Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo]Problems when deleting object
[Teneo]Problems when deleting object [message #88756] Tue, 10 July 2007 12:01 Go to next message
Originally posted by: doux.guil.gmail.com
--------------010107060802050301020403
Hello List,
I'm new on Teneo and I'm experiencing problems.
I'm using Teneo to store EPackage. But when I want to delete a package
from the datastore, I obtain an exception :
org.hibernate.LazyInitializationException: illegal access to
loading collection
The only solution that I have found is to do a loop on all the contents
of the package, but it's not very optimized.
I have read that's because Teneo load only the thing that where usefull
with the lazy loading but I don't have found a best solution.
Anyone can help me ?
Guillaume
PS : The files of the exceptions and of the code are join to this post.
I'm on eclipse 3.3 and Teneo 0.8
Content-Type: text/x-java;
name="code.java"
Content-Disposition: inline;
filename="code.java"
final Properties props = new Properties();
props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
props.setProperty(Environment.USER, usr);
props.setProperty(Environment.URL, "jdbc:mysql://127.0.0.1:3306/" + dbname);
props.setProperty(Environment.PASS, pwd);
props.setProperty(Environment.DIALECT, org.hibernate.dialect.MySQLInnoDBDialect.class.getName());
props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, InheritanceType.SINGLE_TABLE_LITERAL.getName());
// create the HbDataStore
hbds = HbHelper.INSTANCE.createRegisterDataStore(hbName);
// set the relational database to use and other properties
hbds.setHibernateProperties(props);
EPackage[] tpack = new EPackage[]{EcorePackage.eINSTANCE};
// configure EPackage used in this datastore
hbds.setEPackages(tpack);
hbds.initialize();
String uristr = "hibernate://?" + HibernateResource.DS_NAME_PARAM +
"=" + hbName+"&loadStrategy=addToContents&query1 =FROM "+rootelem+" WHERE e_id="+e_id;
Resource res = resTeneo.createResource(URI.createURI(uristr));
res.load(Collections.EMPTY_MAP);
EPackage delme = (EPackage) res.getContents().get(0);
// The loop that i must add to avoid the exception
// TreeIterator<EObject> it = delme.eAllContents();
// while(it.hasNext()){
// EObject eo = it.next();
res.getContents().clear();
res.save(null); // here come the exception
name="exception.txt"
filename="exception.txt"
org.eclipse.emf.teneo.hibernate.HbMapperException: Exception when saving
resource MySF
at
org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:353)
at org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:362)
at test.newtest.delPackageFromTeneo(newtest.java:353)
at test.newtest.deleteMetaModel(newtest.java:313)
at test.newtest.main(newtest.java:714)
Caused by: org.hibernate.LazyInitializationException: illegal access to
loading collection
at
org.hibernate.collection.AbstractPersistentCollection.initia lize(AbstractPersistentCollection.java:341)
at
org.hibernate.collection.AbstractPersistentCollection.read(A bstractPersistentCollection.java:86)
at org.hibernate.collection.PersistentList.toArray(PersistentLi st.java:123)
at
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableEList.doLoad(HibernatePersistableEList.java:133)
at
org.eclipse.emf.teneo.mapping.elist.PersistableEList.load(Pe rsistableEList.java:199)
at
org.eclipse.emf.teneo.mapping.elist.PersistableEList.delegat eIndexOf(PersistableEList.java:357)
at
org.eclipse.emf.common.util.DelegatingEList.indexOf(Delegati ngEList.java:305)
at
org.eclipse.emf.ecore.util.DelegatingEcoreEList.indexOf(Dele gatingEcoreEList.java:506)
at
org.eclipse.emf.ecore.impl.EGenericTypeImpl.setERawType(EGen ericTypeImpl.java:331)
at
org.eclipse.emf.ecore.impl.EGenericTypeImpl.setEClassifier(E GenericTypeImpl.java:586)
at
org.eclipse.emf.ecore.impl.EGenericTypeImpl.eSet(EGenericTyp eImpl.java:667)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1061)
at
org.eclipse.emf.teneo.hibernate.mapping.property.EReferenceP ropertyHandler.set(EReferencePropertyHandler.java:133)
at
org.hibernate.tuple.entity.AbstractEntityTuplizer.setPropert yValues(AbstractEntityTuplizer.java:337)
at
org.hibernate.persister.entity.AbstractEntityPersister.setPr opertyValues(AbstractEntityPersister.java:3499)
--------------010107060802050301020403--
Re: [Teneo]Problems when deleting object [message #88860 is a reply to message #88756] Tue, 10 July 2007 15:40 Go to previous messageGo to next message
Hi Guillaume,
I am making some larger changes to Teneo at the moment so I can't yet retest your case. I will be
able to look at your question tomorrow. In the meantime, I noticed that the first part of the
stacktrace was missing. Can you post the complete stacktrace?
