Home » Archived » Visual Editor (VE) » Final Test Pass for 1.1
Final Test Pass for 1.1 [message #97644] Wed, 13 July 2005 12:05 Go to next message
The final test pass for VE 1.1 begins today. Please see the test pass site for
registration and the integration driver to use for testing. Look under VE 1.1
final regression test -->
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /vep-home/WebContent/docs/testpass.html
Registration is very simple... just click on the Test registration link
(http://www.eclipse.org/vep/web/testruns/110/final/), look through the list of
test cases and look for something you would like to test. The links to the
various test scripts are next to each "Test it" button. Clicking on the links
does NOT register you... it's just a reference.
When you find a test case you want to test, click on the "Test it" button next
to the test case. On the next page, type in your email address and select "Test
it" again. Don't worry... nothing gets sent to your email... this is just a way
of identifying you as the tester for this test case. A notification is sent to
the ve-dev mailing list about your registration.
Please open bugs in bugzilla
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=VE and mention what driver
you were using.
When you are complete with the test case, post your results (pass/fail and any
bugs opened) from this same page and another notification is sent to the ve-dev
mailing list.
All are welcome to participate in the test pass... even if you don't want to
register. Your feedback and comments are always welcome.
Thanks...
Peter Walker
VE Development
Re: Final Test Pass for 1.1 [message #97808 is a reply to message #97644] Thu, 14 July 2005 12:29 Go to previous messageGo to next message
Thanks for all who have been helping to test. We've fixed some bugs and
published a newer integration build:
http://download.eclipse.org/tools/ve/downloads/drops/I-I2005 0714-200507141131/index.html
Regards...
Peter Walker
VE Development
> site for registration and the integration driver to use for testing.
> Look under VE 1.1 final regression test -->
> list of test cases and look for something you would like to test. The
> links to the various test scripts are next to each "Test it" button.
> Clicking on the links does NOT register you... it's just a reference.
> button next to the test case. On the next page, type in your email
> address and select "Test it" again. Don't worry... nothing gets sent to
> your email... this is just a way of identifying you as the tester for
> this test case. A notification is sent to the ve-dev mailing list about
> your registration.
> driver you were using.
> and any bugs opened) from this same page and another notification is
> sent to the ve-dev mailing list.
> want to register. Your feedback and comments are always welcome.
> Thanks...
> Peter Walker
> VE Development
Re: Final Test Pass for 1.1 [message #97885 is a reply to message #97644] Thu, 14 July 2005 16:15 Go to previous messageGo to next message
Peter,
I have finished the JVEWRKB01 test scenario and was able to run through the
entire scenario but noticed I had a couple of errors in the .log file but
for the most part it worked as advertised. The main problem I noticed in
executing the script is that the scenario did not match the Eclipse 3.1 GUI
in a couple of places, but those were pretty obvious.
I have looked through the FAQ and other places in order to determine whether
the test passed or failed. I am inclined to say it passed with minor bugs,
but my question to you is if there is an objective set of criteria to
determine PASS/FAIL. I assume crashes or any behavior which prevents the
test scenario from being executed is a fail.
For example, if I am able to run through the entire scenario and then notice
errors in the log file, is that a fail? or a pass with minor bugs? I will
post the bugs I find on the bug submission page you mentioned.
ML
"Peter Walker" <walkerp@us.ibm.com> wrote in message
news:db3e4g$oli$1@news.eclipse.org...
> for registration and the integration driver to use for testing. Look under
> next to the test case. On the next page, type in your email address and
> select "Test it" again. Don't worry... nothing gets sent to your email...
> this is just a way of identifying you as the tester for this test case. A
> notification is sent to the ve-dev mailing list about your registration.
> any bugs opened) from this same page and another notification is sent to
> Thanks...
> Peter Walker
> VE Development
Re: Final Test Pass for 1.1 [message #97929 is a reply to message #97885] Thu, 14 July 2005 17:20 Go to previous messageGo to next message
Originally posted by: jdstinto.us.ibm.com
We usually use the metrics of 3 minor bugs or 1 major bug will fail the
test case. Major obviously would be something that prevents you from
completing, but it could include other serious issues. Sounds like if
you didn't notice there was anything wrong until you look in the log
they might be minor bugs. It would help if you could narrow them down
to the individual events that caused the messages, but sometimes this is
easier said than done.
