make sure that
Eclipse has loaded the plugins.
Sri.
chris wrote:
> properly.
> Later,
> Chris
> from: update@plugins/org.eclipse.draw2d_3.1.0/
> from: update@plugins/org.eclipse.emf.common_2.1.0/
> from: update@plugins/org.eclipse.gef_3.1.0/
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: VE throws NoClassDefFoundError [message #99864 is a reply to message #99823] |
Mon, 25 July 2005 09:57   |
Hi Chris,
Looks like org.eclipse.ve.cde plugin is decades ahead of where it
should be. I would suggest 'eclipse -clean' again, and maybe if that
doesnt work, please try manual removal of org.eclipse.ve.cde plugins and
try to re-extract the org.eclipse.ve.cde 1.1.0 plugin again with a
-clean. Somehow your Eclipse plugins configuration seems to be out of sync.
Sri.
chris wrote:
> Hi Sri,
> there we go... kind of strange:
> org.eclipse.ve (1.0.1, 1.1.0)
> org.eclipse.ve.cde (11.0.0) (!)
> org.eclipse.ve.doc (1.1.0)
> org.eclipse.ve.java.core (1.1.0)
> org.eclipse.ve.jfc (1.1.0)
> org.eclipse.ve.propertysheet (1.0.1, 1.1.0)
> org.eclipse.ve.sdk (1.0.1, 1.1.0)
> org.eclipse.ve.source (1.1.0)
> org.eclipse.ve.swt (1.1.0)
> Those are all plugins starting with org.eclipse.ve. (1.0.1, 1.1.0) means
> that both versions are shown in the plugin details.
> Bye,
> Chris
> Sri Gunturi wrote:
>>Hi Chris,
>>Regards,
>>Sri.
Re: VE throws NoClassDefFoundError [message #99894 is a reply to message #99823] |
Mon, 25 July 2005 10:11   |
Hi Chris,
Iran also reported the same problem at
news://news.eclipse.org:119/dc2qdm$c74$1@news.eclipse.org and I have
opened defect 105013
https://bugs.eclipse.org/bugs/show_bug.cgi?id=105013 to track this
problem. Please add yourself on CC if you would like to track its progress.
Sri.
chris wrote:
> Hi Sri,
> Bye,
> Chris
> Sri Gunturi wrote:
>>Hi Chris,
>>Regards,
>>Sri.
Re: VE throws NoClassDefFoundError [message #609220 is a reply to message #99714] |
Hi Chris,
Sri.
chris wrote:
> properly.
> Later,
> Chris
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: VE throws NoClassDefFoundError [message #609223 is a reply to message #99779] |
Mon, 25 July 2005 09:45  |
Hi Sri,
Bye,
Chris
Sri Gunturi wrote:
> Hi Chris,
> Regards,
> Sri.
Re: VE throws NoClassDefFoundError [message #609226 is a reply to message #99823] |
Hi Chris,
Sri.
chris wrote:
> Hi Sri,
> Bye,
> Chris
> Sri Gunturi wrote:
>>Hi Chris,
>>Regards,
>>Sri.
Re: VE throws NoClassDefFoundError [message #609228 is a reply to message #99823] |
Hi Chris,
Sri.
chris wrote:
> Hi Sri,
> Bye,
> Chris
> Sri Gunturi wrote:
>>Hi Chris,
>>Regards,
>>Sri.
Current Time: Sat Jul 19 14:14:03 EDT 2025
Powered by FUDForum. Page generated in 0.24893 seconds
