Home » Archived » B3 » question/issue : changing ~= operator to ?=
question/issue : changing ~= operator to ?= [message #538103] Fri, 04 June 2010 21:38 Go to next message
after having typed ~= many times and found it very irritating in Eclipse
editors that the sequence to enter this has to be:
'~' ' '|'<esc>' '='
whereas it in the native mac is fine to type just '~' '='.
In Eclipse any character after ~ that it does not recognize as
composable deletes the ~ character.
All Eclipse editors (I tried) have the same behavior.
('vi' works fine though ;) )
I have the same issue when entering a regexp ~/.../.
How does this work on the Linux and Windows versions of Eclipse (try it
in a Java editor for instance).
Anyway, this has led me to consider replacing the use of ~ with ?. i.e.
'~=' becomes '?=' and patterns become ?/../ for regexp and ?" " for
simple pattern.
- henrik
Re: question/issue : changing ~= operator to ?= [message #538107 is a reply to message #538103] Sat, 05 June 2010 01:21 Go to previous messageGo to next message
I see several reasons not to do that change:
1. p2ql uses ~=. We cannot change that. Not now and not later.
2. Only some of the European keyboards suffer from this. A US keyboard
has the tilde as a first class character (shifted at top left). Same
thing on a French keyboard.
3. The ~= intuitively leads me to believe that this must be an
approximation which is fairly close to what it really is.
- thomas
On 06/05/2010 03:38 AM, Henrik Lindberg wrote:
> '~' ' '|'<esc>' '='
> simple pattern.
> - henrik
Re: question/issue : changing ~= operator to ?= [message #538166 is a reply to message #538107] Sat, 05 June 2010 20:10 Go to previous messageGo to next message
Well,
it is kind of broken in Eclipse - see if we can get it fixed in the
editor - it should not behave that way. (And I like the ~= too, I just
don't like typing it in eclipse :)
- henrik
> - thomas
>> Hi,
>> '~' ' '|'<esc>' '='
>> simple pattern.
>> - henrik
Re: question/issue : changing ~= operator to ?= [message #538170 is a reply to message #538166] Sat, 05 June 2010 21:29 Go to previous message
I reported it as an issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=315894
BTW: It is only the text editors that have it wrong, it works ok in all
dialogs.
- henrik
On 6/6/10 2:10 AM, Henrik Lindberg wrote:
> Well,
> - henrik
>> - thomas
>>> Hi,
>>> '~' ' '|'<esc>' '='
>>> simple pattern.
>>> - henrik
Re: question/issue : changing ~= operator to ?= [message #608294 is a reply to message #538103] Sat, 05 June 2010 01:21 Go to previous message
- thomas
> '~' ' '|'<esc>' '='
> simple pattern.
> - henrik
Re: question/issue : changing ~= operator to ?= [message #608323 is a reply to message #538107] Sat, 05 June 2010 20:10 Go to previous message
Well,
- henrik
> - thomas
>> Hi,
>> '~' ' '|'<esc>' '='
>> simple pattern.
>> - henrik
Re: question/issue : changing ~= operator to ?= [message #608329 is a reply to message #538166] Sat, 05 June 2010 21:29 Go to previous message
dialogs.
- henrik
> Well,
> - henrik
>> - thomas
>>> Hi,
>>> '~' ' '|'<esc>' '='
>>> simple pattern.
>>> - henrik
Previous Topic:issues with property terminal
Next Topic:issues with property terminal
Current Time: Sat Jul 19 15:40:25 EDT 2025
Powered by FUDForum. Page generated in 0.05459 seconds