gr. Maritn
doux guillaume wrote:
> Hello List,
> loading collection
> Thanks
> Guillaume
> hbds.initialize();
> resource MySF
> at
> loading collection
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo]Problems when deleting object [message #88935 is a reply to message #88860] Wed, 11 July 2007 04:47 Go to previous messageGo to next message
--------------070604070406000000010605
Martin Taal wrote:
> Hi Guillaume,
> retest your case. I will be able to look at your question tomorrow. In
> the meantime, I noticed that the first part of the stacktrace was
> gr. Maritn
I post the complete stacktrace that eclipse give me, it left the 2 last
call, but I don't know how to get it, I will try to get a best one.
I have also see that the problem didn't come if I try to delete a
package with one level of content, like this primitive type EPackage :
<ecore:EPackage name="PrimitiveTypes" nsURI="atl.primitive.type"
nsPrefix="ptyp">
<eClassifiers xsi:type="ecore:EDataType" name="Boolean"
instanceClassName="boolean"/>
<eClassifiers xsi:type="ecore:EDataType" name="Integer"
instanceClassName="int"/>
<eClassifiers xsi:type="ecore:EDataType" name="String"
instanceClassName="java.lang.String"/>
</ecore:EPackage>
But when I try with more complex package with more than one level like :
<ecore:EPackage name="rpm" nsURI="my.rpm.model" nsPrefix="rpm">
<eClassifiers xsi:type="ecore:EClass" name="Rpm">
<eStructuralFeatures xsi:type="ecore:EReference" name="lead"
ordered="false"
lowerBound="1" eType="#/1/Lead" containment="true"
eOpposite="#/1/Lead/rpml"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="head"
ordered="false"
lowerBound="1" eType="#/1/Header" containment="true"
eOpposite="#/1/Header/rpmh"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="signature"
ordered="false"
lowerBound="1" eType="#/1/Signature" containment="true"
eOpposite="#/1/Signature/rpms"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="archive"
ordered="false"
lowerBound="1" eType="#/1/Arch" containment="true"
eOpposite="#/1/Arch/rpma"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="name"
ordered="false"
lowerBound="1" eType="#/1/Filename" containment="true"
eOpposite="#/1/Filename/rpmn"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Lead">
<eStructuralFeatures xsi:type="ecore:EReference" name="rpml"
ordered="false"
lowerBound="1" eType="#/1/Rpm" eOpposite="#/1/Rpm/lead"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="magic"
ordered="false"
unique="false" lowerBound="1" eType="#/0/String"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="major"
ordered="false"
It doesn't work and I have my exception.
Thank you to help me,
Guillaume
name="except.txt"
filename="except.txt"
log4j:WARN No appenders could be found for logger (org.eclipse.emf.teneo.hibernate.HbHelper).
log4j:WARN Please initialize the log4j system properly.
