Home » Archived » Visual Editor (VE) » Problems using SWT
Problems using SWT [message #609045] Tue, 12 July 2005 23:26
I've installed the versions of GEF and EMF that are attached to the
current VE build and they seem to be working correctly. My problem is
that whenever I try running one of the SWT smoke test samples, I get the
following stacktrace...
I've made sure to include the SWT library variable (even with JFace
support) on my build path. Not the jars, but the actual library. I am
using Java 1.5, but have set my compile settings to 1.4 for the project.
org.eclipse.swt.SWTException: Unable to load graphics library [GDI+ is
required] (java.lang.NoClassDefFoundError)
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.graphics.Device.checkGDIP(Device.java:175)
at org.eclipse.swt.graphics.GC.initGdip(GC.java:3193)
at org.eclipse.swt.graphics.GC.setAlpha(GC.java:3442)
at org.eclipse.draw2d.SWTGraphics.setAlpha(SWTGraphics.java:912 )
at
org.eclipse.ve.internal.cde.core.OutlineBorder.paint(Outline Border.java:68)
at org.eclipse.draw2d.Figure.paintBorder(Figure.java:1070)
at org.eclipse.draw2d.Figure.paint(Figure.java:1056)
at org.eclipse.draw2d.Figure.paintChildren(Figure.java:1091)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1123)
at org.eclipse.draw2d.Figure.paint(Figure.java:1055)
at
org.eclipse.ve.internal.cde.core.ImageFigure.paintClientArea (ImageFigure.java:112)
at
org.eclipse.draw2d.ScalableFreeformLayeredPane.paintClientAr ea(ScalableFreeformLayeredPane.java:61)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1118)
at org.eclipse.draw2d.Viewport.paintClientArea(Viewport.java:15 6)
at
org.eclipse.draw2d.DeferredUpdateManager.repairDamage(Deferr edUpdateManager.java:225)
at
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:145)
at
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateManager.java:40)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Previous Topic:How does VE render beans at design time?
Next Topic:SWT menus
Current Time: Sun Jul 20 09:30:31 EDT 2025
Powered by FUDForum. Page generated in 0.23649 seconds
