VE properties tab is empty [message #96529] |
Thu, 07 July 2005 10:05  |
Originally posted by: ath.steinheim.com
When I click on a Shell-Object in the VE-view or the JavaBeans-Tab, the
properties-tab is empty. Instead I get the following errors in the
error-log:
!ENTRY org.eclipse.ui 4 4 2005-07-07 10:45:08.241
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-07-07 10:45:08.241
!MESSAGE Failed to execute runnable (java.lang.ClassCastException:
org.eclipse.emf.ecore.impl.EClassImpl)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EClassImpl)
at org.eclipse.swt.SWT.error(SWT.java:2942)
at org.eclipse.swt.SWT.error(SWT.java:2865)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3057)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2716)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.lang.ClassCastException:
at
org.eclipse.ve.internal.java.core.BeanProxyAdapter.getBeanPr opertyValue(BeanProxyAdapter.java:1373)
at
org.eclipse.ve.internal.java.core.BeanPropertySourceAdapter. getPropertyValue(BeanPropertySourceAdapter.java:93)
at
org.eclipse.ve.internal.swt.WidgetPropertySourceAdapter.getP ropertyValue(WidgetPropertySourceAdapter.java:365)
at
org.eclipse.ve.internal.propertysheet.command.CommandStackPr opertySheetEntry.primGetValues(CommandStackPropertySheetEntr y.java:173)
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshValues(AbstractPropertySheetEntry.java:892)
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:823 )
at
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1028)
at
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:875)
at
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:392)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
at
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 18 more
Am I doing something wrong, or is it a problem with VE?
Andreas
Re: Found a fix ... [message #97016 is a reply to message #96705] |
Fri, 08 July 2005 09:47  |
Andreas Thierer wrote:
> Sorry, but I have worked on and can't reproduce the error - even with a
> new class. It seems like magic, but I can now switch between JDK 1.4.2
> and 1.5...
> Rich Kulp wrote:
>> Thanks for the info. We are trying to figure how to at least tolerate
>> 1.5 (i.e. ignore the things we don't understand like generics, enums,
>> and annotations) rather than crashing.
>> By the way, could you please append the class that was causing the
>> problem? That way we can test it out on our changes for 1.5 to make
>> sure it will work.
Did you file defined 1.5 annotation class? see https://bugs.eclipse.org/bugs/show_bug.cgi?id=76944
Re: VE properties tab is empty [message #608986 is a reply to message #96529] |
Thu, 07 July 2005 10:09  |
Sorry, I forgot to post some further informations:
Eclipse Platform
Version: 3.1.0
Build id: I20050627-1435
Eclipse Graphical Editing Framework
Version: 3.1
Build id: 200506300200
Visual Editor
Version: 1.1.0
Build id: 200506301538
Re: VE properties tab is empty [message #608987 is a reply to message #96545] |
Thu, 07 July 2005 11:08  |
We've never seen that and it shouldn't occur. What EMF are you using?
Also try
1) Bring up a VE editor
2) Close the editor
3) Do a Projects->Clean...->Clean all projects
4) Reopen the editor
I'm thinking they may be some old stuff laying around.
> Eclipse Platform
> Version: 3.1.0
> Version: 3.1
> Visual Editor
> Version: 1.1.0
Rich Kulp
Re: VE properties tab is empty [message #608989 is a reply to message #96558] |
Thu, 07 July 2005 12:08  |
Thanks for the quick answer. Project cleanup did not help.
BTW it's a new installation. Just Eclipse and VE.
Eclipse Modeling Framework (EMF)
Version: 2.1.0.I200506230200
When I simply open my project (a simple Shell, currently nothing more), VE
shows up but I get the following message in the error log:
Error 2005-07-07 13:06:05.691 Exception thrown.
at
org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSetting Delegate(EStructuralFeatureImpl.java:790)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate (BasicEObjectImpl.java:822)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eDynamicIsSet(Ba sicEObjectImpl.java:609)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:600)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:951)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2272)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:889)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2001)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1221)
at
at
org.eclipse.emf.ecore.xmi.impl.XMISaveImpl.writeTopObjects(X MISaveImpl.java:78)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:478)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:206)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:193)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:893)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:813)
at
org.eclipse.ve.internal.java.codegen.util.VEModelCacheUtilit y.doSaveCache(VEModelCacheUtility.java:158)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.doSave(JavaSourceTranslator.java:1349)
at
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or$2.doRun(JavaSourceTranslator.java:917)
at
org.eclipse.ve.internal.java.codegen.util.ReverseParserJob.r un(ReverseParserJob.java:56)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
eclipse.buildId=I20050627-1435
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
Andreas
Found a fix ... [message #608990 is a reply to message #96585] |
Thu, 07 July 2005 13:36  |
I simply changed the JDK compliance to 1.4 and pointed the active JDK to
1.4.2 instead of 1.5.
Greetings,
Andreas
Re: Found a fix ... [message #608991 is a reply to message #96599] |
Thu, 07 July 2005 13:40  |
problem? That way we can test it out on our changes for 1.5 to make sure
it will work.
> Greetings,
> Andreas
Rich Kulp
Re: Found a fix ... [message #608997 is a reply to message #96614] |
Thu, 07 July 2005 14:48  |
new class. It seems like magic, but I can now switch between JDK 1.4.2 and
1.5...
> it will work.
Re: Found a fix ... [message #609012 is a reply to message #96705] |
> and 1.5...
>> sure it will work.
FUDForum. Page generated in 0.26754 seconds