Exception in thread "main" org.eclipse.emf.teneo.hibernate.HbMapperException: Exception when saving resource MySF
at org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:353)
at test.delete.main(delete.java:72)
Caused by: org.hibernate.LazyInitializationException: illegal access to loading collection
at org.hibernate.collection.AbstractPersistentCollection.initia lize(AbstractPersistentCollection.java:341)
at org.hibernate.collection.AbstractPersistentCollection.read(A bstractPersistentCollection.java:86)
at org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableEList.doLoad(HibernatePersistableEList.java:133)
at org.eclipse.emf.teneo.mapping.elist.PersistableEList.load(Pe rsistableEList.java:199)
at org.eclipse.emf.teneo.mapping.elist.PersistableEList.delegat eIndexOf(PersistableEList.java:357)
at org.eclipse.emf.common.util.DelegatingEList.indexOf(Delegati ngEList.java:305)
at org.eclipse.emf.ecore.util.DelegatingEcoreEList.indexOf(Dele gatingEcoreEList.java:506)
at org.eclipse.emf.ecore.impl.EGenericTypeImpl.setERawType(EGen ericTypeImpl.java:331)
at org.eclipse.emf.ecore.impl.EGenericTypeImpl.setEClassifier(E GenericTypeImpl.java:586)
at org.eclipse.emf.ecore.impl.EGenericTypeImpl.eSet(EGenericTyp eImpl.java:667)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1061)
at org.eclipse.emf.teneo.hibernate.mapping.property.EReferenceP ropertyHandler.set(EReferencePropertyHandler.java:133)
at org.hibernate.tuple.entity.AbstractEntityTuplizer.setPropert yValues(AbstractEntityTuplizer.java:337)
at org.hibernate.persister.entity.AbstractEntityPersister.setPr opertyValues(AbstractEntityPersister.java:3499)
at org.hibernate.engine.TwoPhaseLoad.initializeEntity(TwoPhaseL oad.java:129)
at org.hibernate.loader.Loader.initializeEntitiesAndCollections (Loader.java:842)
at org.hibernate.loader.Loader.doQuery(Loader.java:717)
at org.hibernate.loader.Loader.doQueryAndInitializeNonLazyColle ctions(Loader.java:224)
at org.hibernate.loader.Loader.loadCollection(Loader.java:1931)
at org.hibernate.loader.collection.CollectionLoader.initialize( CollectionLoader.java:36)
at org.hibernate.persister.collection.AbstractCollectionPersist er.initialize(AbstractCollectionPersister.java:565)
at org.hibernate.event.def.DefaultInitializeCollectionEventList ener.onInitializeCollection(DefaultInitializeCollectionEvent Listener.java:60)
at org.hibernate.impl.SessionImpl.initializeCollection(SessionI mpl.java:1716)
at org.hibernate.collection.AbstractPersistentCollection.initia lize(AbstractPersistentCollection.java:344)
at org.hibernate.collection.PersistentList.iterator(PersistentL ist.java:115)
at org.hibernate.type.CollectionType.getElementsIterator(Collec tionType.java:201)
at org.hibernate.type.CollectionType.getElementsIterator(Collec tionType.java:193)
at org.hibernate.engine.CascadingAction.getAllElementsIterator( CascadingAction.java:415)
at org.hibernate.engine.CascadingAction.access$100(CascadingAct ion.java:27)
at org.hibernate.engine.CascadingAction$2.getCascadableChildren Iterator(CascadingAction.java:125)
at org.hibernate.engine.Cascade.cascadeCollectionElements(Casca de.java:294)
at org.hibernate.engine.Cascade.cascadeCollection(Cascade.java: 242)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :219)
at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:16 9)
at org.hibernate.engine.Cascade.cascade(Cascade.java:130)
at org.hibernate.event.def.DefaultDeleteEventListener.cascadeBe foreDelete(DefaultDeleteEventListener.java:272)
at org.hibernate.event.def.DefaultDeleteEventListener.deleteEnt ity(DefaultDeleteEventListener.java:220)
at org.hibernate.event.def.DefaultDeleteEventListener.onDelete( DefaultDeleteEventListener.java:128)
at org.hibernate.impl.SessionImpl.fireDelete(SessionImpl.java:7 75)
at org.hibernate.impl.SessionImpl.delete(SessionImpl.java:758)
at org.hibernate.engine.CascadingAction$2.cascade(CascadingActi on.java:121)
at org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:268)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :216)
at org.hibernate.engine.Cascade.cascadeCollectionElements(Casca de.java:296)
at org.hibernate.event.def.DefaultDeleteEventListener.onDelete( DefaultDeleteEventListener.java:49)
at org.hibernate.impl.SessionImpl.fireDelete(SessionImpl.java:7 66)
at org.hibernate.impl.SessionImpl.delete(SessionImpl.java:744)
at org.eclipse.emf.teneo.hibernate.HbSessionWrapper.delete(HbSe ssionWrapper.java:148)
at org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:342)
... 2 more
--------------070604070406000000010605--
Re: [Teneo]Problems when deleting object [message #88950 is a reply to message #88935] Wed, 11 July 2007 05:04 Go to previous messageGo to next message
--------------030205050307080105050001
> Martin Taal wrote:
>> Hi Guillaume,
>> gr. Maritn
Hi again,
by trying to load my package in an other way, I have reproduced my
exception and have a full stacktrace of it.
