Home » Archived » Visual Editor (VE) » Eclipse VE and 3.1
Eclipse VE and 3.1 [message #97220] Mon, 11 July 2005 10:10 Go to next message
Originally posted by: mike.nowhere.com
I am having problems getting the ve to run too. I downloaded and
installed the components from
http://download.eclipse.org/tools/ve/downloads/drops/I-I2005 0710-200507102021/index.html
I have:
eclipse-SDK-3.1-win32.zip
emf-sdo-runtime-2.1.0.zip
GEF-runtime-3.1.zip
VE-runtime-I20050710.zip
I started eclipse with -clean and the create visual class is not
available. Under preferences it does not show a visual editor. I believe
I have downloaded the correct files. Is there something else I should do
besides just extracting the zip files? Do I need to register or import
something?
Thanks for any help
Mike
Re: Eclipse VE and 3.1 [message #97239 is a reply to message #97220] Mon, 11 July 2005 10:44 Go to previous messageGo to next message
Originally posted by: ptournet.nojunkmail-win-design.com
I got the same problem (under XP), and here is how I got it work for me :
- first install Eclipse 3.1
- extract the GEF and VE files in the Eclipse directory
- launch Eclipse and go in "Software Updates/Find and Install"
- add a new site ("EMF / SDO / XSD Secondary Update Manager Site for Eclipse
3.x" - http://download.eclipse.org/tools/emf/updates/site-release.x ml)
- use it to install EMF 2.1.0
If I first install EMF 2.1.0 this way, I am unable to install the two other
plugins just by extracting files in the Eclipse directory. If someone has an
explanation for that, I would be glad to hear it...
My 2 cents,
Patrick
"Mike" <mike@nowhere.com> a
Re: Eclipse VE and 3.1 [message #97284 is a reply to message #97220] Mon, 11 July 2005 11:58 Go to previous messageGo to next message
Take a look at the .log file. Where there any errors in it?
> I have:
> GEF-runtime-3.1.zip
> believe I have downloaded the correct files. Is there something else I
> should do besides just extracting the zip files? Do I need to register
> or import something?
> Thanks for any help
> Mike
Rich Kulp
Re: Eclipse VE and 3.1 [message #97297 is a reply to message #97284] Mon, 11 July 2005 14:12 Go to previous messageGo to next message
Where is the log?
As I said I am new to Java and to eclipse/
Mike
Re: Eclipse VE and 3.1 [message #97310 is a reply to message #97297] Mon, 11 July 2005 14:17 Go to previous messageGo to next message
Open Window->Show View->Error Log.
If Error Log is not shown, then go to
Show View->Other...->PDE Runtime->Error Log
Mike wrote:
> Where is the log?
> Mike
Rich Kulp
Re: Eclipse VE and 3.1 [message #97323 is a reply to message #97239] Mon, 11 July 2005 14:44 Go to previous messageGo to next message
There is nothing in either log, I mean nothing. This is a very "fresh"
install. I did it this AM. I have not tried what Nag suggested yet. I
didn't want to uninstall again.
Thanks for your help
Mike
Re: Eclipse VE and 3.1 [message #97337 is a reply to message #97310] Mon, 11 July 2005 14:54 Go to previous messageGo to next message
Mike
Re: Eclipse VE and 3.1 [message #97365 is a reply to message #97239] Tue, 12 July 2005 08:24 Go to previous messageGo to next message
I did everything exactly as you suggested and no joy. Any other ideas? I
don't see how so many people can have issued getting this thing installed.
I have been trying for days with 7 or 8 deletes and reinstalls. What a
PITA.
Mike
Re: Eclipse VE and 3.1 [message #97378 is a reply to message #97365] Tue, 12 July 2005 09:58 Go to previous messageGo to next message
Originally posted by: nozz.telefonica.net
Are you using MyEclipse plug-in (4.0 M2) ? I've get some troubles to
install VE 3.1 until I've unistalled this plug-in, installed VE, then
reinstalled MyEclipse...
This has solved my installation errors.
regards,
nozz
> I don't see how so many people can have issued getting this thing
> installed. I have been trying for days with 7 or 8 deletes and
> reinstalls. What a PITA.
> Mike
Re: Eclipse VE and 3.1 [message #97408 is a reply to message #97337] Tue, 12 July 2005 12:20 Go to previous messageGo to next message
Originally posted by: huy.nguyen.phdmedical.com
i'm having the same problem with VE...
VE 1.1.0
GEF 3.1.0
EMF 2.1.0
eclipse sdk 3.1.0
when i create a visual class i get the following msg
Creation of element failed.
org/eclipse/emf/codegen/jet/JETException
any hints would be greatly appreciated
Re: Eclipse VE and 3.1 [message #97438 is a reply to message #97378] Tue, 12 July 2005 14:44 Go to previous messageGo to next message
No I was only trying to get VE up and running. I finally deleted
everything and downloaded the components from here
Good news this worked. I can now do development using VE. If it was
this hard to get it installed I don't stand a chance at getting anything
developed. Back to Microsoft.
Mike
Re: Eclipse VE and 3.1 [message #97461 is a reply to message #97438] Tue, 12 July 2005 16:04 Go to previous message
The problem is you are working with development drivers (especially of
VE). Development drivers have very particular requirements that keep
changing. If they aren't exactly meet then things won't work.
When we release the VE 1.1, then the update manager can be used and
things will work correctly.
> Mike
Rich Kulp
Re: Eclipse VE and 3.1 [message #609027 is a reply to message #97220] Mon, 11 July 2005 10:44 Go to previous message
My 2 cents,
Patrick
Re: Eclipse VE and 3.1 [message #609030 is a reply to message #97220] Mon, 11 July 2005 11:58 Go to previous message
> I have:
> GEF-runtime-3.1.zip
> Thanks for any help
> Mike
Rich Kulp
Re: Eclipse VE and 3.1 [message #609031 is a reply to message #97284] Mon, 11 July 2005 14:12 Go to previous message
Where is the log?
Mike
Re: Eclipse VE and 3.1 [message #609032 is a reply to message #97297] Mon, 11 July 2005 14:17 Go to previous message
Mike wrote:
> Where is the log?
> Mike
Rich Kulp
Re: Eclipse VE and 3.1 [message #609033 is a reply to message #97239] Mon, 11 July 2005 14:44 Go to previous message
Mike
Re: Eclipse VE and 3.1 [message #609034 is a reply to message #97310] Mon, 11 July 2005 14:54 Go to previous message
Mike
Re: Eclipse VE and 3.1 [message #609036 is a reply to message #97239] Tue, 12 July 2005 08:24 Go to previous message
PITA.
Mike
Re: Eclipse VE and 3.1 [message #609037 is a reply to message #97365] Tue, 12 July 2005 09:58 Go to previous message
regards,
nozz
> Mike
Re: Eclipse VE and 3.1 [message #609039 is a reply to message #97337] Tue, 12 July 2005 12:20 Go to previous message
VE 1.1.0
GEF 3.1.0
EMF 2.1.0
eclipse sdk 3.1.0
Re: Eclipse VE and 3.1 [message #609041 is a reply to message #97378] Tue, 12 July 2005 14:44 Go to previous message
Mike
Re: Eclipse VE and 3.1 [message #609042 is a reply to message #97438] Tue, 12 July 2005 16:04 Go to previous message
> Mike
Rich Kulp
Previous Topic:SpecPkgR Questions
Next Topic:How does VE render beans at design time?
Current Time: Sat Jul 19 23:48:41 EDT 2025
Powered by FUDForum. Page generated in 0.32072 seconds
