Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] too long comment
[Teneo] too long comment [message #91025] Fri, 20 July 2007 04:13 Go to next message
Unsuccessful: create table Too long comment for table
How I can disable comment?
Re: [Teneo] too long comment [message #91040 is a reply to message #91025] Fri, 20 July 2007 04:25 Go to previous messageGo to next message
Comments are new so therefor it now appears. There is no option for that (yet). Can you enter a
bugzilla for this?
For now if the comment is a primitive field then you have to subclass
BasicMapper and override this method:
protected Element addCommentElement(EModelElement eModelElement, Element hbmElement) {
and just return null.
You can set your BasicMapper as an Extension.
If the long comment is in a onetomany then the OneToManyMapper has to be extended etc.
Btw, I tested your case before this last release and it worked on mysql.
For my interest how large is the length constraint for the comment?
gr. Martin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] too long comment [message #91054 is a reply to message #91040] Fri, 20 July 2007 05:32 Go to previous messageGo to next message
A comment for a column can be specified with the COMMENT option, up to 255
characters long. (http://dev.mysql.com/doc/refman/5.0/en/create-table.html)
in bugzila:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=197273
Re: [Teneo] too long comment [message #91064 is a reply to message #91054] Fri, 20 July 2007 05:42 Go to previous messageGo to next message
Okay, I was not aware that there was even a comment length constraint in a db. I will probably add a
comment_max_length option which has default value 0 (=no comment as a default). As comments
apparently can result in low level db errors I prefer to disable it as a default.
gr. Martin
> in bugzila:
The Netherlands
Re: [Teneo] too long comment [message #91095 is a reply to message #91054] Fri, 20 July 2007 05:54 Go to previous messageGo to next message
I did all what you say, where mistakes?:
final ExtensionManager extensionManager = hds.getExtensionManager();
extensionManager.registerExtension(BasicMapper.class.getName (),
BasicMapperEx.class.getName());
extensionManager.registerExtension(OneToManyMapper.class.get Name(),
OneToManyMapperEx.class.getName());
hds.initialize();
public class BasicMapperEx extends BasicMapper{
/* (non-Javadoc)
* @see
org.eclipse.emf.teneo.hibernate.mapper.AbstractMapper#addCom mentElement(org.eclipse.emf.ecore.EModelElement,
org.eclipse.emf.teneo.simpledom.Element)
protected Element addCommentElement(EModelElement modelElement,
Element hbmElement)
return null;
public class OneToManyMapperEx extends OneToManyMapper{
/* (non-Javadoc)
* @see
Element hbmElement)
return null;
I have comment and haven't table )))
Re: [Teneo] too long comment [message #91110 is a reply to message #91095] Fri, 20 July 2007 06:01 Go to previous messageGo to next message
If the comment is on a many-to-one you also have to override the ManyToOneMapper, the same for
ManyToMany.
In the future I will move these utility methods to a separate utility class which can be replaced by
itself. That's easier than overriding all these subclasses.
gr. Martin
> hds.initialize();
> /* (non-Javadoc)
> * @see
> @Override
> Element hbmElement)
> return null;
> /* (non-Javadoc)
> * @see
> @Override
> Element hbmElement)
> return null;
The Netherlands
Re: [Teneo] too long comment [message #91125 is a reply to message #91110] Fri, 20 July 2007 06:17 Go to previous message
:) I did what you say:
extensionManager.registerExtension(ManyToOneMapper.class.get Name(),
ManyToOneMapperEx.class.getName());
extensionManager.registerExtension(ManyToManyMapper.class.ge tName(),
ManyToManyMapperEx.class.getName());
I check, extension work (return null from function)..
27563 [main] ERROR org.hibernate.tool.hbm2ddl.SchemaUpdate - Unsuccessful:
create table `cstmconditiondocmentstype` (`documentbasetype_e_id` bigint not
null, `linenumber` numeric(2,2), `sublinenumber` varchar(2),
`documentmodecode` varchar(4), `informationcode` varchar(2), `perioddate`
date not null, `conditiondate` date, `saledate` date, `presentingdate` date,
`goodsstatus` varchar(1), `repairstatus` bit, primary key
(`documentbasetype_e_id`)) comment='???????? ? ??????????, ??????????? ? ?.
9.1 -9.6 ?? ??????????? ???????, ????? ??? ???????????? ? ???????? ?????????
27563 [main] ERROR org.hibernate.tool.hbm2ddl.SchemaUpdate - Too long
comment for table 'cstmconditiondocmentstype'
Re: [Teneo] too long comment [message #91140 is a reply to message #91125] Fri, 20 July 2007 06:17 Go to previous message
And there is EntityMapper, IdMapper and ManyAttributeMapper. I think it is the EntityMapper as the
error seems to be on the table name.
Hmmm, I see now that your first post already mentioned this, I should have looked better...
gr. Martin
The Netherlands
Re: [Teneo] too long comment [message #608829 is a reply to message #91025] Fri, 20 July 2007 04:25 Go to previous message
bugzilla for this?
gr. Martin
The Netherlands
Re: [Teneo] too long comment [message #608830 is a reply to message #91040] Fri, 20 July 2007 05:32 Go to previous message
in bugzila:
Re: [Teneo] too long comment [message #608831 is a reply to message #91054] Fri, 20 July 2007 05:42 Go to previous message
gr. Martin
> in bugzila:
The Netherlands
Re: [Teneo] too long comment [message #608833 is a reply to message #91054] Fri, 20 July 2007 05:54 Go to previous message
hds.initialize();
/* (non-Javadoc)
* @see
Element hbmElement)
return null;
/* (non-Javadoc)
* @see
Element hbmElement)
return null;
Re: [Teneo] too long comment [message #608834 is a reply to message #91095] Fri, 20 July 2007 06:01 Go to previous message
ManyToMany.
gr. Martin
> hds.initialize();
> /* (non-Javadoc)
> * @see
> @Override
> Element hbmElement)
> return null;
> /* (non-Javadoc)
> * @see
> @Override
> Element hbmElement)
> return null;
The Netherlands
Re: [Teneo] too long comment [message #608835 is a reply to message #91110] Fri, 20 July 2007 06:17 Go to previous message
Re: [Teneo] too long comment [message #608836 is a reply to message #91125] Fri, 20 July 2007 06:17 Go to previous message
gr. Martin
The Netherlands
Previous Topic:Latest build Teneo, backward compatibility
Next Topic:[EMF Compare] StructureViewer and LabelProvider
Current Time: Sat Jul 19 06:38:18 EDT 2025
Powered by FUDForum. Page generated in 0.06633 seconds