I attach the new code to replace loading by a resource and the full
stacktrace.
thanks
name="exceptnew.txt"
filename="exceptnew.txt"
Exception in thread "main" org.hibernate.LazyInitializationException: illegal access to loading collection
at test.delete.main(delete.java:94)
name="delete.java"
filename="delete.java"
package test;
import java.io.IOException;
import java.util.Collections;
import java.util.Properties;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.emf.teneo.PersistenceOptions;
import org.eclipse.emf.teneo.annotations.pannotation.InheritanceTyp e;
import org.eclipse.emf.teneo.hibernate.HbDataStore;
import org.eclipse.emf.teneo.hibernate.HbHelper;
import org.eclipse.emf.teneo.hibernate.resource.HibernateResource;
import org.hibernate.Query;
import org.hibernate.Session;
import org.hibernate.Transaction;
import org.hibernate.cfg.Environment;
public class delete {
// resourceSet used with Teneo for operations
private static ResourceSet resTeneo;
// name of the database
private static String dbname = "test";
// the datastore
private static HbDataStore hbds;
// the name of the datastore
private static String hbName = "MySF";
public static void main(String[] args){
resTeneo = new ResourceSetImpl();
resTeneo.getResourceFactoryRegistry().getExtensionToFactoryM ap().put( "ecore",
new EcoreResourceFactoryImpl());
props.setProperty(Environment.USER, "root");
props.setProperty(Environment.PASS, "root");
hbds.initialize();
// code for replacing the loading of the EPackage
// Create a new session and transaction
Session session = hbds.getSessionFactory().openSession();
Transaction tx = session.beginTransaction();
// delete the Meta models from the Hbds
Query query = session.createQuery("from EPackage pa left join fetch" +
" pa.eClassifiers where pa.e_id= 50");
EPackage delme = (EPackage) query.list().get(0);
// // the following loop is useless but necessary for deleting
session.delete(delme);
// commit and close transaction
tx.commit();
session.close();
--------------030205050307080105050001--
Re: [Teneo]Problems when deleting object [message #89194 is a reply to message #88950] Thu, 12 July 2007 04:16 Go to previous messageGo to next message
No one can help me ?
Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> In the meantime, I noticed that the first part of the stacktrace was
>>> gr. Maritn
> Hi again,
> stacktrace.
> thanks
> package test;
> // the datastore
> hbds.initialize();
> tx.commit();
> session.close();
Re: [Teneo]Problems when deleting object [message #89224 is a reply to message #89194] Thu, 12 July 2007 05:38 Go to previous messageGo to next message
I am looking at it. I have no solution yet but can you tell you what the cause of the issue is;
This is related to bidirectional relations in a one-to-many. The behavior of EMF to notify the other
side of the relation is interfering with Hibernate's lazy load behavior. Teneo tries to prevent this
from occuring but if hibernate loads a list without going through Teneo then Teneo is not in the
loop. I am currently checking if I can also let Teneo be in the loop when hibernate loads a list
without going through the teneo layer.
As an example:
Assume a model with a parent P which has one or more children C. There is a many-to-one relation
from C to its parent (C.parent) and a one-to-many from parent to C (parent.children). Assume first
only the parent is loaded (so the parent.children is not loaded yet). Then when the parent gets
deleted hb loads parent.children. During the load of this collection, for each child that is loaded
the many-to-one back to the parent is initialized. The relation is bidirectional so when the mto is
initialized the parent is notified that a new child is present, for this notification the collection
of the parent is accessed (indexOf). The indexOf goes through Teneo which detects that the
collection is not yet loaded and then tells hibernate to load it.
Then the exception is thrown because the collection is still in its initialization phase.
gr. Martin
> Guillaume
>>> Martin Taal wrote:
>>>> Hi Guillaume,
>>>> yet retest your case. I will be able to look at your question
>>>> gr. Maritn
>> Hi again,
>> stacktrace.
