Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » invoke template from java with string return?
invoke template from java with string return? [message #87792] Sat, 30 June 2007 15:40 Go to next message
Originally posted by: woodri.us.ibm.com
I've looked at the runTransformOnX() methods (x=Object,String, ...) in
org.eclipse.jet.JET2Platform. Is there a JET2 class that does something
like org.eclipse.emf.codegen.jet.JETEmitter in EMF: take a list of
arguments, execute a template against them, and return a string?
Rick
Re: invoke template from java with string return? [message #87819 is a reply to message #87792] Sun, 01 July 2007 08:04 Go to previous messageGo to next message
Rick,
I'll redirect your question to the M2T newsgroup (on the "to" list of
the reply) where the JET2 questions are answered.
Rick Wood wrote:
> something like org.eclipse.emf.codegen.jet.JETEmitter in EMF: take a
> list of arguments, execute a template against them, and return a string?
> Rick
Re: invoke template from java with string return? [message #87847 is a reply to message #87819] Mon, 02 July 2007 08:16 Go to previous messageGo to next message
Thanks Ed - I looked for that group, but forgot to hit the "refresh"
button on the newsgroup subscription panel ... !
Ed Merks wrote:
> Rick,
> Rick Wood wrote:
>> Hi,
>> Thanks,
>> Rick
Re: invoke template from java with string return? [message #88177 is a reply to message #87792] Thu, 05 July 2007 09:26 Go to previous message
Rick:
Yes, JET 0.8.0 has org.eclipse.jet.JET2TemplateManager. You use it something
like this...
String[] jetTransformsToSearch = { "a.b.c", ... };
final String templatePath = "... project relative path of the template to
run.jet ...";
final JET2Context context = new JET2Context( ... source model or null ...);
// optionally set any context variables via
context.setVariable("name", ... value ...);
final BufferedJET2Writer out = new BodyContentWriter();
JET2TemplateManager.run( jetTransformsToSeach, new
JET2TemplateManager.ITemplateOperation() {
public run(JET2TemplateManager.ITemplateRunner templateRunner) {
String result = templateRunner.generate( templatePath, context,
out );
// do something with the result
String output = out.getContent();
The reason for passing the runnable-like class is that the manager may have
to dynamically load JET projects from the workspace. JET is very careful to
make sure such things get unloaded again - using the ITemplateOperation
helps identify that boundary. In real life, you would probably execute
multiple templates in a single ITemplateOperation.
Lastly, I noticed the Javadoc for ITemplateRunner.generate() says it
throughs IllegalAccessException. It does not. It throughs
IllegalArgumentException of templatePath does not map to a know template. I
have submitted bug 195523
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=195523).
Paul
"Rick Wood" <woodri@us.ibm.com> wrote in message
news:f66bjj$39i$1@build.eclipse.org...
> Rick
Re: invoke template from java with string return? [message #608619 is a reply to message #87792] Sun, 01 July 2007 08:04 Go to previous message
Rick,
Rick Wood wrote:
> Rick
Re: invoke template from java with string return? [message #608621 is a reply to message #87819] Mon, 02 July 2007 08:16 Go to previous message
Ed Merks wrote:
> Rick,
> Rick Wood wrote:
>> Hi,
>> Thanks,
>> Rick
Re: invoke template from java with string return? [message #608643 is a reply to message #87792] Thu, 05 July 2007 09:26 Go to previous message
Rick:
like this...
run.jet ...";
out );
Paul
> Rick
Previous Topic:[Teneo / JPOX] Reload content
Next Topic:[Teneo / JPOX] Spaces with type string
Current Time: Sat Jul 19 05:54:13 EDT 2025
Powered by FUDForum. Page generated in 1.04716 seconds