Also, if the scenario is very out of date please open up a defect for
that and state what is wrong. That way we can fix it for the next test
pass.
Thanks for helping out!
-Jon
> ML
Re: Final Test Pass for 1.1 [message #98054 is a reply to message #97644] Fri, 15 July 2005 10:10 Go to previous messageGo to next message
Another Integration driver is now available -->
http://download.eclipse.org/tools/ve/downloads/drops/I-I2005 0715-200507150927/index.html
Regards...
Peter Walker
VE Development
> your registration.
> Thanks...
> Peter Walker
> VE Development
Re: Final Test Pass for 1.1 [message #98069 is a reply to message #97929] Fri, 15 July 2005 10:32 Go to previous messageGo to next message
I opened bug 104012 to track this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=104012
Regards...
Peter Walker
> pass.
> -Jon
>> through the entire scenario but noticed I had a couple of errors in
>> the .log file but for the most part it worked as advertised. The main
>> problem I noticed in executing the script is that the scenario did not
>> match the Eclipse 3.1 GUI in a couple of places, but those were pretty
>> obvious.
>> whether the test passed or failed. I am inclined to say it passed
>> with minor bugs, but my question to you is if there is an objective
>> set of criteria to determine PASS/FAIL. I assume crashes or any
>> behavior which prevents the test scenario from being executed is a fail.
>> notice errors in the log file, is that a fail? or a pass with minor
>> bugs? I will post the bugs I find on the bug submission page you
>> mentioned.
>> Thanks,
>> ML
Re: Final Test Pass for 1.1 [message #98417 is a reply to message #97644] Tue, 19 July 2005 10:58 Go to previous messageGo to next message
http://download.eclipse.org/tools/ve/downloads/drops/I-I2005 0719-200507190956/index.html
Regards...
Peter Walker
VE Development
> your registration.
> Thanks...
> Peter Walker
> VE Development
Re: Final Test Pass for 1.1 [message #98681 is a reply to message #97644] Wed, 20 July 2005 09:33 Go to previous message
The intent is to release VE1.1 RC1 tonight.
Re: Final Test Pass for 1.1 [message #609065 is a reply to message #97644] Thu, 14 July 2005 12:29 Go to previous message
Regards...
Peter Walker
VE Development
> your registration.
> Thanks...
> Peter Walker
> VE Development
Re: Final Test Pass for 1.1 [message #609070 is a reply to message #97644] Thu, 14 July 2005 16:15 Go to previous message
Peter,
ML
> Thanks...
> Peter Walker
> VE Development
Re: Final Test Pass for 1.1 [message #609073 is a reply to message #97885] Thu, 14 July 2005 17:20 Go to previous message
pass.
-Jon
> ML
Re: Final Test Pass for 1.1 [message #609081 is a reply to message #97644] Fri, 15 July 2005 10:10 Go to previous message
Regards...
Peter Walker
VE Development
> your registration.
> Thanks...
> Peter Walker
> VE Development
Re: Final Test Pass for 1.1 [message #609082 is a reply to message #97929] Fri, 15 July 2005 10:32 Go to previous message
Regards...
Peter Walker
> pass.
> -Jon
>> obvious.
>> mentioned.
>> Thanks,
>> ML
Re: Final Test Pass for 1.1 [message #609105 is a reply to message #97644] Tue, 19 July 2005 10:58 Go to previous message
Regards...
Peter Walker
VE Development
> your registration.
> Thanks...
> Peter Walker
> VE Development
Re: Final Test Pass for 1.1 [message #609123 is a reply to message #97644] Wed, 20 July 2005 09:33 Go to previous message
Previous Topic:An internal error occurred during: "Create Remote VM for Visual Editor for Java".
Next Topic:Integration driver I20050720 available
Current Time: Sun Jul 20 18:41:20 EDT 2025
Powered by FUDForum. Page generated in 0.08615 seconds