>> thanks
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> package test;
>> // the datastore
>> hbds.initialize();
>> fetch" +
>> tx.commit();
>> session.close();
The Netherlands
Re: [Teneo]Problems when deleting object [message #89254 is a reply to message #89224] Thu, 12 July 2007 06:15 Go to previous messageGo to next message
--------------090309020007030903060309
It seems that I have found a way to solve this. I needed to add a initializecollectioneventlistener
to Hibernate. I have attached it. You can just create your own initializecollection event listener
and copy my code into that.
You can the eventlistener as follows.
After
hbds.initialize();
you do this:
final EMFInitializeCollectionEventListener eventListener = new EMFInitializeCollectionEventListener();
((HbSessionDataStore)hbds.getConfiguration().getEventListene rs().setInitializeCollectionEventListeners(
new InitializeCollectionEventListener[] { eventListener });
this may not be completely syntactically correct as I copied/pasted to the post but I think you will
get the meaning.
This will be in the next release of Teneo.
Can you let me know if it works for you?
gr. Martin
> behavior of EMF to notify the other side of the relation is interfering
> with Hibernate's lazy load behavior. Teneo tries to prevent this from
> Teneo is not in the loop. I am currently checking if I can also let
> Teneo be in the loop when hibernate loads a list without going through
> the teneo layer.
> As an example:
> is a many-to-one relation from C to its parent (C.parent) and a
> one-to-many from parent to C (parent.children). Assume first only the
> the parent gets deleted hb loads parent.children. During the load of
> this collection, for each child that is loaded the many-to-one back to
> is initialized the parent is notified that a new child is present, for
> this notification the collection of the parent is accessed (indexOf).
> The indexOf goes through Teneo which detects that the collection is not
> gr. Martin
>> Hi,
>> Guillaume
>>>> Martin Taal wrote:
>>>>> Hi Guillaume,
>>>>> gr. Maritn
>>> Hi again,
>>> stacktrace.
>>> thanks
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> package test;
>>> // name of the database private static String dbname = "test";
>>> // the datastore
>>> hbds.initialize();
>>> fetch" +
>>> tx.commit();
>>> session.close();
The Netherlands
name="EMFInitializeCollectionEventListener.java"
filename="EMFInitializeCollectionEventListener.java"
* <copyright>
* Copyright (c) 2005, 2006, 2007 Springsite BV (The Netherlands) and others
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Martin Taal
* </copyright>
* $Id: AnyEObjectType.java,v 1.3 2007/02/08 23:11:37 mtaal Exp $
package org.eclipse.emf.teneo.hibernate.mapping;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.teneo.extension.ExtensionPoint;
import org.hibernate.HibernateException;
import org.hibernate.event.InitializeCollectionEvent;
import org.hibernate.event.def.DefaultInitializeCollectionEventList ener;
* Sets eDeliver to false for the owner of the collection during the initialization of the
* collection.
* @author <a href="mailto:mkanaley@tibco.com">Mike Kanaley</a>
public class EMFInitializeCollectionEventListener extends DefaultInitializeCollectionEventListener implements
ExtensionPoint {
private static final long serialVersionUID = 1L;
* (non-Javadoc)
* @see org.hibernate.event.def.DefaultInitializeCollectionEventList ener#onInitializeCollection(org.hibernate.event.InitializeCo llectionEvent)
public void onInitializeCollection(InitializeCollectionEvent event) throws HibernateException {
final Object owner = event.getCollection().getOwner();
boolean setDeliver = false;
boolean eDeliver = false;
EObject eobj = null;
if (owner instanceof EObject) {
eobj = (EObject) owner;
eDeliver = eobj.eDeliver();
try {
// only set to false if it was true
if (eDeliver) {
eobj.eSetDeliver(false);
setDeliver = true;
} catch (UnsupportedOperationException e) {
// in this case the eSetDeliver was not overridden from the baseclass
// ignore
try {
super.onInitializeCollection(event);
} finally {
if (setDeliver) {
eobj.eSetDeliver(eDeliver);
--------------090309020007030903060309--
Re: [Teneo]Problems when deleting object [message #89269 is a reply to message #89254] Thu, 12 July 2007 08:32 Go to previous messageGo to next message
Hi again,
In order to get the libraries to do this modification, I have had to
import from the Teneo cvs repository the project :
- org.eclipse.emf.teneo
- org.eclipse.emf.teneo.annotations
With this It is syntactically correct, but I have had to change :
in
InheritanceType.SINGLE_TABLE.name());
and now I have a new exception at the instruction hbds.initialize()
I obtain this exception :
database test droped
database test created
meta datas tables created
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/emf/teneo/annotations/pamodel/util/BasicPamodelB uilder
at
org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbD ataStore.java:531)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataStore.java:149)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:70)
at test.newtest.teneoMetaModel(newtest.java:180)
at test.newtest.addMetaModel(newtest.java:206)
at test.newtest.main(newtest.java:699)
So I can't test your code.
What must I do to avoid this exception?
thanks for the help,
Guillaume.
> initializecollectioneventlistener to Hibernate. I have attached it. You
> can just create your own initializecollection event listener and copy my
> code into that.
> After
> hbds.initialize();
> you do this:
> the post but I think you will get the meaning.
> gr. Martin
Re: [Teneo]Problems when deleting object [message #89284 is a reply to message #89269] Thu, 12 July 2007 08:39 Go to previous messageGo to next message
Hi Guillaume,
You can just create your own initializecollectioneventlistener and copy the code from the event
listener I sent. Then I don't think you need to do a get latest from cvs (please correct me if I am
wrong).
gr. Martin
> Hi again,
> in
> at
> at
> at
> Guillaume.
>> You can just create your own initializecollection event listener and
>> After
>> hbds.initialize();
>> you do this:
>> gr. Martin
The Netherlands
Re: [Teneo]Problems when deleting object [message #89299 is a reply to message #89284] Thu, 12 July 2007 08:44 Go to previous messageGo to next message
The problem is that I don't have :
and the code you give to me implements ExtensionPoint, that's why I have
import this.
Guillaume
Martin Taal wrote:
> Hi Guillaume,
> the code from the event listener I sent. Then I don't think you need to
> do a get latest from cvs (please correct me if I am wrong).
> gr. Martin
>> Hi again,
>> in
>> at
>> at
>> at
>> Guillaume.
>>> After
>>> hbds.initialize();
>>> you do this:
>>> to the post but I think you will get the meaning.
>>> gr. Martin
Re: [Teneo]Problems when deleting object [message #89314 is a reply to message #89299] Thu, 12 July 2007 09:31 Go to previous messageGo to next message
Hi again,
I have try your code without the "implements ExtensionPoint" in
EMFInitializeCollect then I can test it,
but I obtain always my org.hibernate.LazyInitializationException...
Guillaume
> import this.
> Guillaume
> Martin Taal wrote:
>> Hi Guillaume,
>> copy the code from the event listener I sent. Then I don't think you
>> need to do a get latest from cvs (please correct me if I am wrong).
>> gr. Martin
>>> Hi again,
>>> in
>>> at
>>> at
>>> at
>>> Guillaume.
>>>> After
>>>> hbds.initialize();
>>>> you do this:
>>>> gr. Martin
Re: [Teneo]Problems when deleting object [message #89329 is a reply to message #89314] Thu, 12 July 2007 09:50 Go to previous messageGo to next message
Forgot this, because the event listener is set after the hbds.initialize() you have to get a new
sessionFactory.
SessionFactory sf = ((HbSessionDataStore)hbds).getConfiguration().buildSessionFa ctory();
Session session = sf.getSessionFactory().openSession();
and then do the rest...
gr. Martin
> Hi again,
> Guillaume
>> Hi,
>> have import this.
>> Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> gr. Martin
>>>> Hi again,
>>>> in
>>>> at
>>>> at
>>>> at
>>>> Guillaume.
>>>>> After
>>>>> hbds.initialize();
>>>>> you do this:
>>>>> gr. Martin
The Netherlands
Re: [Teneo]Problems when deleting object [message #89364 is a reply to message #89329] Thu, 12 July 2007 10:00 Go to previous messageGo to next message
Hi again,
I have done this :
SessionFactory sf =
Session session = sf.openSession();
And then it works.
Thanks a lot !
Guillaume
> hbds.initialize() you have to get a new sessionFactory.
> SessionFactory sf =
> gr. Martin
>> Hi again,
>> Guillaume
>>> Hi,
>>> have import this.
>>> Guillaume
>>> Martin Taal wrote:
>>>> Hi Guillaume,
>>>> gr. Martin
>>>>> Hi again,
>>>>> to import from the Teneo cvs repository the project :
>>>>> in
>>>>> at
>>>>> at
>>>>> at
>>>>> Guillaume.
>>>>>> listener and copy my code into that.
>>>>>> After
>>>>>> hbds.initialize();
>>>>>> you do this:
>>>>>> eventListener });
>>>>>> copied/pasted to the post but I think you will get the meaning.
>>>>>> gr. Martin
H
Re: [Teneo]Problems when deleting object [message #89379 is a reply to message #89364] Thu, 12 July 2007 10:06 Go to previous message
Okay great, in the next release of Teneo you won't have to do the extre buildSessionFactory anymore
then the eventlistener will be set as part of the initialization step of the datastore.
gr. Martin
> Hi again,
> I have done this :
> SessionFactory sf =
> And then it works.
> Thanks a lot !
> Guillaume
>> SessionFactory sf =
>> gr. Martin
>>> Hi again,
>>> Guillaume
>>>> Hi,
>>>> have import this.
>>>> Guillaume
>>>> Martin Taal wrote:
>>>>> Hi Guillaume,
>>>>> wrong).
>>>>> gr. Martin
>>>>>> Hi again,
>>>>>> in
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Guillaume.
>>>>>>> After
>>>>>>> hbds.initialize();
>>>>>>> you do this:
>>>>>>> eventListener });
>>>>>>> gr. Martin
> H
The Netherlands
Re: [Teneo]Problems when deleting object [message #608688 is a reply to message #88756] Tue, 10 July 2007 15:40 Go to previous message
Hi Guillaume,
gr. Maritn
> Hello List,
> loading collection
> Thanks
> Guillaume
> hbds.initialize();
> resource MySF
> at
> loading collection
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Re: [Teneo]Problems when deleting object [message #608693 is a reply to message #88860] Wed, 11 July 2007 04:47 Go to previous message
Martin Taal wrote:
> Hi Guillaume,
> gr. Maritn
nsPrefix="ptyp">
</ecore:EPackage>
ordered="false"
ordered="false"
ordered="false"
ordered="false"
ordered="false"
</eClassifiers>
ordered="false"
ordered="false"
ordered="false"
Guillaume
name="except.txt"
... 2 more
Re: [Teneo]Problems when deleting object [message #608694 is a reply to message #88935] Wed, 11 July 2007 05:04 Go to previous message
> Martin Taal wrote:
>> Hi Guillaume,
>> gr. Maritn
Hi again,
stacktrace.
thanks
name="delete.java"
package test;
// the datastore
hbds.initialize();
tx.commit();
session.close();
Re: [Teneo]Problems when deleting object [message #608710 is a reply to message #88950] Thu, 12 July 2007 04:16 Go to previous message
Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> gr. Maritn
> Hi again,
> stacktrace.
> thanks
> package test;
> // the datastore
> hbds.initialize();
> tx.commit();
> session.close();
Re: [Teneo]Problems when deleting object [message #608712 is a reply to message #89194] Thu, 12 July 2007 05:38 Go to previous message
As an example:
gr. Martin
> Guillaume
>>> Martin Taal wrote:
>>>> Hi Guillaume,
>>>> gr. Maritn
>> Hi again,
>> stacktrace.
>> thanks
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> package test;
>> // the datastore
>> hbds.initialize();
>> fetch" +
>> tx.commit();
>> session.close();
The Netherlands
Re: [Teneo]Problems when deleting object [message #608714 is a reply to message #89224] Thu, 12 July 2007 06:15 Go to previous message
After
hbds.initialize();
you do this:
get the meaning.
gr. Martin
> the teneo layer.
> As an example:
> gr. Martin
>> Hi,
>> Guillaume
>>>> Martin Taal wrote:
>>>>> Hi Guillaume,
>>>>> gr. Maritn
>>> Hi again,
>>> stacktrace.
>>> thanks
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> package test;
>>> // the datastore
>>> hbds.initialize();
>>> fetch" +
>>> tx.commit();
>>> session.close();
The Netherlands
* <copyright>
* Contributors:
* Martin Taal
* </copyright>
* collection.
ExtensionPoint {
* (non-Javadoc)
try {
if (eDeliver) {
setDeliver = true;
// ignore
try {
} finally {
if (setDeliver) {
Re: [Teneo]Problems when deleting object [message #608715 is a reply to message #89254] Thu, 12 July 2007 08:32 Go to previous message
Hi again,
in
at
at
at
Guillaume.
> code into that.
> After
> hbds.initialize();
> you do this:
> gr. Martin
Re: [Teneo]Problems when deleting object [message #608716 is a reply to message #89269] Thu, 12 July 2007 08:39 Go to previous message
Hi Guillaume,
wrong).
gr. Martin
> Hi again,
> in
> at
> at
> at
> Guillaume.
>> After
>> hbds.initialize();
>> you do this:
>> gr. Martin
The Netherlands
Re: [Teneo]Problems when deleting object [message #608717 is a reply to message #89284] Thu, 12 July 2007 08:44 Go to previous message
import this.
Guillaume
Martin Taal wrote:
> Hi Guillaume,
> gr. Martin
>> Hi again,
>> in
>> at
>> at
>> at
>> Guillaume.
>>> After
>>> hbds.initialize();
>>> you do this:
>>> gr. Martin
Re: [Teneo]Problems when deleting object [message #608718 is a reply to message #89299] Thu, 12 July 2007 09:31 Go to previous message
Hi again,
Guillaume
> import this.
> Guillaume
> Martin Taal wrote:
>> Hi Guillaume,
>> gr. Martin
>>> Hi again,
>>> in
>>> at
>>> at
>>> at
>>> Guillaume.
>>>> After
>>>> hbds.initialize();
>>>> you do this:
>>>> gr. Martin
Re: [Teneo]Problems when deleting object [message #608719 is a reply to message #89314] Thu, 12 July 2007 09:50 Go to previous message
sessionFactory.
gr. Martin
> Hi again,
> Guillaume
>> Hi,
>> have import this.
>> Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> gr. Martin
>>>> Hi again,
>>>> in
>>>> at
>>>> at
>>>> at
>>>> Guillaume.
>>>>> After
>>>>> hbds.initialize();
>>>>> you do this:
>>>>> gr. Martin
The Netherlands
Re: [Teneo]Problems when deleting object [message #608721 is a reply to message #89329] Thu, 12 July 2007 10:00 Go to previous message
Hi again,
I have done this :
SessionFactory sf =
And then it works.
Thanks a lot !
Guillaume
> SessionFactory sf =
> gr. Martin
>> Hi again,
>> Guillaume
>>> Hi,
>>> have import this.
>>> Guillaume
>>> Martin Taal wrote:
>>>> Hi Guillaume,
>>>> gr. Martin
>>>>> Hi again,
>>>>> in
>>>>> at
>>>>> at
>>>>> at
>>>>> Guillaume.
>>>>>> After
>>>>>> hbds.initialize();
>>>>>> you do this:
>>>>>> eventListener });
>>>>>> gr. Martin
H
Re: [Teneo]Problems when deleting object [message #608722 is a reply to message #89364] Thu, 12 July 2007 10:06 Go to previous message
gr. Martin
> Hi again,
> I have done this :
> SessionFactory sf =
> And then it works.
> Thanks a lot !
> Guillaume
>> SessionFactory sf =
>> gr. Martin
>>> Hi again,
>>> Guillaume
>>>> Hi,
>>>> have import this.
>>>> Guillaume
>>>> Martin Taal wrote:
>>>>> Hi Guillaume,
>>>>> wrong).
>>>>> gr. Martin
>>>>>> Hi again,
>>>>>> in
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Guillaume.
>>>>>>> After
>>>>>>> hbds.initialize();
>>>>>>> you do this:
>>>>>>> eventListener });
>>>>>>> gr. Martin
> H
The Netherlands
Previous Topic:[EMF Compare] XSLT File
Next Topic:[Teneo] another problems: my datas are modified by Teneo
Current Time: Sat Jul 19 11:52:54 EDT 2025
Powered by FUDForum. Page generated in 0.34778 seconds
